Problema con VMWare Workstation Pro 12
Ciao a tutti.
Purtroppo ho un serio problema con Windows Xp Pro SP3, installato in VMWare Workstation Pro 12.
Ho cambiato totalmente hardware, per cui penso che il problema sia stato causato da questo.
Sia il sistema virtuale già installato, sia se volessi installarne uno nuovo, mi dà questo errore:
https://ibb.co/gBMs1k
Ho seguito qualche guida/consiglio online ma non ha funzionato... :muro:
Grazie mille, buona giornata.
Matteo
Ciao
2017-08-30T11:26:36.391+02:00| vmx| I125: Log for VMware Workstation pid=6160 version=12.5.7 build=build-5813279 option=Release
2017-08-30T11:26:36.391+02:00| vmx| I125: The process is 64-bit.
2017-08-30T11:26:36.391+02:00| vmx| I125: Host codepage=windows-1252 encoding=windows-1252
2017-08-30T11:26:36.391+02:00| vmx| I125: Host is Windows 10, 64-bit (Build 15063)
2017-08-30T11:26:36.344+02:00| vmx| I125: VTHREAD initialize main thread 0 "vmx" host id 13112
2017-08-30T11:26:36.344+02:00| vmx| I125: LOCALE windows-1252 -> NULL User=410 System=410
2017-08-30T11:26:36.344+02:00| vmx| I125: Msg_SetLocaleEx: HostLocale=windows-1252 UserLocale=NULL
2017-08-30T11:26:36.344+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:ProgramDataVMware): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.344+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:ProgramDataVMwareVMware Workstation): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.344+02:00| vmx| I125: DictionaryLoad: Cannot open file "C:UsersDefaultAppDataRoamingVMwareconfig.ini": Unknown error 3 (0x3).
2017-08-30T11:26:36.344+02:00| vmx| I125: Msg_Reset:
2017-08-30T11:26:36.344+02:00| vmx| I125: [msg.dictionary.load.openFailed] Cannot open file "C:UsersDefaultAppDataRoamingVMwareconfig.ini": Unknown error 3 (0x3).
2017-08-30T11:26:36.344+02:00| vmx| I125: ----------------------------------------
2017-08-30T11:26:36.344+02:00| vmx| I125: ConfigDB: Failed to load C:UsersDefaultAppDataRoamingVMwareconfig.ini
2017-08-30T11:26:36.344+02:00| vmx| I125: OBJLIB-LIB: Objlib initialized.
2017-08-30T11:26:36.344+02:00| vmx| I125: PREF Optional preferences file not found at C:UsersDefaultAppDataRoamingVMwareconfig.ini. Using default values.
2017-08-30T11:26:36.344+02:00| vmx| I125: UUID: SMBIOS UUID is reported as '96 6b e4 4b ef 4b 2a b9-dd 49 88 d7 f6 e2 3a d9'.
2017-08-30T11:26:36.344+02:00| vmx| I125: FILE: FileLockDynaLink: Further process validation tools are: available
2017-08-30T11:26:36.344+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:UsersDefaultAppDataRoamingVMwarepreferences.ini.lck): Unknown error 3 (0x3) (3)
2017-08-30T11:26:36.344+02:00| vmx| W115: FILE: FileLockCreateEntryDirectory creation failure on 'C:UsersDefaultAppDataRoamingVMwarepreferences.ini.lck': No such file or directory
2017-08-30T11:26:36.344+02:00| vmx| I125: [msg.preference.loadNoLock] Unable to lock user preference file C:UsersDefaultAppDataRoamingVMwarepreferences.ini for reading.
2017-08-30T11:26:36.344+02:00| vmx| I125: PREF Failed to load user preferences.
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:ProgramDataVMware): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipog): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppData): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocal): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocalTemp): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocalTempvmware-tipog): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: Hostname=DESKTOP-GODURJ7
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=fe80::39fc:8a3a:22e:7abc%5
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=fe80::2966:802b:fef9:ef66%2
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=fe80::18d4:62de:c419:af6f%6
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=fe80::88d:2aac:3f57:fe79%3
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=192.168.40.1
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=192.168.226.1
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=192.168.1.134
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=2001:0:5ef5:79fd:88d:2aac:3f57:fe79
2017-08-30T11:26:36.422+02:00| vmx| I125: System uptime 92680602864 us
2017-08-30T11:26:36.422+02:00| vmx| I125: Command line: "C:Program Files (x86)VMwareVMware Workstationx64vmware-vmx.exe" "-T" "querytoken" "-s" "vmx.stdio.keep=TRUE" "-#" "product=1;name=VMware Workstation;version=12.5.7;buildnumber=5813279;licensename=VMware Workstation;licenseversion=12.0;" "-@" "pipe=\.pipevmxcaec9fa46175bab1;msgs=ui" "C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmx"
2017-08-30T11:26:36.422+02:00| vmx| I125: Msg_SetLocaleEx: HostLocale=windows-1252 UserLocale=NULL
2017-08-30T11:26:36.453+02:00| vmx| I125: WQPoolAllocPoll : pollIx = 1, signalHandle = 624
2017-08-30T11:26:36.453+02:00| vmx| I125: WQPoolAllocPoll : pollIx = 2, signalHandle = 680
2017-08-30T11:26:36.453+02:00| vmx| I125: VigorTransport listening on fd 692
2017-08-30T11:26:36.453+02:00| vmx| I125: Vigor_Init 1
2017-08-30T11:26:36.453+02:00| vmx| I125: Connecting 'ui' to pipe '\.pipevmxcaec9fa46175bab1' with user '(null)'
2017-08-30T11:26:36.453+02:00| vmx| I125: VMXVmdb: Local connection timeout: 60000 ms.
2017-08-30T11:26:36.547+02:00| vmx| I125: VmdbAddConnection: cnxPath=/db/connection/#1/, cnxIx=1
2017-08-30T11:26:36.547+02:00| vmx| I125: Vix: [13112 mainDispatch.c:490]: VMAutomation: Initializing VMAutomation.
2017-08-30T11:26:36.547+02:00| vmx| I125: Vix: [13112 mainDispatch.c:746]: VMAutomationOpenListenerSocket() listening
2017-08-30T11:26:36.563+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1870, success=1 additionalError=0
2017-08-30T11:26:36.563+02:00| vmx| I125: Transitioned vmx/execState/val to poweredOff
2017-08-30T11:26:36.563+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2017-08-30T11:26:36.563+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=2, newAppState=1877, success=1 additionalError=0
2017-08-30T11:26:36.563+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=3, newAppState=1881, success=1 additionalError=0
2017-08-30T11:26:36.578+02:00| vmx| I125: IOPL_VBSRunning: VBS is set to 0
2017-08-30T11:26:36.578+02:00| vmx| I125: IOCTL_VMX86_SET_MEMORY_PARAMS already set
2017-08-30T11:26:36.578+02:00| vmx| I125: FeatureCompat: No EVC masks.
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID vendor: AuthenticAMD
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID family: 0x17 model: 0x1 stepping: 0x1
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID codename: Unknown
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID name: AMD Ryzen 7 1700X Eight-Core Processor
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000000, 0: 0x0000000d 0x68747541 0x444d4163 0x69746e65
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000001, 0: 0x00800f11 0x00100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000002, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000003, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000004, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000005, 0: 0x00000040 0x00000040 0x00000003 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000006, 0: 0x00000004 0x00000000 0x00000001 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000007, 0: 0x00000000 0x209c01a9 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000a, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 0: 0x00000007 0x00000340 0x00000340 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1: 0x0000000f 0x00000340 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2: 0x00000100 0x00000240 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 5: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 6: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 7: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 8: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 9: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 10: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 11: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 12: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 13: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 14: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 15: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 16: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 17: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 18: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 19: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 20: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 21: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 22: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 23: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 24: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 25: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 26: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 27: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 28: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 29: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 30: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 31: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 32: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 33: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 34: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 35: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 36: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 37: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 38: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 39: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000000, 0: 0x8000001f 0x68747541 0x444d4163 0x69746e65
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000001, 0: 0x00800f11 0x20000000 0x35c233ff 0x2fd3fbff
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000002, 0: 0x20444d41 0x657a7952 0x2037206e 0x30303731
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000003, 0: 0x69452058 0x2d746867 0x65726f43 0x6f725020
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000004, 0: 0x73736563 0x2020726f 0x20202020 0x00202020
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000005, 0: 0xff40ff40 0xff40ff40 0x20080140 0x40040140
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000006, 0: 0x26006400 0x66006400 0x02006140 0x00808140
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000007, 0: 0x00000000 0x0000001b 0x00000000 0x00006599
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000008, 0: 0x00003030 0x00000007 0x0000400f 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000a, 0: 0x00000001 0x00008000 0x00000000 0x0001bcff
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000010, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000011, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000012, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000013, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000014, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000015, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000016, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000017, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000018, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000019, 0: 0xf040f040 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001a, 0: 0x00000003 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001b, 0: 0x000003ff 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001d, 0: 0x00004121 0x01c0003f 0x0000003f 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001d, 1: 0x00004122 0x00c0003f 0x000000ff 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001d, 2: 0x00004143 0x01c0003f 0x000003ff 0x00000002
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001d, 3: 0x0001c163 0x03c0003f 0x00001fff 0x00000001
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001e, 0: 0x00000000 0x00000100 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001f, 0: 0x00000007 0x0000016f 0x0000000f 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID differences from hostCPUID.
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[1] level 00000001, 0: 0x00800f11 0x01100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[1] level 8000001e, 0: 0x00000001 0x00000100 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[2] level 00000001, 0: 0x00800f11 0x02100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[2] level 8000001e, 0: 0x00000002 0x00000101 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[3] level 00000001, 0: 0x00800f11 0x03100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[3] level 8000001e, 0: 0x00000003 0x00000101 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[4] level 00000001, 0: 0x00800f11 0x04100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[4] level 8000001e, 0: 0x00000004 0x00000102 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[5] level 00000001, 0: 0x00800f11 0x05100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[5] level 8000001e, 0: 0x00000005 0x00000102 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[6] level 00000001, 0: 0x00800f11 0x06100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[6] level 8000001e, 0: 0x00000006 0x00000103 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[7] level 00000001, 0: 0x00800f11 0x07100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[7] level 8000001e, 0: 0x00000007 0x00000103 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[8] level 00000001, 0: 0x00800f11 0x08100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[8] level 8000001e, 0: 0x00000008 0x00000104 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[9] level 00000001, 0: 0x00800f11 0x09100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[9] level 8000001e, 0: 0x00000009 0x00000104 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[10] level 00000001, 0: 0x00800f11 0x0a100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[10] level 8000001e, 0: 0x0000000a 0x00000105 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[11] level 00000001, 0: 0x00800f11 0x0b100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[11] level 8000001e, 0: 0x0000000b 0x00000105 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[12] level 00000001, 0: 0x00800f11 0x0c100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[12] level 8000001e, 0: 0x0000000c 0x00000106 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[13] level 00000001, 0: 0x00800f11 0x0d100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[13] level 8000001e, 0: 0x0000000d 0x00000106 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[14] level 00000001, 0: 0x00800f11 0x0e100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[14] level 8000001e, 0: 0x0000000e 0x00000107 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[15] level 00000001, 0: 0x00800f11 0x0f100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[15] level 8000001e, 0: 0x0000000f 0x00000107 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID Maximum Physical Address Bits supported across all CPUs: 48
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x3a = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x480 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x481 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x482 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x483 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x484 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x485 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x486 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x487 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x488 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x489 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48a = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48b = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48c = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48d = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48e = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48f = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x490 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x491 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0xc0010114 = 0x18
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0xce = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: VMMon_GetkHzEstimate: Calculated 3393624 kHz
2017-08-30T11:26:36.656+02:00| vmx| I125: HOSTINFO: Host supports constant rate TSC.
2017-08-30T11:26:36.656+02:00| vmx| I125: TSC kHz estimates: vmmon 3393624, remembered 0, osReported 3400000. Using 3400000 kHz.
2017-08-30T11:26:36.656+02:00| vmx| I125: TSC first measured delta 884
2017-08-30T11:26:36.656+02:00| vmx| I125: TSC min delta 884
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: RefClockToPTSC 0 @ 14318180Hz -> 0 @ 3400000000Hz
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: RefClockToPTSC ((x * 3983923543) >> 24) + -12972649701295
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: tscOffset -13011554950100
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: using TSC
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: hardware TSCs are synchronized.
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: hardware TSCs may have been adjusted by the host.
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: current PTSC=59313379234640
2017-08-30T11:26:36.656+02:00| vmx| I125: WQPoolAllocPoll : pollIx = 3, signalHandle = 876
2017-08-30T11:26:36.703+02:00| vmx| I125: ConfigCheck: No rules file found. Checks are disabled.
2017-08-30T11:26:36.703+02:00| vmx| I125: changing directory to C:Users ipogDocumentsVirtual MachinesWindows XP Professional.
2017-08-30T11:26:36.703+02:00| vmx| I125: Config file: C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmx
2017-08-30T11:26:36.703+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2017-08-30T11:26:36.703+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=2, newAppState=1878, success=1 additionalError=0
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipog): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppData): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocal): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocalTemp): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocalTempvmware-tipog): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.735+02:00| vmx| A100: ConfigDB: Setting ide1:0.fileName = "auto detect"
2017-08-30T11:26:36.813+02:00| vmx| I125: VMXVmdbCbVmVmxExecState: Exec state change requested to state poweredOn without reset, soft, softOptionTimeout: 0.
2017-08-30T11:26:36.813+02:00| vmx| I125: Tools: sending 'OS_PowerOn' (state = 3) state change request
2017-08-30T11:26:36.813+02:00| vmx| I125: Tools: Delaying state change request to state 3.
