Integrated GPU overclocking tips ?
Prd91
hi, i want to overclock the iGPU (uhd 770) of the i5-12600k.  Do you have any tips to do it safely and preferably not to decrease the CPU life with this procedure?  I use 3D rendering / design and (programming).  in the future I will definitely get a dedicated gpu but for the moment I need something sure to increase the performance in this area, keeping the PC longer and more durable as possible.  I also ask you one more thing: on z690 I know for sure that it is possible to overclock iGPU, but on B660 motherboards enabled to over clock bclk you can over clock the integrated gpu as well as the CPU?
