  3. Case
  4. [Thread Ufficiale]Cooler Master HAF XB-HAF Cube
Pianificato Fissato Bloccato Spostato Case
25 Post 0 Autori 6.1k Visualizzazioni
    principe andry
    Sito ufficiale -> click e micro sito dedicato -> click
    top2.jpg?1546688309
    top4.jpg?227237370
    top5.jpg?2099760086
    top6.jpg?635251770
    [TABLE=width: 590]
    [TR]
    [TD=class: specs, width: 100, bgcolor: #E4E4E4]Materials[/TD]
    [TD=class: specs, bgcolor: #E4E4E4]Steel body, Front Mesh, Plastic bezel[/TD]
    [/TR]
    [TR]
    [TD=class: specs2, width: 100]Dimension (W / H / D)[/TD]
    [TD=class: specs2]442 x 330 x 423mm / 17.4 x 13 x 16.7inch[/TD]
    [/TR]
    [TR]
    [TD=class: specs, width: 100, bgcolor: #E4E4E4]Net Weight[/TD]
    [TD=class: specs, bgcolor: #E4E4E4]8.2kg / 18.1lb[/TD]
    [/TR]
    [TR]
    [TD=class: specs2, width: 100]M/B Type[/TD]
    [TD=class: specs2]ATX, Micro-ATX, Mini-ITX[/TD]
    [/TR]
    [TR]
    [TD=class: specs, width: 100, bgcolor: #E4E4E4]5.25" Drive Bays[/TD]
    [TD=class: specs, bgcolor: #E4E4E4]2[/TD]
    [/TR]
    [TR]
    [TD=class: specs2, width: 100]3.5" Drive Bays[/TD]
    [TD=class: specs2]2 (from X-Dock)[/TD]
    [/TR]
    [TR]
    [TD=class: specs, width: 100, bgcolor: #E4E4E4]2.5" Drive Bays[/TD]
    [TD=class: specs, bgcolor: #E4E4E4]6 (2 from X-Dock)[/TD]
    [/TR]
    [TR]
    [TD=class: specs2, width: 100]I/O Panel[/TD]
    [TD=class: specs2]USB 3.0 x 2 (internal)
    Audio In & Out x 1 (supports HD Audio)[/TD]
    [/TR]
    [TR]
    [TD=class: specs, width: 100, bgcolor: #E4E4E4]Expansion Slots[/TD]
    [TD=class: specs, bgcolor: #E4E4E4]7[/TD]
    [/TR]
    [TR]
    [TD=class: specs2, width: 100]Cooling System[/TD]
    [TD=class: specs2]Front: 120mm fan x 2, 1800 RPM, 21 dBA
    (or 140mm fan x 2)
    Rear: 120mm fan x 1 (optional), and
    80mm fan x 2 (optional)
    Top: 200mm fan x 1 (optional)[/TD]
    [/TR]
    [TR]
    [TD=class: specs, width: 100, bgcolor: #E4E4E4]Power Supply Type[/TD]
    [TD=class: specs, bgcolor: #E4E4E4]ATX PS2 (Support Max. of the PSU in 180mm length)[/TD]
    [/TR]
    [TR]
    [TD=class: specs2, width: 100]Maximum Compatibility[/TD]
    [TD=class: specs2]VGA card length: 334mm/13.1inch
    CPU cooler height: 180mm/7.1inch
    Water cooling support:
    240mm radiator x 1(front), 120mm radiator x 1(rear)[/TD]
    [/TR]
    [/TABLE]
      le aggiungo in prima pagina
        un lan box da liquidare ;)
          su caccia la scimmia mattia :D
            nono
            ho un bel ft02 che non sta bene a liquido
            il haf xb con le ventole come sono predisposte e la mobo rialzata viene un bel lavoretto.
            rad da 240 + 120 = cpu e vga al fresco 😄
            la mia scimmia è altro..
              voglio vederli proprio i progetti in questo cube di CM