2017-08-30T11:26:36.813+02:00| vmx| W115: PowerOn
2017-08-30T11:26:36.813+02:00| vmx| I125: VMX_PowerOn: VMX build 5813279, UI build 5813279
2017-08-30T11:26:36.813+02:00| vmx| I125: HostWin32: WIN32 NUMA node 0, CPU mask 0x000000000000ffff
2017-08-30T11:26:36.828+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1871, success=1 additionalError=0
2017-08-30T11:26:36.828+02:00| vmx| I125: HOST Windows version 10.0, build 15063, platform 2, "", SMP
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- GLOBAL SETTINGS C:ProgramDataVMwareVMware Workstationsettings.ini
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT printers.enabled = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- NON PERSISTENT
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- USER PREFERENCES C:UsersDefaultAppDataRoamingVMwarepreferences.ini
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- USER DEFAULTS C:UsersDefaultAppDataRoamingVMwareconfig.ini
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- HOST DEFAULTS C:ProgramDataVMwareVMware Workstationconfig.ini
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT authd.client.port = "903"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT authd.proxy.nfc = "vmware-hostd:ha-nfc"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT installerDefaults.autoSoftwareUpdateEnabled = "yes"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT installerDefaults.autoSoftwareUpdateEnabled.epoch = "19778"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT installerDefaults.componentDownloadEnabled = "yes"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT installerDefaults.dataCollectionEnabled = "no"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT installerDefaults.dataCollectionEnabled.epoch = "19778"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT smc.version = "0"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- SITE DEFAULTS C:ProgramDataVMwareVMware Workstationconfig.ini
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- NONPERSISTENT
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmx.stdio.keep = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT gui.available = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- COMMAND LINE
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- RECORDING
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- CONFIGURATION C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmx
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT config.version = "8"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT virtualHW.version = "11"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT scsi0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT memsize = "2000"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide0:0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide0:0.fileName = "Windows XP Professional.vmdk"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide1:0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide1:0.fileName = "auto detect"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide1:0.deviceType = "cdrom-raw"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.connectionType = "nat"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.wakeOnPcktRcv = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.addressType = "generated"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ehci.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ehci.pciSlotNumber = "35"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT sound.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT sound.fileName = "-1"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT sound.autodetect = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT mks.enable3d = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.graphicsMemoryKB = "524288"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT serial0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT serial0.fileType = "thinprint"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge4.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge4.virtualDev = "pcieRootPort"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge4.functions = "8"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge5.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge5.virtualDev = "pcieRootPort"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge5.functions = "8"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge6.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge6.virtualDev = "pcieRootPort"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge6.functions = "8"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge7.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge7.virtualDev = "pcieRootPort"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge7.functions = "8"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmci0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT hpet0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb.vbluetooth.startConnected = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT buslogic.noDriver = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT displayName = "Windows XP Professional"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT guestOS = "winxppro"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT nvram = "Windows XP Professional.nvram"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT virtualHW.productCompatibility = "hosted"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT gui.exitOnCLIHLT = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT powerType.powerOff = "soft"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT powerType.powerOn = "soft"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT powerType.suspend = "soft"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT powerType.reset = "soft"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT extendedConfigFile = "Windows XP Professional.vmxf"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT uuid.bios = "56 4d 63 35 46 0d cd a6-08 ad 14 74 37 47 80 ab"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT uuid.location = "56 4d 63 35 46 0d cd a6-08 ad 14 74 37 47 80 ab"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT replay.supported = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT replay.filename = ""
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT migrate.hostlog = ".Windows XP Professional-7eefab4f.hlog"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide0:0.redo = ""
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge0.pciSlotNumber = "17"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge4.pciSlotNumber = "21"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge5.pciSlotNumber = "22"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge6.pciSlotNumber = "23"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge7.pciSlotNumber = "24"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT scsi0.pciSlotNumber = "16"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb.pciSlotNumber = "32"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.pciSlotNumber = "33"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT sound.pciSlotNumber = "34"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmci0.pciSlotNumber = "36"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.generatedAddress = "00:0c:29:47:80:ab"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.generatedAddressOffset = "0"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmci0.id = "2044499865"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT monitor.phys_bits_used = "42"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmotion.checkpointFBSize = "4194304"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmotion.checkpointSVGAPrimarySize = "33554432"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT cleanShutdown = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT softPowerOff = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:1.speed = "2"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:1.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:1.deviceType = "hub"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:1.port = "1"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:1.parent = "-1"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide1:0.autodetect = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.guestBackedPrimaryAware = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT tools.syncTime = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb.autoConnect.device0 = ""
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT tools.remindInstall = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT toolsInstallManager.updateCounter = "7"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT checkpoint.vmState = ""
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide1:0.startConnected = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.autodetect = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.vramSize = "5242880"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT numvcpus = "4"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.maxWidth = "1280"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.maxHeight = "1024"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT sound.startConnected = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT numa.autosize.vcpu.maxPerVirtualNode = "4"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT numa.autosize.cookie = "40001"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT toolsInstallManager.lastInstallError = "0"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT cpuid.coresPerSocket = "2"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb.autoConnect.device1 = ""
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:0.deviceType = "hid"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:0.port = "0"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:0.parent = "-1"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT monitor.virtual_mmu = "automatic"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT monitor.virtual_exec = "automatic"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb_xhci.present = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT floppy0.present = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: ToolsISO: open of C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig failed: Could not find the file
2017-08-30T11:26:36.828+02:00| vmx| I125: ToolsISO: Unable to read signature file 'C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig', ignoring.
2017-08-30T11:26:36.828+02:00| vmx| I125: ToolsISO: Selected Tools ISO 'winPreVista.iso' for 'winxppro' guest.
2017-08-30T11:26:36.828+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2017-08-30T11:26:36.860+02:00| vmx| I125: Host AMD-V Capabilities:
2017-08-30T11:26:36.860+02:00| vmx| I125: SVM Revision: 1
2017-08-30T11:26:36.860+02:00| vmx| I125: ASIDs Supported: 32768
2017-08-30T11:26:36.860+02:00| vmx| I125: Nested Paging: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: LBR Virtualization: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: SVM Lock: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: NRIP Save: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: TSC Rate MSR: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: VMCB Clean Bits: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: Flush by ASID: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: Decode Assists: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: Pause Filter: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: Pause Filter Threshold: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: Family 10H or greater CPU(s) required for AMD-V support in VMware Workstation; however, this host has family 17H CPU(s).
2017-08-30T11:26:36.860+02:00| vmx| I125: hostCpuFeatures = 0x347f
2017-08-30T11:26:36.860+02:00| vmx| I125: hostNumGenPerfCounters = 0
2017-08-30T11:26:36.860+02:00| vmx| I125: hostNumFixedPerfCounters = 0
2017-08-30T11:26:36.860+02:00| vmx| I125: hostPerfCtrArch = 0
2017-08-30T11:26:36.860+02:00| vmx| I125: MONITOR MODE: allowed modes : BT
2017-08-30T11:26:36.860+02:00| vmx| I125: MONITOR MODE: user requested modes : BT HV HWMMU
2017-08-30T11:26:36.860+02:00| vmx| I125: MONITOR MODE: guestOS preferred modes: HWMMU HV BT
2017-08-30T11:26:36.860+02:00| vmx| I125: MONITOR MODE: filtered list : BT
2017-08-30T11:26:36.860+02:00| vmx| I125: HV Settings: virtual exec = 'software'; virtual mmu = 'software'
2017-08-30T11:26:36.860+02:00| vmx| W115: Unknown Guest OS. Ensure sufficient memory provisioning if ballooning is enabled.
2017-08-30T11:26:36.860+02:00| vmx| I125: OvhdMem_PowerOn: initial admission: paged 221498 nonpaged 4145 anonymous 26229
2017-08-30T11:26:36.860+02:00| vmx| I125: VMMEM: Initial Reservation: 983MB (MainMem=2000MB)
2017-08-30T11:26:36.860+02:00| vmx| I125: MemSched_PowerOn: balloon minGuestSize 0 (80% of min required size 0)
2017-08-30T11:26:36.860+02:00| vmx| I125: MemSched: reserved mem (in MB) min 128 max 28616 recommended 28616
2017-08-30T11:26:36.860+02:00| vmx| I125: MemSched: pg 221498 np 4145 anon 26229 mem 512000
2017-08-30T11:26:36.906+02:00| vmx| I125: MemSched: numvm 1 locked pages: num 0 max 7264772
2017-08-30T11:26:36.906+02:00| vmx| I125: MemSched: locked Page Limit: host 8078434 config 7325696 dynam 7272964
2017-08-30T11:26:36.906+02:00| vmx| I125: MemSched: minmempct 50 minalloc 0 admitted 1
2017-08-30T11:26:36.922+02:00| vmx| I125: hread 10248 6160VTHREAD start thread 8 "WinNotifyThread" host id 10248
2017-08-30T11:26:36.922+02:00| WinNotifyThread| I125: WinNotify thread is alive
2017-08-30T11:26:36.922+02:00| vmx| I125: LICENSE using: 'HKEY_LOCAL_MACHINESOFTWAREVMware, Inc.VMware WorkstationDormantLicense.ws.12.0.e2.201505'
2017-08-30T11:26:36.922+02:00| vmx| I125: hread 15444 6160VTHREAD start thread 9 "vthread-9" host id 15444
2017-08-30T11:26:36.922+02:00| vmx| I125: PolicyVMXFindPolicyKey: policy file does not exist.
2017-08-30T11:26:36.922+02:00| vmx| I125: ToolsISO: open of C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig failed: Could not find the file
2017-08-30T11:26:36.922+02:00| vmx| I125: ToolsISO: Unable to read signature file 'C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig', ignoring.
2017-08-30T11:26:36.922+02:00| vmx| I125: ToolsISO: Selected Tools ISO 'winPreVista.iso' for 'winxppro' guest.
2017-08-30T11:26:36.922+02:00| vmx| I125: Host IPI vectors: 0x2f 0. Monitor IPI vector: 0, HV IPI vector: 0
2017-08-30T11:26:36.922+02:00| vmx| I125: Monitor_PowerOn: hostedVSMPMaxSkew is 1500 us (5100000 cycles)
2017-08-30T11:26:36.922+02:00| vmx| I125: Monitor64_PowerOn()
2017-08-30T11:26:36.922+02:00| vmx| I125: Loaded worldswitch: .wsBody64. Size = 480.
2017-08-30T11:26:36.922+02:00| vmx| I125: Successfully loaded worldswitch fault handlers from .switchNMI. Size = 208.
2017-08-30T11:26:36.922+02:00| vmx| I125: vmm64-modules: [vmm.vmm64, mmu-nohv.vmm64, vprobe-none.vmm64, hv-none.vmm64, gphys-sw.vmm64, callstack-none.vmm64, vmce-none.vmm64, vvtd-none.vmm64, guestIntegrity-none.vmm64, buslogic-buslogic.vmm64, {SharedAreaReservations} .shared_per_vm_vmx:0x40, {SharedInterVcpuVmxSection}, {SharedInterVcpuSection}, , busLogicShared=0xfffffffffc0c6000, {UseUnwind}=0x0, hvLoadedAsAddr=0x0, useNPTAsAddr=0x0, numVCPUsAsAddr=0x4, busmemFrameSizeLog2AsAddr=0x4, busmemFrameSizeAsAddr=0x10, {rodataSize}=0x1b09c, {textAddr}=0xfffffffffc41c000, {textSize}=0x93473]
2017-08-30T11:26:36.922+02:00| vmx| I125: vmm64-vcpus: 4
2017-08-30T11:26:36.938+02:00| vmx| I125: KHZEstimate 3400000
2017-08-30T11:26:36.938+02:00| vmx| I125: MHZEstimate 3400
2017-08-30T11:26:36.938+02:00| vmx| I125: NumVCPUs 4
2017-08-30T11:26:36.938+02:00| vmx| I125: Guest OS (20488) not supported for replay debugging.
2017-08-30T11:26:36.938+02:00| vmx| I125: MonTimer: host does not have high resolution timers.
2017-08-30T11:26:36.938+02:00| vmx| I125: UUID: location-UUID is 56 4d 73 72 30 05 8a 20-0d ea 48 af 80 b6 87 e9
2017-08-30T11:26:36.938+02:00| vmx| I125: UUID: location-UUID is 56 4d 63 35 46 0d cd a6-08 ad 14 74 37 47 80 ab
2017-08-30T11:26:36.938+02:00| vmx| I125: AIOGNRC: numThreads=4 ide=1, scsi=0, passthru=1
2017-08-30T11:26:36.938+02:00| vmx| I125: WORKER: Creating new group with numThreads=4 (4)
2017-08-30T11:26:36.938+02:00| vmx| I125: WORKER: Creating new group with numThreads=1 (5)
2017-08-30T11:26:36.938+02:00| vmx| I125: MainMem: CPT Host WZ=0 PF=2000 D=0
2017-08-30T11:26:36.938+02:00| vmx| I125: MainMem: CPT PLS=1 PLR=1 BS=1 BlkP=32 Mult=4 W=50
2017-08-30T11:26:36.953+02:00| vmx| I125: Hostinfo_OpenProcessBits: OpenProcess access bits are 1000.
2017-08-30T11:26:36.953+02:00| vmx| I125: FILE: FileLockScanDirectory discarding M16434.lck from C:Users ipogDocumentsVirtual MachinesWindows XP Professional564d6335-460d-cda6-08ad-1474374780ab.vmem.lck': invalid executionID 5164-131484699338746354(vmware-vmx.exe).
2017-08-30T11:26:37.063+02:00| vmx| I125: MainMem: Opened paging file, 'C:Users ipogDocumentsVirtual MachinesWindows XP Professional564d6335-460d-cda6-08ad-1474374780ab.vmem'.
