Tex Posted September 17, 2012 Share Posted September 17, 2012 Li puoi elencare i componenti pf? Vorrei dargli un occhiata.. Si i tubi vanno bene, ma occhio che con le.curve un po troppo.strette si strozzano facilmente. Il liquido usa.semplice acqua distillata.che comperi in farmacia.a.2eu.. Se vuoi prendi il prodotto.funghicida. Cosi.eviti.che i tubi vengano verdi Nei rad in vendita trovi ventole.. Ma sono gia.kit. La.staffa tocca a te a.comprarla. Vero che sono cari, ma.son fatti di rame e alluminio, entrambi materiali costosi Ps: non comprare coloranti.. Dovrai fare.spesso.manuntenzione.a.causa di quelli.. Si imcrostano e fanno.delle.patine.sui.componenti. Usa semplice.tubo.rosso uv reativo e qualche lampadina led uv Quote Link to comment Share on other sites More sharing options...
tom1 Posted September 18, 2012 Share Posted September 18, 2012 si facci dare uno sguardo per evitare problemi o acquisti errati. Quote Link to comment Share on other sites More sharing options...
Dark_Night Posted September 18, 2012 Author Share Posted September 18, 2012 Phobya G-Changer 280 Alphacool Repack - Dual DC-LT - 5,25 Single Bay Station V1 ? without pump Aquacomputer cuplex kryos XT for sockets 1366/1156/775, G1/4 Watercool HEATKILLER® GPU-X³ GTX 560 "Hole Edition" Phobya DC12-400 & EK-Reservoir Combo DCP 4.0 Bundle mancano tubi, e raccordi. Quote Link to comment Share on other sites More sharing options...
tom1 Posted September 19, 2012 Share Posted September 19, 2012 direi ok , per tubi prendi i musterkleer e raccordi 13/10 Quote Link to comment Share on other sites More sharing options...
Tex Posted September 19, 2012 Share Posted September 19, 2012 Mmmh metti un rad da 120 in piu Quote Link to comment Share on other sites More sharing options...
Dark_Night Posted September 19, 2012 Author Share Posted September 19, 2012 da 120 in piu che? i tubi da 1/4g non li trovo. Quote Link to comment Share on other sites More sharing options...
Dark_Night Posted September 19, 2012 Author Share Posted September 19, 2012 facciamo un pò di chiarezza. Il radiatore, il wb e la vaschetta e la pompa sono tutti 1/4g. Ma che tubi posso inserire? Non mi pare di averlo letto nelle specifiche, posso mettere un 6 un 8 un 12.. perche non è specificato? Devo per forza comprare i raccordi per mettere il tubo che voglio da quello che ho capito? Se voglio inserire i 13/10 dovrò comprare dieci raccordi ( due per ogni componente )? Altrimenti potevo risparmiare questa spesa. Quote Link to comment Share on other sites More sharing options...
tom1 Posted September 19, 2012 Share Posted September 19, 2012 ovviamente servono i raccordi. Quote Link to comment Share on other sites More sharing options...
Dark_Night Posted September 19, 2012 Author Share Posted September 19, 2012 ok, quidni le misure 1/4g sono tutte da dieci. Nel senso che il wb del cpu/vga la pompa, il radiatore e la vaschetta hanno un uscita/entrata per i tubi da dieci, mettendo i raccordi invece inserisco quelli da 13. perche non usare direttamente quelli da dieci? piu effetto scenico o cosa? in fin dei conti la pressione è sempre quella Quote Link to comment Share on other sites More sharing options...
xtremer Posted September 19, 2012 Share Posted September 19, 2012 come rad il 280 basta già da solo per cpu e vga per quanto riguarda i tubi,nei raccordi 13/10 puoi mettere il tubo 3/8id come questo: http://www.aquatuning.it/product_info.php/info/p11080_Alphacool-tubing-HF-13-10--3-8-ID----blue--Semi-trasparente-.html cmq i g1/4 non sono tutti da 10 ps:come pompa potresti mettere una laing ddc 500 costa circa 25€ in più di quella che hai preso tu e va molto meglio,inoltre puoi mettergli il tubo 3/8id Quote Link to comment Share on other sites More sharing options...
Tex Posted September 19, 2012 Share Posted September 19, 2012 Si quoto, comunque ho proposto un rad in piu da 120mm per le.T piu ottimali.. Cosi per fare: rad 280 - cpu - rad 120 - vga - pompa - vaschetta. Certamente migliore la pompa da te proposta ma budget parlando e limitato. Quote Link to comment Share on other sites More sharing options...
tom1 Posted September 20, 2012 Share Posted September 20, 2012 esatto, quindi rimango per la precedente configurazione. Quote Link to comment Share on other sites More sharing options...
xtremer Posted September 20, 2012 Share Posted September 20, 2012 @tex hai ragione per le temp,però quella phobya non è chissà quale pompa,dicevo anche per questo di lasciare solo il 280,ma poi perchè la phobya con reservoir ed un altra reservoir alphacool XD ? Quote Link to comment Share on other sites More sharing options...
Dark_Night Posted September 25, 2012 Author Share Posted September 25, 2012 per il momento solo i raccordi ho preso. Quote Link to comment Share on other sites More sharing options...
tom1 Posted September 26, 2012 Share Posted September 26, 2012 ok, postaci alcune foto appena arrivano. Quote Link to comment Share on other sites More sharing options...
Dark_Night Posted September 26, 2012 Author Share Posted September 26, 2012 ImageShack® - Online Photo and Video Hosting Quote Link to comment Share on other sites More sharing options...
tom1 Posted September 26, 2012 Share Posted September 26, 2012 ma è un raccordo per idraulica ? Quote Link to comment Share on other sites More sharing options...
xtremer Posted September 26, 2012 Share Posted September 26, 2012 loooooooool ma sono quelli per il bagno XD? Quote Link to comment Share on other sites More sharing options...
Dark_Night Posted September 26, 2012 Author Share Posted September 26, 2012 so dei raccordi in rame, 3/8 uscita e 1/4 entrata ( da mettere sul radiatore ecc ecc ). Quote Link to comment Share on other sites More sharing options...
Gianluca92 Posted September 26, 2012 Share Posted September 26, 2012 ma che l'hanno il passo G1/4 per avvitarli e un oring? Quote Link to comment Share on other sites More sharing options...
tom1 Posted September 27, 2012 Share Posted September 27, 2012 bhè non li paghi di più di quelli da prendere? Quote Link to comment Share on other sites More sharing options...
xtremer Posted September 27, 2012 Share Posted September 27, 2012 si ma il passo 1/4 deve essere con la filettatura da avvitare nei vari componenti,qui non se ne vede o sbaglio? Quote Link to comment Share on other sites More sharing options...
Dark_Night Posted September 29, 2012 Author Share Posted September 29, 2012 ce sta tutto, purtroppo non vanno bene perche sono 10-3/8 a me servono i 13. si costano di piu, dieci raccordi oltre i sessanta euro ma ovviamente questi sono stati "rimediati" Quote Link to comment Share on other sites More sharing options...
tom1 Posted September 29, 2012 Share Posted September 29, 2012 ok, comunque per me rimangono meglio quelli dedicati al cooling da pc. Quote Link to comment Share on other sites More sharing options...
Dark_Night Posted September 29, 2012 Author Share Posted September 29, 2012 ok, comunque per me rimangono meglio quelli dedicati al cooling da pc. gia ma solo di raccordi spenderò 40 euro . Quote Link to comment Share on other sites More sharing options...