2017-08-30T11:26:37.063+02:00| vmx| I125: MStat: Creating Stat vm.uptime
2017-08-30T11:26:37.063+02:00| vmx| I125: MStat: Creating Stat vm.suspendTime
2017-08-30T11:26:37.063+02:00| vmx| I125: MStat: Creating Stat vm.powerOnTimeStamp
2017-08-30T11:26:37.063+02:00| vmx| I125: hread 11500 6160VMXAIOMGR: Using: simple=Generic unbuf=Compl
2017-08-30T11:26:37.063+02:00| aioCompletion| I125: VTHREAD start thread 10 "aioCompletion" host id 11500
2017-08-30T11:26:37.078+02:00| vmx| I125: WORKER: Creating new group with numThreads=1 (6)
2017-08-30T11:26:37.078+02:00| vmx| I125: WORKER: Creating new group with numThreads=16 (22)
2017-08-30T11:26:37.078+02:00| vmx| I125: MigrateResetStaleVMDBHostLog: Hostlog .Windows XP Professional-7eefab4f.hlog doesn't exist.
2017-08-30T11:26:37.078+02:00| vmx| I125: MigrateBusMemPrealloc: BusMem preallocation begins.
2017-08-30T11:26:37.078+02:00| vmx| I125: MigrateBusMemPrealloc: BusMem preallocation completes.
2017-08-30T11:26:37.078+02:00| vmx| I125: TimeTracker host to guest rate conversion 59314797440328 @ 3400000000Hz -> 0 @ 3400000000Hz
2017-08-30T11:26:37.078+02:00| vmx| I125: TimeTracker host to guest rate conversion ((x * 2147483648) >> 31) + -59314797440328
2017-08-30T11:26:37.078+02:00| vmx| I125: Disabling TSC scaling since host does not support it.
2017-08-30T11:26:37.078+02:00| vmx| I125: TSC offsetting enabled.
2017-08-30T11:26:37.078+02:00| vmx| I125: timeTracker.globalProgressMaxAllowanceMS: 2000
2017-08-30T11:26:37.078+02:00| vmx| I125: timeTracker.globalProgressToAllowanceNS: 1000
2017-08-30T11:26:37.078+02:00| vmx| A100: ConfigDB: Setting ide0:0.redo = ""
2017-08-30T11:26:37.078+02:00| vmx| I125: DISK: OPEN ide0:0 'C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk' persistent R[]
2017-08-30T11:26:37.094+02:00| vmx| I125: FILE: FileLockScanDirectory discarding M45553.lck from C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk.lck': invalid executionID 5164-131484699338746354(vmware-vmx.exe).
2017-08-30T11:26:37.094+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [0]: "Windows XP Professional-s001.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [1]: "Windows XP Professional-s002.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [2]: "Windows XP Professional-s003.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [3]: "Windows XP Professional-s004.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [4]: "Windows XP Professional-s005.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [5]: "Windows XP Professional-s006.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [6]: "Windows XP Professional-s007.vmdk" (0xa)
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [7]: "Windows XP Professional-s008.vmdk" (0xa)
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [8]: "Windows XP Professional-s009.vmdk" (0xa)
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [9]: "Windows XP Professional-s010.vmdk" (0xa)
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [10]: "Windows XP Professional-s011.vmdk" (0xa)
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-LINK : Opened 'C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk' (0xa): twoGbMaxExtentSparse, 83886080 sectors / 40 GB.
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-LIB : Opened "C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk" (flags 0xa, type twoGbMaxExtentSparse).
2017-08-30T11:26:37.125+02:00| vmx| I125: DiskGetGeometry: Reading of disk partition table
2017-08-30T11:26:37.125+02:00| vmx| I125: DISK: Disk 'C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk' has UUID '60 00 c2 97 38 29 05 70-57 96 8c 57 41 11 82 85'
2017-08-30T11:26:37.125+02:00| vmx| I125: DISK: OPEN 'C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk' Geo (83220/16/63) BIOS Geo (5221/255/63)
2017-08-30T11:26:37.141+02:00| vmx| I125: DISKUTILWIN32: DiskUtilW32IsATASSDDevice: Reported rotation rate = 1
2017-08-30T11:26:37.157+02:00| vmx| I125: DISKUTILWIN32: DiskUtilW32IsATASSDDevice: Reported rotation rate = 1
2017-08-30T11:26:37.172+02:00| vmx| I125: DISKUTILWIN32: DiskUtilW32IsATASSDDevice: Reported rotation rate = 1
2017-08-30T11:26:37.172+02:00| vmx| I125: DISK: DiskConfigureVirtualSSD: Disk 'ide0:0' identified as Virtual SSD device.
2017-08-30T11:26:37.172+02:00| vmx| I125: DISK: Opening disks took 95 ms.
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Virtual Hub' backend
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Generic' backend
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Virtual HID' backend
2017-08-30T11:26:37.172+02:00| vmx| I125: hread 6924 6160VTHREAD start thread 11 "sensorThread" host id 6924
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Remote Device' backend
2017-08-30T11:26:37.172+02:00| vmx| I125: RemoteUSBVMX: Retrieved hostId [96 6b e4 4b ef 4b 2a b9-dd 49 88 d7 f6 e2 3a d9]
2017-08-30T11:26:37.172+02:00| vmx| I125: RemoteUSBVMX: Protocol version min:15 current:16
2017-08-30T11:26:37.172+02:00| vmx| I125: RemoteUSBVMX: no delay setting is TRUE.
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Virtual Mass Storage' backend
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Virtual CCID' backend
2017-08-30T11:26:37.188+02:00| vmx| I125: hread 9944 6160USB: Initializing 'Virtual Bluetooth' backend
2017-08-30T11:26:37.188+02:00| vmx| I125: USB: Initializing 'Virtual Audio' backend
2017-08-30T11:26:37.188+02:00| vmx| I125: USB: Initializing 'Virtual Video' backend
2017-08-30T11:26:37.188+02:00| usbCCIDEnumCards| I125: VTHREAD start thread 12 "usbCCIDEnumCards" host id 9944
2017-08-30T11:26:37.188+02:00| usbCCIDEnumCards| I125: USB-CCID: Card enum thread created.
2017-08-30T11:26:37.188+02:00| vmx| I125: USBGW: Skipping disk backing for file (C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmx).
2017-08-30T11:26:37.188+02:00| vmx| I125: USBGW: Skipping disk backing for file (C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk).
2017-08-30T11:26:37.203+02:00| vmx| I125: USBGW: Skipping disk backing for file (C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmsd).
2017-08-30T11:26:37.203+02:00| vmx| I125: USBGW: Skipping disk backing for file (C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.nvram).
2017-08-30T11:26:37.203+02:00| vmx| I125: MKS PowerOn
2017-08-30T11:26:37.203+02:00| vmx| I125: hread 6940 6160VTHREAD start thread 2 "mks" host id 6940
2017-08-30T11:26:37.203+02:00| mks| I125: MKS thread is alive
2017-08-30T11:26:37.203+02:00| mks| I125: SOUNDLIB: Creating the Wave sound backend.
2017-08-30T11:26:37.203+02:00| mks| I125: hread 11612 6160VTHREAD start thread 13 "mouse" host id 11612
2017-08-30T11:26:37.203+02:00| mks| I125: hread 13316 6160VTHREAD start thread 14 "kbh" host id 13316
2017-08-30T11:26:37.203+02:00| mks| I125: MKS Win32: Registering top level window (0x1a02d6) to receive session change notification.
2017-08-30T11:26:37.203+02:00| mks| I125: MKS-RenderMain: RenderMain: PowerOn allowed MKSBasicOps
2017-08-30T11:26:37.203+02:00| mks| I125: MKS-RenderMain: Starting MKSBasicOps
2017-08-30T11:26:37.203+02:00| mks| I125: KHBKL: Unable to parse keystring at: ''
2017-08-30T11:26:37.203+02:00| mks| I125: MKS-RemoteMgr: Set default display name: Windows XP Professional
2017-08-30T11:26:37.203+02:00| mks| I125: MKS-RemoteMgr: Loading VNC Configuration from VM config file
2017-08-30T11:26:37.203+02:00| mks| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:ProgramDataVMware): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:37.203+02:00| vmx| I125: VLANCE: send cluster threshold is 80, size = 2 recalcInterval is 2 ticks
2017-08-30T11:26:37.203+02:00| vmx| I125: VMXNET: send cluster threshold is 80, size = 2 recalcInterval is 2 ticks, dontClusterSize is 128
2017-08-30T11:26:37.203+02:00| vmx| I125: Chipset version: 0x13
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge4.pciSlotNumber = "-1"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge5.pciSlotNumber = "-1"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge6.pciSlotNumber = "-1"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge7.pciSlotNumber = "-1"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge4.pciSlotNumber = "21"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge5.pciSlotNumber = "22"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge6.pciSlotNumber = "23"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge7.pciSlotNumber = "24"
2017-08-30T11:26:37.203+02:00| vmx| I125: FILE: FileDeletionRetry: Non-retriable error encountered (C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmx~): Unknown error 2 (0x2) (2)
2017-08-30T11:26:37.219+02:00| vmx| I125: DISKUTIL: ide0:0 : capacity=83886080 logical sector size=512
2017-08-30T11:26:37.219+02:00| vmx| I125: SCSI DEVICE (ide0:0): Computed value of ide0:0.useBounceBuffers: default
2017-08-30T11:26:37.219+02:00| vmx| I125: DISKUTIL: ide0:0 : geometry=5221/255/63
2017-08-30T11:26:37.219+02:00| vmx| I125: SCSI DEVICE (ide1:0): Computed value of ide1:0.useBounceBuffers: default
2017-08-30T11:26:37.219+02:00| vmx| I125: DISKUTIL: ide1:0 : capacity=0 logical sector size=2048
2017-08-30T11:26:37.219+02:00| vmx| I125: DISKUTIL: ide1:0 : geometry=0/0/0
2017-08-30T11:26:37.219+02:00| vmx| I125: SCSI0: UNTAGGED commands will be converted to ORDER tags.
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA: Maximum display topology 3840x1920.
2017-08-30T11:26:37.219+02:00| vmx| I125: Ignoring svga.vramSize value in config file because svga.autoDetect is enabled.
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA-GFB: Initial gfbSize=4194304
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA: Number of displays 2
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA: Truncated maximum resolution to VRAM size: 4194304 bytes VRAM, 1176x885 Max Resolution
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA: FIFO capabilities 0x0000077f
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA: Device capabilities 0x0dff83e2
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA3dCaps: host, at power on: 3d disabled
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 0]: 0x00000000 (3D)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 1]: 0x00000000 (MAX_LIGHTS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 2]: 0x00000000 (MAX_TEXTURES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 3]: 0x00000000 (MAX_CLIP_PLANES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 4]: 0x00000000 (VERTEX_SHADER_VERSION)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 5]: 0x00000000 (VERTEX_SHADER)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 6]: 0x00000000 (FRAGMENT_SHADER_VERSION)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 7]: 0x00000000 (FRAGMENT_SHADER)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 8]: 0x00000000 (MAX_RENDER_TARGETS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 9]: 0x00000000 (S23E8_TEXTURES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 10]: 0x00000000 (S10E5_TEXTURES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 11]: 0x00000000 (MAX_FIXED_VERTEXBLEND)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 12]: 0x00000000 (D16_BUFFER_FORMAT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 13]: 0x00000000 (D24S8_BUFFER_FORMAT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 14]: 0x00000000 (D24X8_BUFFER_FORMAT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 15]: 0x00000000 (QUERY_TYPES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 16]: 0x00000000 (TEXTURE_GRADIENT_SAMPLING)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 17]: 0.000000 (MAX_POINT_SIZE)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 18]: 0x00000000 (MAX_SHADER_TEXTURES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 19]: 0x00001000 (MAX_TEXTURE_WIDTH)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 20]: 0x00001000 (MAX_TEXTURE_HEIGHT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 21]: 0x00000000 (MAX_VOLUME_EXTENT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 22]: 0x00000000 (MAX_TEXTURE_REPEAT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 23]: 0x00000000 (MAX_TEXTURE_ASPECT_RATIO)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 24]: 0x00000000 (MAX_TEXTURE_ANISOTROPY)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 25]: 0x00000000 (MAX_PRIMITIVE_COUNT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 26]: 0x00000000 (MAX_VERTEX_INDEX)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 27]: 0x00000000 (MAX_VERTEX_SHADER_INSTRUCTIONS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 28]: 0x00000000 (MAX_FRAGMENT_SHADER_INSTRUCTIONS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 29]: 0x00000000 (MAX_VERTEX_SHADER_TEMPS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 30]: 0x00000000 (MAX_FRAGMENT_SHADER_TEMPS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 31]: 0x00000000 (TEXTURE_OPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 32]: 0x00000000 (SURFACEFMT_X8R8G8B8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 33]: 0x00000000 (SURFACEFMT_A8R8G8B8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 34]: 0x00000000 (SURFACEFMT_A2R10G10B10)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 35]: 0x00000000 (SURFACEFMT_X1R5G5B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 36]: 0x00000000 (SURFACEFMT_A1R5G5B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 37]: 0x00000000 (SURFACEFMT_A4R4G4B4)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 38]: 0x00000000 (SURFACEFMT_R5G6B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 39]: 0x00000000 (SURFACEFMT_LUMINANCE16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 40]: 0x00000000 (SURFACEFMT_LUMINANCE8_ALPHA8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 41]: 0x00000000 (SURFACEFMT_ALPHA8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 42]: 0x00000000 (SURFACEFMT_LUMINANCE8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 43]: 0x00000000 (SURFACEFMT_Z_D16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 44]: 0x00000000 (SURFACEFMT_Z_D24S8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 45]: 0x00000000 (SURFACEFMT_Z_D24X8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 46]: 0x00000000 (SURFACEFMT_DXT1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 47]: 0x00000000 (SURFACEFMT_DXT2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 48]: 0x00000000 (SURFACEFMT_DXT3)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 49]: 0x00000000 (SURFACEFMT_DXT4)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 50]: 0x00000000 (SURFACEFMT_DXT5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 51]: 0x00000000 (SURFACEFMT_BUMPX8L8V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 52]: 0x00000000 (SURFACEFMT_A2W10V10U10)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 53]: 0x00000000 (SURFACEFMT_BUMPU8V8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 54]: 0x00000000 (SURFACEFMT_Q8W8V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 55]: 0x00000000 (SURFACEFMT_CxV8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 56]: 0x00000000 (SURFACEFMT_R_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 57]: 0x00000000 (SURFACEFMT_R_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 58]: 0x00000000 (SURFACEFMT_RG_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 59]: 0x00000000 (SURFACEFMT_RG_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 60]: 0x00000000 (SURFACEFMT_ARGB_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 61]: 0x00000000 (SURFACEFMT_ARGB_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 62]: 0x00000000 (MISSING62)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 63]: 0x00000000 (MAX_VERTEX_SHADER_TEXTURES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 64]: 0x00000000 (MAX_SIMULTANEOUS_RENDER_TARGETS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 65]: 0x00000000 (SURFACEFMT_V16U16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 66]: 0x00000000 (SURFACEFMT_G16R16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 67]: 0x00000000 (SURFACEFMT_A16B16G16R16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 68]: 0x00000000 (SURFACEFMT_UYVY)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 69]: 0x00000000 (SURFACEFMT_YUY2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 70]: 0x00000000 (MULTISAMPLE_NONMASKABLESAMPLES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 71]: 0x00000000 (MULTISAMPLE_MASKABLESAMPLES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 72]: 0x00000000 (ALPHATOCOVERAGE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 73]: 0x00000000 (SUPERSAMPLE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 74]: 0x00000000 (AUTOGENMIPMAPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 75]: 0x00000000 (SURFACEFMT_NV12)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 76]: 0x00000000 (SURFACEFMT_AYUV)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 77]: 0x00000000 (MAX_CONTEXT_IDS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 78]: 0x00000000 (MAX_SURFACE_IDS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 79]: 0x00000000 (SURFACEFMT_Z_DF16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 80]: 0x00000000 (SURFACEFMT_Z_DF24)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 81]: 0x00000000 (SURFACEFMT_Z_D24S8_INT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 82]: 0x00000000 (SURFACEFMT_ATI1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 83]: 0x00000000 (SURFACEFMT_ATI2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 84]: 0x00000000 (DEAD1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 85]: 0x00000000 (VIDEO_DECODE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 86]: 0x00000000 (VIDEO_PROCESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 87]: 0x00000000 (LINE_AA)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 88]: 0x00000000 (LINE_STIPPLE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 89]: 0.000000 (MAX_LINE_WIDTH)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 90]: 0.000000 (MAX_AA_LINE_WIDTH)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 91]: 0x00000000 (SURFACEFMT_YV12)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 92]: 0x00000000 (LOGICOPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 93]: 0x00000001 (TS_COLOR_KEY)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 94]: 0x00000000 (DEAD2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 95]: 0x00000000 (DXCONTEXT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 96]: 0x00000000 (MAX_TEXTURE_ARRAY_SIZE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 97]: 0x00000000 (DX_MAX_VERTEXBUFFERS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 98]: 0x00000000 (DX_MAX_CONSTANT_BUFFERS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 99]: 0x00000000 (DX_PROVOKING_VERTEX)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[100]: 0x00000000 (DXFMT_X8R8G8B8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[101]: 0x00000000 (DXFMT_A8R8G8B8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[102]: 0x00000000 (DXFMT_R5G6B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[103]: 0x00000000 (DXFMT_X1R5G5B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[104]: 0x00000000 (DXFMT_A1R5G5B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[105]: 0x00000000 (DXFMT_A4R4G4B4)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[106]: 0x00000000 (DXFMT_Z_D32)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[107]: 0x00000000 (DXFMT_Z_D16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[108]: 0x00000000 (DXFMT_Z_D24S8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[109]: 0x00000000 (DXFMT_Z_D15S1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[110]: 0x00000000 (DXFMT_LUMINANCE8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[111]: 0x00000000 (DXFMT_LUMINANCE4_ALPHA4)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[112]: 0x00000000 (DXFMT_LUMINANCE16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[113]: 0x00000000 (DXFMT_LUMINANCE8_ALPHA8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[114]: 0x00000000 (DXFMT_DXT1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[115]: 0x00000000 (DXFMT_DXT2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[116]: 0x00000000 (DXFMT_DXT3)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[117]: 0x00000000 (DXFMT_DXT4)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[118]: 0x00000000 (DXFMT_DXT5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[119]: 0x00000000 (DXFMT_BUMPU8V8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[120]: 0x00000000 (DXFMT_BUMPL6V5U5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[121]: 0x00000000 (DXFMT_BUMPX8L8V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[122]: 0x00000000 (DXFMT_FORMAT_DEAD1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[123]: 0x00000000 (DXFMT_ARGB_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[124]: 0x00000000 (DXFMT_ARGB_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[125]: 0x00000000 (DXFMT_A2R10G10B10)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[126]: 0x00000000 (DXFMT_V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[127]: 0x00000000 (DXFMT_Q8W8V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[128]: 0x00000000 (DXFMT_CxV8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[129]: 0x00000000 (DXFMT_X8L8V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[130]: 0x00000000 (DXFMT_A2W10V10U10)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[131]: 0x00000000 (DXFMT_ALPHA8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[132]: 0x00000000 (DXFMT_R_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[133]: 0x00000000 (DXFMT_R_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[134]: 0x00000000 (DXFMT_RG_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[135]: 0x00000000 (DXFMT_RG_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[136]: 0x00000000 (DXFMT_BUFFER)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[137]: 0x00000000 (DXFMT_Z_D24X8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[138]: 0x00000000 (DXFMT_V16U16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[139]: 0x00000000 (DXFMT_G16R16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[140]: 0x00000000 (DXFMT_A16B16G16R16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[141]: 0x00000000 (DXFMT_UYVY)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[142]: 0x00000000 (DXFMT_YUY2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[143]: 0x00000000 (DXFMT_NV12)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[144]: 0x00000000 (DXFMT_AYUV)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[145]: 0x00000000 (DXFMT_R32G32B32A32_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[146]: 0x00000000 (DXFMT_R32G32B32A32_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[147]: 0x00000000 (DXFMT_R32G32B32A32_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[148]: 0x00000000 (DXFMT_R32G32B32_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[149]: 0x00000000 (DXFMT_R32G32B32_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[150]: 0x00000000 (DXFMT_R32G32B32_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[151]: 0x00000000 (DXFMT_R32G32B32_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[152]: 0x00000000 (DXFMT_R16G16B16A16_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[153]: 0x00000000 (DXFMT_R16G16B16A16_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[154]: 0x00000000 (DXFMT_R16G16B16A16_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[155]: 0x00000000 (DXFMT_R16G16B16A16_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[156]: 0x00000000 (DXFMT_R32G32_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[157]: 0x00000000 (DXFMT_R32G32_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[158]: 0x00000000 (DXFMT_R32G32_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[159]: 0x00000000 (DXFMT_R32G8X24_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[160]: 0x00000000 (DXFMT_D32_FLOAT_S8X24_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[161]: 0x00000000 (DXFMT_R32_FLOAT_X8X24_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[162]: 0x00000000 (DXFMT_X32_TYPELESS_G8X24_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[163]: 0x00000000 (DXFMT_R10G10B10A2_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[164]: 0x00000000 (DXFMT_R10G10B10A2_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[165]: 0x00000000 (DXFMT_R11G11B10_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[166]: 0x00000000 (DXFMT_R8G8B8A8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[167]: 0x00000000 (DXFMT_R8G8B8A8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[168]: 0x00000000 (DXFMT_R8G8B8A8_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[169]: 0x00000000 (DXFMT_R8G8B8A8_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[170]: 0x00000000 (DXFMT_R8G8B8A8_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[171]: 0x00000000 (DXFMT_R16G16_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[172]: 0x00000000 (DXFMT_R16G16_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[173]: 0x00000000 (DXFMT_R16G16_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[174]: 0x00000000 (DXFMT_R32_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[175]: 0x00000000 (DXFMT_D32_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[176]: 0x00000000 (DXFMT_R32_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[177]: 0x00000000 (DXFMT_R32_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[178]: 0x00000000 (DXFMT_R24G8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[179]: 0x00000000 (DXFMT_D24_UNORM_S8_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[180]: 0x00000000 (DXFMT_R24_UNORM_X8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[181]: 0x00000000 (DXFMT_X24_TYPELESS_G8_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[182]: 0x00000000 (DXFMT_R8G8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[183]: 0x00000000 (DXFMT_R8G8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[184]: 0x00000000 (DXFMT_R8G8_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[185]: 0x00000000 (DXFMT_R8G8_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[186]: 0x00000000 (DXFMT_R16_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[187]: 0x00000000 (DXFMT_R16_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[188]: 0x00000000 (DXFMT_R16_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[189]: 0x00000000 (DXFMT_R16_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[190]: 0x00000000 (DXFMT_R16_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[191]: 0x00000000 (DXFMT_R8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[192]: 0x00000000 (DXFMT_R8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[193]: 0x00000000 (DXFMT_R8_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[194]: 0x00000000 (DXFMT_R8_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[195]: 0x00000000 (DXFMT_R8_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[196]: 0x00000000 (DXFMT_P8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[197]: 0x00000000 (DXFMT_R9G9B9E5_SHAREDEXP)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[198]: 0x00000000 (DXFMT_R8G8_B8G8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[199]: 0x00000000 (DXFMT_G8R8_G8B8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[200]: 0x00000000 (DXFMT_BC1_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[201]: 0x00000000 (DXFMT_BC1_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[202]: 0x00000000 (DXFMT_BC2_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[203]: 0x00000000 (DXFMT_BC2_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[204]: 0x00000000 (DXFMT_BC3_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[205]: 0x00000000 (DXFMT_BC3_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[206]: 0x00000000 (DXFMT_BC4_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[207]: 0x00000000 (DXFMT_ATI1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[208]: 0x00000000 (DXFMT_BC4_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[209]: 0x00000000 (DXFMT_BC5_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[210]: 0x00000000 (DXFMT_ATI2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[211]: 0x00000000 (DXFMT_BC5_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[212]: 0x00000000 (DXFMT_R10G10B10_XR_BIAS_A2_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[213]: 0x00000000 (DXFMT_B8G8R8A8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[214]: 0x00000000 (DXFMT_B8G8R8A8_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[215]: 0x00000000 (DXFMT_B8G8R8X8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[216]: 0x00000000 (DXFMT_B8G8R8X8_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[217]: 0x00000000 (DXFMT_Z_DF16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[218]: 0x00000000 (DXFMT_Z_DF24)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[219]: 0x00000000 (DXFMT_Z_D24S8_INT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[220]: 0x00000000 (DXFMT_YV12)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[221]: 0x00000000 (DXFMT_R32G32B32A32_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[222]: 0x00000000 (DXFMT_R16G16B16A16_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[223]: 0x00000000 (DXFMT_R16G16B16A16_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[224]: 0x00000000 (DXFMT_R32G32_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[225]: 0x00000000 (DXFMT_R10G10B10A2_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[226]: 0x00000000 (DXFMT_R8G8B8A8_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[227]: 0x00000000 (DXFMT_R16G16_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[228]: 0x00000000 (DXFMT_R16G16_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[229]: 0x00000000 (DXFMT_R16G16_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[230]: 0x00000000 (DXFMT_R32_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[231]: 0x00000000 (DXFMT_R8G8_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[232]: 0x00000000 (DXFMT_R16_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[233]: 0x00000000 (DXFMT_D16_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[234]: 0x00000000 (DXFMT_A8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[235]: 0x00000000 (DXFMT_BC1_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[236]: 0x00000000 (DXFMT_BC2_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[237]: 0x00000000 (DXFMT_BC3_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[238]: 0x00000000 (DXFMT_B5G6R5_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[239]: 0x00000000 (DXFMT_B5G5R5A1_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[240]: 0x00000000 (DXFMT_B8G8R8A8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[241]: 0x00000000 (DXFMT_B8G8R8X8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[242]: 0x00000000 (DXFMT_BC4_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[243]: 0x00000000 (DXFMT_BC5_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: SVGA3dCaps: guest, compatibility level: No-Clamping
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 0]: 0x00000000 (3D)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 1]: 0x00000000 (MAX_LIGHTS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 2]: 0x00000000 (MAX_TEXTURES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 3]: 0x00000000 (MAX_CLIP_PLANES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 4]: 0x00000000 (VERTEX_SHADER_VERSION)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 5]: 0x00000000 (VERTEX_SHADER)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 6]: 0x00000000 (FRAGMENT_SHADER_VERSION)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 7]: 0x00000000 (FRAGMENT_SHADER)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 8]: 0x00000000 (MAX_RENDER_TARGETS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 9]: 0x00000000 (S23E8_TEXTURES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 10]: 0x00000000 (S10E5_TEXTURES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 11]: 0x00000000 (MAX_FIXED_VERTEXBLEND)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 12]: 0x00000000 (D16_BUFFER_FORMAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 13]: 0x00000000 (D24S8_BUFFER_FORMAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 14]: 0x00000000 (D24X8_BUFFER_FORMAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 15]: 0x00000000 (QUERY_TYPES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 16]: 0x00000000 (TEXTURE_GRADIENT_SAMPLING)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 17]: 0.000000 (MAX_POINT_SIZE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 18]: 0x00000000 (MAX_SHADER_TEXTURES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 19]: 0x00001000 (MAX_TEXTURE_WIDTH)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 20]: 0x00001000 (MAX_TEXTURE_HEIGHT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 21]: 0x00000000 (MAX_VOLUME_EXTENT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 22]: 0x00000000 (MAX_TEXTURE_REPEAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 23]: 0x00000000 (MAX_TEXTURE_ASPECT_RATIO)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 24]: 0x00000000 (MAX_TEXTURE_ANISOTROPY)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 25]: 0x00000000 (MAX_PRIMITIVE_COUNT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 26]: 0x00000000 (MAX_VERTEX_INDEX)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 27]: 0x00000000 (MAX_VERTEX_SHADER_INSTRUCTIONS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 28]: 0x00000000 (MAX_FRAGMENT_SHADER_INSTRUCTIONS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 29]: 0x00000000 (MAX_VERTEX_SHADER_TEMPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 30]: 0x00000000 (MAX_FRAGMENT_SHADER_TEMPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 31]: 0x00000000 (TEXTURE_OPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 93]: 0x00000000 (TS_COLOR_KEY)
2017-08-30T11:26:37.235+02:00| vmx| I125: hread 17448 6160USB: Initializing 'UHCI' host controller
2017-08-30T11:26:37.235+02:00| svga| I125: VTHREAD start thread 1 "svga" host id 17448
2017-08-30T11:26:37.235+02:00| vmx| A100: ConfigDB: Setting usb:0.present = "TRUE"
2017-08-30T11:26:37.235+02:00| vmx| A100: ConfigDB: Setting usb:0.deviceType = "hid"
2017-08-30T11:26:37.235+02:00| vmx| A100: ConfigDB: Setting usb:0.port = "0"
2017-08-30T11:26:37.235+02:00| vmx| A100: ConfigDB: Setting usb:0.parent = "-1"
2017-08-30T11:26:37.250+02:00| vmx| A100: ConfigDB: Setting usb:1.speed = "2"
2017-08-30T11:26:37.250+02:00| vmx| I125: Ethernet0 MAC Address: 00:0c:29:47:80:ab
2017-08-30T11:26:37.250+02:00| vmx| I125: USB: Initializing 'EHCI' host controller
2017-08-30T11:26:37.250+02:00| vmx| A100: ConfigDB: Setting vmci0.id = "2044499865"
2017-08-30T11:26:37.250+02:00| vmx| I125: WORKER: Creating new group with numThreads=1 (23)
2017-08-30T11:26:37.250+02:00| vmx| I125: DISKUTIL: ide0:0 : max toolsVersion = 10252, type = 1
2017-08-30T11:26:37.250+02:00| vmx| I125: TOOLS setting legacy tools version to '10252' type 1, manifest status is 9
2017-08-30T11:26:37.250+02:00| vmx| I125: TOOLS INSTALL initializing state to IDLE on power on.
2017-08-30T11:26:37.250+02:00| Worker#0| I125: ToolsISO: open of C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig failed: Could not find the file
2017-08-30T11:26:37.250+02:00| Worker#0| I125: ToolsISO: Unable to read signature file 'C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig', ignoring.
2017-08-30T11:26:37.266+02:00| Worker#0| I125: ToolsISO: Selected Tools ISO 'winPreVista.iso' for 'winxppro' guest.
2017-08-30T11:26:37.266+02:00| Worker#0| I125: GetHostManifests: Extracting the manifest file.
2017-08-30T11:26:37.266+02:00| vmx| I125: FeatureCompat: No VM masks.
2017-08-30T11:26:37.266+02:00| vmx| I125: MonPmc: ctrBase 0xc0010004 selBase 0xc0010000/1 PGC 0/0 SMM 0 drain 0 AMD 1
2017-08-30T11:26:37.266+02:00| vmx| I125+ MonPmc: gen counters num: 0 width 48 write width 48
2017-08-30T11:26:37.266+02:00| vmx| I125+ MonPmc: fix counters num: 0 width 0
2017-08-30T11:26:37.266+02:00| vmx| I125+ MonPmc: unavailable counters: 0
2017-08-30T11:26:37.266+02:00| Worker#0| I125: GetHostManifests: Done extracting the manifest file.
2017-08-30T11:26:37.266+02:00| Worker#0| I125: ToolsVersionGetStatusWorkerThread: Tools status 3 derived from environment
2017-08-30T11:26:37.266+02:00| vmx| I125: guestCpuFeatures = 0x307f
2017-08-30T11:26:37.266+02:00| vmx| A100: ConfigDB: Setting monitor.phys_bits_used = "42"
2017-08-30T11:26:37.266+02:00| vmx| I125: Full guest CPUID with differences from hostCPUID highlighted.
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest vendor: AuthenticAMD
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest family: 0x17 model: 0x1 stepping: 0x1
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest codename: Unknown
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest name: AMD Ryzen 7 1700X Eight-Core Processor
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID level eaxIn, ecxIn: eax ebx ecx edx
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000000, 0: 0x0000000d 0x68747541 0x444d4163 0x69746e65
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000001, 0: 0x00800f11 0x00020800 0xf6f83203 0x178bfbff
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 00000001, 0: 0x00800f11 0x00100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000002, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000003, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 1: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 2: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 5: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 6: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000006, 0: 0x00000004 0x00000000 0x00000001 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000007, 0: 0x00000000 0x001c01a9 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 00000007, 0: 0x00000000 0x209c01a9 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000a, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000b, 0: 0x00000000 0x00000001 0x00000100 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 0000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000b, 1: 0x00000001 0x00000002 0x00000201 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 0: 0x00000007 0x00000340 0x00000340 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1: 0x00000001 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 0000000d, 1: 0x0000000f 0x00000340 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2: 0x00000100 0x00000240 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 5: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 6: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 7: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 8: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 9: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 10: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 11: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 12: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 13: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 14: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 15: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 16: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 17: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 18: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 19: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 20: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 21: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 22: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 23: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 24: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 25: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 26: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 27: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 28: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 29: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 30: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 31: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 32: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 33: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 34: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 35: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 36: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 37: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 38: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 39: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000010, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000011, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000012, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000000, 0: 0x40000010 0x61774d56 0x4d566572 0x65726177
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000001, 0: 0x31237648 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000002, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000003, 0: 0x00000262 0x00000000 0x00000000 0x00000508
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000004, 0: 0x00000020 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000005, 0: 0xffffffff 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000006, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000007, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000a, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000010, 0: 0x0033e140 0x000101d0 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000000, 0: 0x8000001f 0x68747541 0x444d4163 0x69746e65
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000001, 0: 0x00800f11 0x20000000 0x000003fb 0x2fd3fbff
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 80000001, 0: 0x00800f11 0x20000000 0x35c233ff 0x2fd3fbff
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000002, 0: 0x20444d41 0x657a7952 0x2037206e 0x30303731
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000003, 0: 0x69452058 0x2d746867 0x65726f43 0x6f725020
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000004, 0: 0x73736563 0x2020726f 0x20202020 0x00202020
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000005, 0: 0xff40ff40 0xff40ff40 0x20080140 0x40040140
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000006, 0: 0x26006400 0x66006400 0x02006140 0x00808140
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000007, 0: 0x00000000 0x00000000 0x00000000 0x00000100
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 80000007, 0: 0x00000000 0x0000001b 0x00000000 0x00006599
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000008, 0: 0x0000302a 0x00000007 0x00001001 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 80000008, 0: 0x00003030 0x00000007 0x0000400f 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000010, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000011, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000012, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000013, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000014, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000015, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000016, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000017, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000018, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000019, 0: 0xf040f040 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001a, 0: 0x00000003 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001b, 0: 0x000003ff 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 0: 0x00004121 0x01c0003f 0x0000003f 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 1: 0x00004122 0x00c0003f 0x000000ff 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 2: 0x00004143 0x01c0003f 0x000003ff 0x00000002
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 3: 0x0001c163 0x03c0003f 0x00001fff 0x00000001
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001e, 0: 0x00000000 0x00000100 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001f, 0: 0x00000007 0x0000016f 0x0000000f 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: CPUID control desired.
2017-08-30T11:26:37.266+02:00| vmx| I125: Minimum ucode level: 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: VPMC: events will use hybrid freeze.
2017-08-30T11:26:37.266+02:00| vmx| I125: VPMC: gen counters: num 0 mask 0xffffffffffff
2017-08-30T11:26:37.266+02:00| vmx| I125: VPMC: hardware counters: 0
2017-08-30T11:26:37.266+02:00| vmx| I125: SVGA-GFB: Allocated gfbSize=4194304
2017-08-30T11:26:37.266+02:00| vmx| A100: ConfigDB: Setting vmotion.checkpointFBSize = "4194304"
2017-08-30T11:26:37.266+02:00| vmx| A100: ConfigDB: Setting vmotion.checkpointSVGAPrimarySize = "33554432"
2017-08-30T11:26:37.266+02:00| vmx| I125: SVGA-PCI: BAR gfbSize=134217728, fifoSize=8388608
2017-08-30T11:26:37.266+02:00| vmx| I125: SVGA: SVGA_REG_MEMORY_SIZE=4194304
2017-08-30T11:26:37.266+02:00| vmx| I125: SVGA: SVGA_REG_VRAM_SIZE=4194304
2017-08-30T11:26:37.266+02:00| vmx| I125: BusMemSampleSetUpStats: touched: initPct 75 pages 384000 : dirtied: initPct 75 pages 384000
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: caller 0 numvm 1 locked pages: num 1915 max 7264772
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: locked Page Limit: host 8078673 config 7325696 dynam 7272964
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: minmempct 50 timestamp 21281
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: VM 0 min 285926 max 541926 shares 512000 paged 221498 nonpaged 3697 anonymous 26229 locked 1915 touchedPct 75 dirtiedPct 75 timestamp 21281 vmResponsive is 1
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: locked 1915 target 541926 balloon 0 0 0 swapped 0 0 allocd 0 512 state 0 100
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: states: 0 1 : 1 0 : 2 0 : 3 0
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: Balloon enabled 1 guestType 0 maxSize 0
2017-08-30T11:26:37.282+02:00| vmx| I125: FeatureCompat: Capabilities:
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.FFXSR = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.RDRAND = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.PDPE1GB = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.XSAVE = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.LM = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.MWAIT = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.RDSEED = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.MOVBE = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.EXTAPICSPC = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.MMXEXT = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.CR8AVAIL = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.AMD = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.ABM = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.XCR0_MASTER_YMM_H = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.FMA = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.AVX2 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.XSAVEOPT = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SSE4A = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SSSE3 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SSE3 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.NX = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SSE41 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.BMI2 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.AES = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.PCLMULQDQ = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.3DNPREFETCH = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.POPCNT = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.AVX = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.F16C = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.FSGSBASE = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.RDTSCP = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.LAHF64 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.MISALIGNED_SSE = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.CMPXCHG16B = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SMEP = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.ADX = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SSE42 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.BMI1 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SMAP = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.XCR0_MASTER_SSE = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: FeatureCompat: Requirements:
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SSE3 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.PCLMULQDQ - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SSSE3 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.FMA - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.CMPXCHG16B - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SSE41 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SSE42 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.MOVBE - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.POPCNT - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.AES - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.XSAVE - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.AVX - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.F16C - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.RDRAND - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.FSGSBASE - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.BMI1 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.AVX2 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SMEP - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.BMI2 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.RDSEED - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.ADX - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SMAP - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.XCR0_MASTER_SSE - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.XCR0_MASTER_YMM_H - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.XSAVEOPT - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.LAHF64 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.EXTAPICSPC - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.CR8AVAIL - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.ABM - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SSE4A - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.MISALIGNED_SSE - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.3DNPREFETCH - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.NX - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.MMXEXT - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.FFXSR - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.PDPE1GB - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.RDTSCP - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.LM - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.AMD - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: TOOLS received request in VMX to set option 'enableDnD' -> '1'
2017-08-30T11:26:37.282+02:00| vmx| I125+ OvhdMem: Static (Power On) Overheads
2017-08-30T11:26:37.282+02:00| vmx| I125: reserved | used
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem excluded cur max avg | cur max avg
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MainMem : 512000 512000 - | - - -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxText : 6912 6912 - | - - -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxTextLibs : 15360 15360 - | - - -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Total excluded : 534272 534272 - | - - -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Actual maximum : 534272 | -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem paged cur max avg | cur max avg
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_KSTATS_vmm : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_STATS_vmm : 8 8 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_KSTATS_device : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_STATS_device : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_KSTATS_migrate : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_IOFilters : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_DiskLibMemUsed : 3075 3075 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaSurfaceData : 5 5 - | 1 1 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaRestoreBufferArray : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaSDirtyCache : 48 48 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaShaderTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaShaderText : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaContextCache : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaMobCache : 248 248 - | 24 24 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXRTViewTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXDSViewTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXSRViewTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXBlendStateTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXElementLayoutTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXDepthStencilTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXRasterizerStateTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXSamplerTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXContextTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXShaderTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXStreamOutTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXQueryTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxAllocTrack : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxCallStackProf : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxGlobals : 10240 10240 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxGlobalsLibs : 3584 3584 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxHeap : 8704 8704 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxHeapFreeList : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMks : 33 33 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMks3d : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksGLRenderer : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksGLTransient : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksLLVM : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksScreenTemp : 69634 69634 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksVnc : 37712 37712 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksScreen : 65537 65537 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksSVGAVO : 4096 4096 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxPhysMemRingBuf : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxPhysMemErrPages : 10 10 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxFTCptOutputBuf : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxSLEntryBuf : 128 128 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxThreadMks : 512 512 - | 512 512 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxThreadVmx : 512 512 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxThreadsVcpu : 1024 1024 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxThreadsWorker : 15872 15872 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxThreadSvga : 512 512 - | 512 512 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Total paged : 221498 221498 - | 1049 1049 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Actual maximum : 221498 | 1049
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem nonpaged cur max avg | cur max avg
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SharedArea : 89 89 - | 66 66 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_BusMemTraceBitmap : 18 18 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PFrame : 1147 1328 - | 1147 1147 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VProbe : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VIDE_KSEG : 16 16 - | 16 16 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VGA : 64 64 - | 64 64 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_BalloonMPN : 1 1 - | 1 1 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_P2MUpdateBuffer : 3 3 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_ServicesMPN : 2 2 - | 2 2 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_LocalApic : 4 4 - | 4 4 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_BusError : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VBIOS : 8 8 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VnicGuest : 16 16 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VnicMmap : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_TestDev : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_LSIBIOS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_LSIRings : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PCIPBIOS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PVSCSIBIOS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PVSCSIKickReg : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SAS1068BIOS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SBIOS : 16 16 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_AHCIBIOS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_FlashRam : 128 128 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SMM : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SVGAFB : 1024 1024 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SVGAMEM : 64 512 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_HDAudioReg : 3 3 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_EHCIRegister : 1 1 - | 1 1 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_XhciRegister : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PhysMemDebug : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_HyperV : 2 2 - | 1 1 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_ExtCfg : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_HV : 13 13 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_HVIOBitmap : 3 3 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_HVMSRBitmap : 2 2 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VHVGuestMSRBitmap : 2 2 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_vhvCachedVMCS : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_vhvNestedAPIC : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PCIP : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VMsafe : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonBootstrap : 5 5 - | 5 5 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonWired : 196 196 - | 196 196 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonLow : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonWiredNuma : 116 116 - | 116 116 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonNuma : 418 418 - | 296 296 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonOther : 136 136 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PAEShadow : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_FTCpt : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_NVDIMM : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Total nonpaged : 3516 4145 - | 1915 1915 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Actual maximum : 4145 | 1915
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem anonymous cur max avg | cur max avg
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Alloc : 316 316 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMemFrame : 2280 2471 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMemFramePGAR : 6 6 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMemTracePGAR : 2 2 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMem2MRegionPGAR : 9 9 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMemZapListMPN : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_MMU : 3100 3100 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Backmap : 8 8 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_ScratchAS : 648 648 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_MonTLB : 24 24 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_DT : 72 72 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_TCCoherency : 84 84 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_TC : 18436 18436 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_ChainInfo : 324 324 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Island : 8 8 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMemScratchAS : 8 8 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_PlatformScratchAS : 5 5 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_HVNuma : 12 12 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_HV : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VHV : 12 12 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VNPTShadow : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VNPTShadowCache : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VNPTBackmap : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_SVMIDT : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_CallStackProfAnon : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Numa : 42 42 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_NumaTextRodata : 222 222 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_NumaDataBss : 196 196 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_NumaLargeData : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_WiredNuma : 116 116 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_GPhysTraced : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_GPhysHWMMU : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_GPhysNoTrace : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BTScratchPage : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_PhysMemGart : 88 88 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_PhysMemErr : 9 9 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_TraceALot : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VIDE : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VMXNETWake : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusLogic : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Ahci : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_PVSCSIShadowRing : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_LSIRings : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_FTCptScratchAS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Hba : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VProbe : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Total anonymous : 26038 26229 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Actual maximum : 26229 | 0
2017-08-30T11:26:37.282+02:00| vmx| I125: VMMEM: Precise Reservation: 980MB (MainMem=2000MB)
2017-08-30T11:26:37.282+02:00| vmx| I125: Vix: [13112 mainDispatch.c:1073]: VMAutomation_PowerOn. Powering on.
2017-08-30T11:26:37.282+02:00| vmx| I125: VMX_PowerOn: ModuleTable_PowerOn = 1
2017-08-30T11:26:37.282+02:00| vmx| A100: ConfigDB: Setting cleanShutdown = "FALSE"
2017-08-30T11:26:37.282+02:00| vmx| A100: ConfigDB: Setting softPowerOff = "FALSE"
2017-08-30T11:26:37.282+02:00| vmx| I125: hread 17780 6160VTHREAD start thread 4 "vcpu-0" host id 17780
2017-08-30T11:26:37.282+02:00| vmx| I125: ToolsISO: open of C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig failed: Could not find the file
2017-08-30T11:26:37.282+02:00| vmx| I125: ToolsISO: Unable to read signature file 'C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig', ignoring.
2017-08-30T11:26:37.282+02:00| vmx| I125: ToolsISO: Selected Tools ISO 'winPreVista.iso' for 'winxppro' guest.
2017-08-30T11:26:37.282+02:00| vmx| I125: VMXVmdb_SetToolsVersionStatus: status value set to 'ok', 'current', install possible
2017-08-30T11:26:37.282+02:00| vcpu-0| I125: MonTimer APIC:0/0 vec: 0
2017-08-30T11:26:37.282+02:00| vcpu-0| I125: APIC: version = 0x10, max LVT = 5, LDR = 0x1000000, DFR = 0xfffffff
2017-08-30T11:26:37.282+02:00| vcpu-0| W115: MONITOR PANIC: vcpu-0:VERIFY vmcore/vmm/main/cpuid.c:386 bugNr=1036521
2017-08-30T11:26:37.282+02:00| vcpu-0| I125: Core dump with build build-5813279
2017-08-30T11:26:37.282+02:00| vcpu-0| W115: Writing monitor corefile "C:Users ipogDocumentsVirtual MachinesWindows XP Professionalvmmcores.gz"
2017-08-30T11:26:37.297+02:00| vcpu-0| W115: Dumping core for vcpu-0
2017-08-30T11:26:37.297+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:37.297+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddf05) Unknown error 998 (0x3e6)
2017-08-30T11:26:37.922+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:37.922+02:00| vcpu-0| W115: Dumping core for vcpu-1
2017-08-30T11:26:37.922+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:37.922+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddeff) Unknown error 998 (0x3e6)
2017-08-30T11:26:38.547+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:38.547+02:00| vcpu-0| W115: Dumping core for vcpu-2
2017-08-30T11:26:38.547+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:38.547+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddefe) Unknown error 998 (0x3e6)
2017-08-30T11:26:39.172+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:39.172+02:00| vcpu-0| W115: Dumping core for vcpu-3
2017-08-30T11:26:39.172+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:39.172+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddefa) Unknown error 998 (0x3e6)
2017-08-30T11:26:39.782+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:39.829+02:00| vcpu-0| I125: CoreDump_CoreDump: faking exception to get context
2017-08-30T11:26:39.829+02:00| vcpu-0| I125: CoreDump: Minidump file C:Users ipogDocumentsVirtual MachinesWindows XP Professionalvmware-vmx.dmp exists. Rotating ...
2017-08-30T11:26:39.844+02:00| vcpu-0| W115: CoreDump: Writing minidump to C:Users ipogDocumentsVirtual MachinesWindows XP Professionalvmware-vmx.dmp
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ff63f2a0000 size 0x0x01691000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x01415431 timestamp 0x59488eee
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:Program Files (x86)VMwareVMware Workstationx64vmware-vmx.exe
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 12.5.7.20721
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05fe0000 size 0x0x001db000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x001dd2f4 timestamp 0xa329d3a8
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 tdll.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.447
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb058e0000 size 0x0x000ae000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000ba9b8 timestamp 0xf5fa43df
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32kernel32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.296
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02e30000 size 0x0x00249000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00251760 timestamp 0x005405b5
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32KERNELBASE.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.502
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaeb880000 size 0x0x000a7000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000aedf6 timestamp 0x593677bf
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:Program FilesBitdefenderBitdefender Securityatcuf262824383465032704atcuf64.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 1.9.84.0
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05e30000 size 0x0x0014a000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0014c0a9 timestamp 0xd66f509b
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32user32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.0
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb034b0000 size 0x0x0001e000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002c288 timestamp 0xd9592a17
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32win32u.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05be0000 size 0x0x00027000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002d6de timestamp 0xefcc154c
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32gdi32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03320000 size 0x0x00188000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0018c93a timestamp 0x2e4a909f
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32gdi32full.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.413
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb031d0000 size 0x0x0009a000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0009c31a timestamp 0xd867caf3
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32msvcp_win.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb030d0000 size 0x0x000f6000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000f8df9 timestamp 0x5ba8b66e
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32ucrtbase.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb056e0000 size 0x0x00145000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0014bf01 timestamp 0xcf17fc6c
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32ole32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb036f0000 size 0x0x002f9000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0030878d timestamp 0x91412db8
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32combase.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03540000 size 0x0x00125000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x001251d1 timestamp 0xcf94c546
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 pcrt4.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb034d0000 size 0x0x0006a000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0006e6ae timestamp 0x3bbaa205
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32cryptPrimitives.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03d50000 size 0x0x00059000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00062381 timestamp 0xb4c11302
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32sechost.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05830000 size 0x0x000a1000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000a0077 timestamp 0x8e7c3351
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32advapi32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03c80000 size 0x0x0009d000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000a08ad timestamp 0x3280d1b7
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32msvcrt.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 7.0.15063.0
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb041f0000 size 0x0x01437000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0146b7f9 timestamp 0x944613c6
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32shell32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03080000 size 0x0x00049000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00049455 timestamp 0xbb524065
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32cfgmgr32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05c70000 size 0x0x000aa000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000ab70b timestamp 0xb7eb0e3a
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32SHCore.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02500000 size 0x0x006f3000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00700b1f timestamp 0xded631f2
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32windows.storage.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb039f0000 size 0x0x00051000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00050ac9 timestamp 0x166c812d
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32shlwapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb024e0000 size 0x0x00011000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0001ca85 timestamp 0xed031ad5
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32kernel.appcore.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02490000 size 0x0x0004c000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00059a98 timestamp 0xbc0704c4
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32powrprof.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02470000 size 0x0x00015000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00020f06 timestamp 0xc8e1d59a
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32profapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03db0000 size 0x0x0043b000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0044ef93 timestamp 0x5b73cf27
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32setupapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03670000 size 0x0x0006c000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0006aeaf timestamp 0x60cde072
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32ws2_32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03bc0000 size 0x0x000c0000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000bea89 timestamp 0xc76efb2b
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32oleaut32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.332
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02c00000 size 0x0x001c9000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x001c8cbd timestamp 0x27f585b8
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32crypt32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02450000 size 0x0x00011000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00011ae2 timestamp 0xc8896f56
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32msasn1.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x58d80000 size 0x0x000a3000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0009febb timestamp 0x57fb7ca9
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsWinSxSamd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9279_none_08e667efa83ba076msvcr90.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 9.0.30729.9279
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb00830000 size 0x0x00023000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002d19d timestamp 0x24ec155f
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32winmm.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffae8720000 size 0x0x0008c000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000911bd timestamp 0x05871a39
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32dsound.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf1ad0000 size 0x0x0003f000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0003c6de timestamp 0x94f161b1
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32WinSCard.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffafb080000 size 0x0x000d7000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000da987 timestamp 0x5a70786d
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32winhttp.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaff000000 size 0x0x00013000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00015c52 timestamp 0xf583d34a
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wtsapi32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb00540000 size 0x0x0002b000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00028fa7 timestamp 0x318335b4
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32WINMMBASE.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb00f90000 size 0x0x00028000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00025d32 timestamp 0xcc2b2861
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32devobj.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03d20000 size 0x0x0002d000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002bd92 timestamp 0xdd2e6bc9
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32imm32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb00c50000 size 0x0x00095000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0009238a timestamp 0x32d33af4
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32uxtheme.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x58570000 size 0x0x00244000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0023f163 timestamp 0x5897f482
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:Program Files (x86)VMwareVMware Workstationx64libeay32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 1.0.2.11
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf6fa0000 size 0x0x0005d000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0005a7fd timestamp 0x5897f48e
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:Program Files (x86)VMwareVMware Workstationx64ssleay32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01f00000 size 0x0x00017000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000218b4 timestamp 0x867e8ea6
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32cryptsp.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01920000 size 0x0x00034000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000367ed timestamp 0x87674e0e
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 saenh.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02320000 size 0x0x00025000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002692f timestamp 0x17fe17fb
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32crypt.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01f20000 size 0x0x0000b000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000111cd timestamp 0xde95b0dc
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32CRYPTBASE.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02350000 size 0x0x00030000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0003283d timestamp 0x4ed5f018
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32sspicli.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01750000 size 0x0x00031000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00031add timestamp 0x1c48ce6a
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 tmarta.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01d00000 size 0x0x0005c000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0005d450 timestamp 0x279c60ce
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32mswsock.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01ae0000 size 0x0x000a4000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000af167 timestamp 0x4b63fa85
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32dnsapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb056d0000 size 0x0x00008000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00014149 timestamp 0x5e3fea14
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 si.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01aa0000 size 0x0x00037000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0003f628 timestamp 0x445de47c
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32IPHLPAPI.DLL
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf7f40000 size 0x0x0000a000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0000e2a1 timestamp 0x1faec3a4
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 asadhlp.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05630000 size 0x0x0009e000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000a5c1e timestamp 0x08d5a6ff
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32clbcatq.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 2001.12.10941.16384
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf7f30000 size 0x0x00010000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00014224 timestamp 0xa8949859
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wbemwbemprox.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf1f20000 size 0x0x00082000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0007febd timestamp 0x3a8a6fab
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wbemcomn.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaef9a0000 size 0x0x00014000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000163eb timestamp 0x0f06ed62
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wbemwbemsvc.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaeff80000 size 0x0x000f0000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000f2f5c timestamp 0xe706edd1
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wbemfastprox.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb059b0000 size 0x0x00008000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000052db timestamp 0x26b463dc
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32psapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf0190000 size 0x0x001a9000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00194edc timestamp 0xed6376f8
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32dbghelp.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.250
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03a50000 size 0x0x00166000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00168f90 timestamp 0x6e750bce
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32msctf.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01ea0000 size 0x0x00055000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00056e14 timestamp 0x6c7fa901
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32winsta.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf6480000 size 0x0x00069000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000735b6 timestamp 0x1e7a418a
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32SensorsApi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.483
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaff580000 size 0x0x0000f000
continua
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0000e8c7 timestamp 0xab999dd1
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32SensorsUtilsV2.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffafc540000 size 0x0x0001d000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00024861 timestamp 0x04fac2f0
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32SensorsNativeApi.V2.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaff0b0000 size 0x0x00196000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0019b38a timestamp 0x74650d36
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32propsys.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02dd0000 size 0x0x00056000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0005cba7 timestamp 0xbffdf466
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wintrust.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb00800000 size 0x0x0002a000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002f77a timestamp 0xdd3bab06
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32dwmapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaefa40000 size 0x0x00029000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000259c5 timestamp 0xb0cf3869
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32dbgcore.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 13112
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 13712
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 6060
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 14296
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 10248
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 15444
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 11500
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 6924
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 9388
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 9944
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 6940
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 11612
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 13316
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 17448
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 17780
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: Msg_Post: Error
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: [msg.log.error.unrecoverable] VMware Workstation unrecoverable error: (vcpu-0)
2017-08-30T11:26:40.063+02:00| vcpu-0| I125+ vcpu-0:VERIFY vmcore/vmm/main/cpuid.c:386 bugNr=1036521
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: [msg.panic.haveLog] A log file is available in "C:Users ipogDocumentsVirtual MachinesWindows XP Professionalvmware.log".
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: [msg.panic.requestSupport.withoutLog] You can request support.
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: [msg.panic.requestSupport.vmSupport.windowsOrLinux]
2017-08-30T11:26:40.063+02:00| vcpu-0| I125+ To collect data to submit to VMware support, choose "Collect Support Data" from the Help menu.
2017-08-30T11:26:40.063+02:00| vcpu-0| I125+ You can also run the "vm-support" script in the Workstation folder directly.
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: [msg.panic.response] We will respond on the basis of your support entitlement.
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: ----------------------------------------
2017-08-30T11:26:47.718+02:00| vcpu-0| W115: Writing monitor corefile "C:Users ipogDocumentsVirtual MachinesWindows XP Professionalvmmcores.gz"
2017-08-30T11:26:47.734+02:00| vcpu-0| W115: Dumping core for vcpu-0
2017-08-30T11:26:47.734+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:47.734+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddf05) Unknown error 998 (0x3e6)
2017-08-30T11:26:48.359+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:48.359+02:00| vcpu-0| W115: Dumping core for vcpu-1
2017-08-30T11:26:48.359+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:48.359+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddeff) Unknown error 998 (0x3e6)
2017-08-30T11:26:48.984+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:48.984+02:00| vcpu-0| W115: Dumping core for vcpu-2
2017-08-30T11:26:48.984+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:48.984+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddefe) Unknown error 998 (0x3e6)
2017-08-30T11:26:49.625+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:49.625+02:00| vcpu-0| W115: Dumping core for vcpu-3
2017-08-30T11:26:49.625+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:49.625+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddefa) Unknown error 998 (0x3e6)
2017-08-30T11:26:50.250+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:36.391+02:00| vmx| I125: Log for VMware Workstation pid=6160 version=12.5.7 build=build-5813279 option=Release
2017-08-30T11:26:36.391+02:00| vmx| I125: The process is 64-bit.
2017-08-30T11:26:36.391+02:00| vmx| I125: Host codepage=windows-1252 encoding=windows-1252
2017-08-30T11:26:36.391+02:00| vmx| I125: Host is Windows 10, 64-bit (Build 15063)
2017-08-30T11:26:36.344+02:00| vmx| I125: VTHREAD initialize main thread 0 "vmx" host id 13112
2017-08-30T11:26:36.344+02:00| vmx| I125: LOCALE windows-1252 -> NULL User=410 System=410
2017-08-30T11:26:36.344+02:00| vmx| I125: Msg_SetLocaleEx: HostLocale=windows-1252 UserLocale=NULL
2017-08-30T11:26:36.344+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:ProgramDataVMware): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.344+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:ProgramDataVMwareVMware Workstation): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.344+02:00| vmx| I125: DictionaryLoad: Cannot open file "C:UsersDefaultAppDataRoamingVMwareconfig.ini": Unknown error 3 (0x3).
2017-08-30T11:26:36.344+02:00| vmx| I125: Msg_Reset:
2017-08-30T11:26:36.344+02:00| vmx| I125: [msg.dictionary.load.openFailed] Cannot open file "C:UsersDefaultAppDataRoamingVMwareconfig.ini": Unknown error 3 (0x3).
2017-08-30T11:26:36.344+02:00| vmx| I125: ----------------------------------------
2017-08-30T11:26:36.344+02:00| vmx| I125: ConfigDB: Failed to load C:UsersDefaultAppDataRoamingVMwareconfig.ini
2017-08-30T11:26:36.344+02:00| vmx| I125: OBJLIB-LIB: Objlib initialized.
2017-08-30T11:26:36.344+02:00| vmx| I125: PREF Optional preferences file not found at C:UsersDefaultAppDataRoamingVMwareconfig.ini. Using default values.
2017-08-30T11:26:36.344+02:00| vmx| I125: UUID: SMBIOS UUID is reported as '96 6b e4 4b ef 4b 2a b9-dd 49 88 d7 f6 e2 3a d9'.
2017-08-30T11:26:36.344+02:00| vmx| I125: FILE: FileLockDynaLink: Further process validation tools are: available
2017-08-30T11:26:36.344+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:UsersDefaultAppDataRoamingVMwarepreferences.ini.lck): Unknown error 3 (0x3) (3)
2017-08-30T11:26:36.344+02:00| vmx| W115: FILE: FileLockCreateEntryDirectory creation failure on 'C:UsersDefaultAppDataRoamingVMwarepreferences.ini.lck': No such file or directory
2017-08-30T11:26:36.344+02:00| vmx| I125: [msg.preference.loadNoLock] Unable to lock user preference file C:UsersDefaultAppDataRoamingVMwarepreferences.ini for reading.
2017-08-30T11:26:36.344+02:00| vmx| I125: PREF Failed to load user preferences.
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:ProgramDataVMware): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipog): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppData): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocal): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocalTemp): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocalTempvmware-tipog): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.391+02:00| vmx| I125: Hostname=DESKTOP-GODURJ7
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=fe80::39fc:8a3a:22e:7abc%5
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=fe80::2966:802b:fef9:ef66%2
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=fe80::18d4:62de:c419:af6f%6
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=fe80::88d:2aac:3f57:fe79%3
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=192.168.40.1
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=192.168.226.1
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=192.168.1.134
2017-08-30T11:26:36.391+02:00| vmx| I125: IP=2001:0:5ef5:79fd:88d:2aac:3f57:fe79
2017-08-30T11:26:36.422+02:00| vmx| I125: System uptime 92680602864 us
2017-08-30T11:26:36.422+02:00| vmx| I125: Command line: "C:Program Files (x86)VMwareVMware Workstationx64vmware-vmx.exe" "-T" "querytoken" "-s" "vmx.stdio.keep=TRUE" "-#" "product=1;name=VMware Workstation;version=12.5.7;buildnumber=5813279;licensename=VMware Workstation;licenseversion=12.0;" "-@" "pipe=\.pipevmxcaec9fa46175bab1;msgs=ui" "C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmx"
2017-08-30T11:26:36.422+02:00| vmx| I125: Msg_SetLocaleEx: HostLocale=windows-1252 UserLocale=NULL
2017-08-30T11:26:36.453+02:00| vmx| I125: WQPoolAllocPoll : pollIx = 1, signalHandle = 624
2017-08-30T11:26:36.453+02:00| vmx| I125: WQPoolAllocPoll : pollIx = 2, signalHandle = 680
2017-08-30T11:26:36.453+02:00| vmx| I125: VigorTransport listening on fd 692
2017-08-30T11:26:36.453+02:00| vmx| I125: Vigor_Init 1
2017-08-30T11:26:36.453+02:00| vmx| I125: Connecting 'ui' to pipe '\.pipevmxcaec9fa46175bab1' with user '(null)'
2017-08-30T11:26:36.453+02:00| vmx| I125: VMXVmdb: Local connection timeout: 60000 ms.
2017-08-30T11:26:36.547+02:00| vmx| I125: VmdbAddConnection: cnxPath=/db/connection/#1/, cnxIx=1
2017-08-30T11:26:36.547+02:00| vmx| I125: Vix: [13112 mainDispatch.c:490]: VMAutomation: Initializing VMAutomation.
2017-08-30T11:26:36.547+02:00| vmx| I125: Vix: [13112 mainDispatch.c:746]: VMAutomationOpenListenerSocket() listening
2017-08-30T11:26:36.563+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1870, success=1 additionalError=0
2017-08-30T11:26:36.563+02:00| vmx| I125: Transitioned vmx/execState/val to poweredOff
2017-08-30T11:26:36.563+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2017-08-30T11:26:36.563+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=2, newAppState=1877, success=1 additionalError=0
2017-08-30T11:26:36.563+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=3, newAppState=1881, success=1 additionalError=0
2017-08-30T11:26:36.578+02:00| vmx| I125: IOPL_VBSRunning: VBS is set to 0
2017-08-30T11:26:36.578+02:00| vmx| I125: IOCTL_VMX86_SET_MEMORY_PARAMS already set
2017-08-30T11:26:36.578+02:00| vmx| I125: FeatureCompat: No EVC masks.
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID vendor: AuthenticAMD
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID family: 0x17 model: 0x1 stepping: 0x1
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID codename: Unknown
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID name: AMD Ryzen 7 1700X Eight-Core Processor
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000000, 0: 0x0000000d 0x68747541 0x444d4163 0x69746e65
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000001, 0: 0x00800f11 0x00100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000002, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000003, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000004, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000005, 0: 0x00000040 0x00000040 0x00000003 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000006, 0: 0x00000004 0x00000000 0x00000001 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000007, 0: 0x00000000 0x209c01a9 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 00000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000a, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 0: 0x00000007 0x00000340 0x00000340 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1: 0x0000000f 0x00000340 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2: 0x00000100 0x00000240 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 5: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 6: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 7: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 8: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 9: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 10: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 11: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 12: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 13: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 14: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 15: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 16: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 17: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 18: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 19: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 1f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 20: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 21: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 22: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 23: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 24: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 25: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 26: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 27: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 28: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 29: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 2f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 30: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 31: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 32: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 33: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 34: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 35: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 36: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 37: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 38: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 39: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 0000000d, 3f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000000, 0: 0x8000001f 0x68747541 0x444d4163 0x69746e65
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000001, 0: 0x00800f11 0x20000000 0x35c233ff 0x2fd3fbff
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000002, 0: 0x20444d41 0x657a7952 0x2037206e 0x30303731
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000003, 0: 0x69452058 0x2d746867 0x65726f43 0x6f725020
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000004, 0: 0x73736563 0x2020726f 0x20202020 0x00202020
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000005, 0: 0xff40ff40 0xff40ff40 0x20080140 0x40040140
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000006, 0: 0x26006400 0x66006400 0x02006140 0x00808140
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000007, 0: 0x00000000 0x0000001b 0x00000000 0x00006599
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000008, 0: 0x00003030 0x00000007 0x0000400f 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000a, 0: 0x00000001 0x00008000 0x00000000 0x0001bcff
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000010, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000011, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000012, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000013, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000014, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000015, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000016, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000017, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000018, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 80000019, 0: 0xf040f040 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001a, 0: 0x00000003 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001b, 0: 0x000003ff 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001d, 0: 0x00004121 0x01c0003f 0x0000003f 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001d, 1: 0x00004122 0x00c0003f 0x000000ff 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001d, 2: 0x00004143 0x01c0003f 0x000003ff 0x00000002
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001d, 3: 0x0001c163 0x03c0003f 0x00001fff 0x00000001
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001e, 0: 0x00000000 0x00000100 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: hostCPUID level 8000001f, 0: 0x00000007 0x0000016f 0x0000000f 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID differences from hostCPUID.
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[1] level 00000001, 0: 0x00800f11 0x01100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[1] level 8000001e, 0: 0x00000001 0x00000100 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[2] level 00000001, 0: 0x00800f11 0x02100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[2] level 8000001e, 0: 0x00000002 0x00000101 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[3] level 00000001, 0: 0x00800f11 0x03100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[3] level 8000001e, 0: 0x00000003 0x00000101 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[4] level 00000001, 0: 0x00800f11 0x04100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[4] level 8000001e, 0: 0x00000004 0x00000102 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[5] level 00000001, 0: 0x00800f11 0x05100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[5] level 8000001e, 0: 0x00000005 0x00000102 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[6] level 00000001, 0: 0x00800f11 0x06100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[6] level 8000001e, 0: 0x00000006 0x00000103 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[7] level 00000001, 0: 0x00800f11 0x07100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[7] level 8000001e, 0: 0x00000007 0x00000103 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[8] level 00000001, 0: 0x00800f11 0x08100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[8] level 8000001e, 0: 0x00000008 0x00000104 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[9] level 00000001, 0: 0x00800f11 0x09100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[9] level 8000001e, 0: 0x00000009 0x00000104 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[10] level 00000001, 0: 0x00800f11 0x0a100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[10] level 8000001e, 0: 0x0000000a 0x00000105 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[11] level 00000001, 0: 0x00800f11 0x0b100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[11] level 8000001e, 0: 0x0000000b 0x00000105 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[12] level 00000001, 0: 0x00800f11 0x0c100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[12] level 8000001e, 0: 0x0000000c 0x00000106 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[13] level 00000001, 0: 0x00800f11 0x0d100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[13] level 8000001e, 0: 0x0000000d 0x00000106 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[14] level 00000001, 0: 0x00800f11 0x0e100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[14] level 8000001e, 0: 0x0000000e 0x00000107 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[15] level 00000001, 0: 0x00800f11 0x0f100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID[15] level 8000001e, 0: 0x0000000f 0x00000107 0x00000000 0x00000000
2017-08-30T11:26:36.656+02:00| vmx| I125: CPUID Maximum Physical Address Bits supported across all CPUs: 48
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x3a = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x480 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x481 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x482 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x483 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x484 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x485 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x486 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x487 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x488 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x489 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48a = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48b = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48c = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48d = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48e = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x48f = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x490 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0x491 = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0xc0010114 = 0x18
2017-08-30T11:26:36.656+02:00| vmx| I125: Common: MSR 0xce = 0
2017-08-30T11:26:36.656+02:00| vmx| I125: VMMon_GetkHzEstimate: Calculated 3393624 kHz
2017-08-30T11:26:36.656+02:00| vmx| I125: HOSTINFO: Host supports constant rate TSC.
2017-08-30T11:26:36.656+02:00| vmx| I125: TSC kHz estimates: vmmon 3393624, remembered 0, osReported 3400000. Using 3400000 kHz.
2017-08-30T11:26:36.656+02:00| vmx| I125: TSC first measured delta 884
2017-08-30T11:26:36.656+02:00| vmx| I125: TSC min delta 884
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: RefClockToPTSC 0 @ 14318180Hz -> 0 @ 3400000000Hz
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: RefClockToPTSC ((x * 3983923543) >> 24) + -12972649701295
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: tscOffset -13011554950100
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: using TSC
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: hardware TSCs are synchronized.
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: hardware TSCs may have been adjusted by the host.
2017-08-30T11:26:36.656+02:00| vmx| I125: PTSC: current PTSC=59313379234640
2017-08-30T11:26:36.656+02:00| vmx| I125: WQPoolAllocPoll : pollIx = 3, signalHandle = 876
2017-08-30T11:26:36.703+02:00| vmx| I125: ConfigCheck: No rules file found. Checks are disabled.
2017-08-30T11:26:36.703+02:00| vmx| I125: changing directory to C:Users ipogDocumentsVirtual MachinesWindows XP Professional.
2017-08-30T11:26:36.703+02:00| vmx| I125: Config file: C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmx
2017-08-30T11:26:36.703+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2017-08-30T11:26:36.703+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=2, newAppState=1878, success=1 additionalError=0
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipog): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppData): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocal): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocalTemp): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.703+02:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:Users ipogAppDataLocalTempvmware-tipog): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:36.735+02:00| vmx| A100: ConfigDB: Setting ide1:0.fileName = "auto detect"
2017-08-30T11:26:36.813+02:00| vmx| I125: VMXVmdbCbVmVmxExecState: Exec state change requested to state poweredOn without reset, soft, softOptionTimeout: 0.
2017-08-30T11:26:36.813+02:00| vmx| I125: Tools: sending 'OS_PowerOn' (state = 3) state change request
2017-08-30T11:26:36.813+02:00| vmx| I125: Tools: Delaying state change request to state 3.
2017-08-30T11:26:36.813+02:00| vmx| W115: PowerOn
2017-08-30T11:26:36.813+02:00| vmx| I125: VMX_PowerOn: VMX build 5813279, UI build 5813279
2017-08-30T11:26:36.813+02:00| vmx| I125: HostWin32: WIN32 NUMA node 0, CPU mask 0x000000000000ffff
2017-08-30T11:26:36.828+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1871, success=1 additionalError=0
2017-08-30T11:26:36.828+02:00| vmx| I125: HOST Windows version 10.0, build 15063, platform 2, "", SMP
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- GLOBAL SETTINGS C:ProgramDataVMwareVMware Workstationsettings.ini
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT printers.enabled = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- NON PERSISTENT
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- USER PREFERENCES C:UsersDefaultAppDataRoamingVMwarepreferences.ini
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- USER DEFAULTS C:UsersDefaultAppDataRoamingVMwareconfig.ini
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- HOST DEFAULTS C:ProgramDataVMwareVMware Workstationconfig.ini
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT authd.client.port = "903"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT authd.proxy.nfc = "vmware-hostd:ha-nfc"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT installerDefaults.autoSoftwareUpdateEnabled = "yes"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT installerDefaults.autoSoftwareUpdateEnabled.epoch = "19778"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT installerDefaults.componentDownloadEnabled = "yes"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT installerDefaults.dataCollectionEnabled = "no"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT installerDefaults.dataCollectionEnabled.epoch = "19778"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT smc.version = "0"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- SITE DEFAULTS C:ProgramDataVMwareVMware Workstationconfig.ini
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- NONPERSISTENT
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmx.stdio.keep = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT gui.available = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- COMMAND LINE
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- RECORDING
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT --- CONFIGURATION C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmx
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT config.version = "8"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT virtualHW.version = "11"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT scsi0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT memsize = "2000"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide0:0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide0:0.fileName = "Windows XP Professional.vmdk"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide1:0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide1:0.fileName = "auto detect"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide1:0.deviceType = "cdrom-raw"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.connectionType = "nat"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.wakeOnPcktRcv = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.addressType = "generated"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ehci.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ehci.pciSlotNumber = "35"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT sound.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT sound.fileName = "-1"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT sound.autodetect = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT mks.enable3d = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.graphicsMemoryKB = "524288"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT serial0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT serial0.fileType = "thinprint"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge4.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge4.virtualDev = "pcieRootPort"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge4.functions = "8"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge5.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge5.virtualDev = "pcieRootPort"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge5.functions = "8"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge6.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge6.virtualDev = "pcieRootPort"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge6.functions = "8"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge7.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge7.virtualDev = "pcieRootPort"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge7.functions = "8"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmci0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT hpet0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb.vbluetooth.startConnected = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT buslogic.noDriver = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT displayName = "Windows XP Professional"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT guestOS = "winxppro"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT nvram = "Windows XP Professional.nvram"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT virtualHW.productCompatibility = "hosted"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT gui.exitOnCLIHLT = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT powerType.powerOff = "soft"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT powerType.powerOn = "soft"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT powerType.suspend = "soft"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT powerType.reset = "soft"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT extendedConfigFile = "Windows XP Professional.vmxf"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT uuid.bios = "56 4d 63 35 46 0d cd a6-08 ad 14 74 37 47 80 ab"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT uuid.location = "56 4d 63 35 46 0d cd a6-08 ad 14 74 37 47 80 ab"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT replay.supported = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT replay.filename = ""
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT migrate.hostlog = ".Windows XP Professional-7eefab4f.hlog"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide0:0.redo = ""
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge0.pciSlotNumber = "17"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge4.pciSlotNumber = "21"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge5.pciSlotNumber = "22"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge6.pciSlotNumber = "23"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT pciBridge7.pciSlotNumber = "24"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT scsi0.pciSlotNumber = "16"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb.pciSlotNumber = "32"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.pciSlotNumber = "33"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT sound.pciSlotNumber = "34"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmci0.pciSlotNumber = "36"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.generatedAddress = "00:0c:29:47:80:ab"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ethernet0.generatedAddressOffset = "0"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmci0.id = "2044499865"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT monitor.phys_bits_used = "42"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmotion.checkpointFBSize = "4194304"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT vmotion.checkpointSVGAPrimarySize = "33554432"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT cleanShutdown = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT softPowerOff = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:1.speed = "2"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:1.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:1.deviceType = "hub"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:1.port = "1"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:1.parent = "-1"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide1:0.autodetect = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.guestBackedPrimaryAware = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT tools.syncTime = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb.autoConnect.device0 = ""
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT tools.remindInstall = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT toolsInstallManager.updateCounter = "7"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT checkpoint.vmState = ""
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT ide1:0.startConnected = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.autodetect = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.vramSize = "5242880"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT numvcpus = "4"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.maxWidth = "1280"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT svga.maxHeight = "1024"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT sound.startConnected = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT numa.autosize.vcpu.maxPerVirtualNode = "4"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT numa.autosize.cookie = "40001"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT toolsInstallManager.lastInstallError = "0"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT cpuid.coresPerSocket = "2"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb.autoConnect.device1 = ""
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:0.present = "TRUE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:0.deviceType = "hid"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:0.port = "0"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb:0.parent = "-1"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT monitor.virtual_mmu = "automatic"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT monitor.virtual_exec = "automatic"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT usb_xhci.present = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: DICT floppy0.present = "FALSE"
2017-08-30T11:26:36.828+02:00| vmx| I125: ToolsISO: open of C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig failed: Could not find the file
2017-08-30T11:26:36.828+02:00| vmx| I125: ToolsISO: Unable to read signature file 'C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig', ignoring.
2017-08-30T11:26:36.828+02:00| vmx| I125: ToolsISO: Selected Tools ISO 'winPreVista.iso' for 'winxppro' guest.
2017-08-30T11:26:36.828+02:00| vmx| I125: Vix: [13112 mainDispatch.c:4238]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2017-08-30T11:26:36.860+02:00| vmx| I125: Host AMD-V Capabilities:
2017-08-30T11:26:36.860+02:00| vmx| I125: SVM Revision: 1
2017-08-30T11:26:36.860+02:00| vmx| I125: ASIDs Supported: 32768
2017-08-30T11:26:36.860+02:00| vmx| I125: Nested Paging: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: LBR Virtualization: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: SVM Lock: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: NRIP Save: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: TSC Rate MSR: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: VMCB Clean Bits: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: Flush by ASID: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: Decode Assists: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: Pause Filter: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: Pause Filter Threshold: yes
2017-08-30T11:26:36.860+02:00| vmx| I125: Family 10H or greater CPU(s) required for AMD-V support in VMware Workstation; however, this host has family 17H CPU(s).
2017-08-30T11:26:36.860+02:00| vmx| I125: hostCpuFeatures = 0x347f
2017-08-30T11:26:36.860+02:00| vmx| I125: hostNumGenPerfCounters = 0
2017-08-30T11:26:36.860+02:00| vmx| I125: hostNumFixedPerfCounters = 0
2017-08-30T11:26:36.860+02:00| vmx| I125: hostPerfCtrArch = 0
2017-08-30T11:26:36.860+02:00| vmx| I125: MONITOR MODE: allowed modes : BT
2017-08-30T11:26:36.860+02:00| vmx| I125: MONITOR MODE: user requested modes : BT HV HWMMU
2017-08-30T11:26:36.860+02:00| vmx| I125: MONITOR MODE: guestOS preferred modes: HWMMU HV BT
2017-08-30T11:26:36.860+02:00| vmx| I125: MONITOR MODE: filtered list : BT
2017-08-30T11:26:36.860+02:00| vmx| I125: HV Settings: virtual exec = 'software'; virtual mmu = 'software'
2017-08-30T11:26:36.860+02:00| vmx| W115: Unknown Guest OS. Ensure sufficient memory provisioning if ballooning is enabled.
2017-08-30T11:26:36.860+02:00| vmx| I125: OvhdMem_PowerOn: initial admission: paged 221498 nonpaged 4145 anonymous 26229
2017-08-30T11:26:36.860+02:00| vmx| I125: VMMEM: Initial Reservation: 983MB (MainMem=2000MB)
2017-08-30T11:26:36.860+02:00| vmx| I125: MemSched_PowerOn: balloon minGuestSize 0 (80% of min required size 0)
2017-08-30T11:26:36.860+02:00| vmx| I125: MemSched: reserved mem (in MB) min 128 max 28616 recommended 28616
2017-08-30T11:26:36.860+02:00| vmx| I125: MemSched: pg 221498 np 4145 anon 26229 mem 512000
2017-08-30T11:26:36.906+02:00| vmx| I125: MemSched: numvm 1 locked pages: num 0 max 7264772
2017-08-30T11:26:36.906+02:00| vmx| I125: MemSched: locked Page Limit: host 8078434 config 7325696 dynam 7272964
2017-08-30T11:26:36.906+02:00| vmx| I125: MemSched: minmempct 50 minalloc 0 admitted 1
2017-08-30T11:26:36.922+02:00| vmx| I125: hread 10248 6160VTHREAD start thread 8 "WinNotifyThread" host id 10248
2017-08-30T11:26:36.922+02:00| WinNotifyThread| I125: WinNotify thread is alive
2017-08-30T11:26:36.922+02:00| vmx| I125: LICENSE using: 'HKEY_LOCAL_MACHINESOFTWAREVMware, Inc.VMware WorkstationDormantLicense.ws.12.0.e2.201505'
2017-08-30T11:26:36.922+02:00| vmx| I125: hread 15444 6160VTHREAD start thread 9 "vthread-9" host id 15444
2017-08-30T11:26:36.922+02:00| vmx| I125: PolicyVMXFindPolicyKey: policy file does not exist.
2017-08-30T11:26:36.922+02:00| vmx| I125: ToolsISO: open of C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig failed: Could not find the file
2017-08-30T11:26:36.922+02:00| vmx| I125: ToolsISO: Unable to read signature file 'C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig', ignoring.
2017-08-30T11:26:36.922+02:00| vmx| I125: ToolsISO: Selected Tools ISO 'winPreVista.iso' for 'winxppro' guest.
2017-08-30T11:26:36.922+02:00| vmx| I125: Host IPI vectors: 0x2f 0. Monitor IPI vector: 0, HV IPI vector: 0
2017-08-30T11:26:36.922+02:00| vmx| I125: Monitor_PowerOn: hostedVSMPMaxSkew is 1500 us (5100000 cycles)
2017-08-30T11:26:36.922+02:00| vmx| I125: Monitor64_PowerOn()
2017-08-30T11:26:36.922+02:00| vmx| I125: Loaded worldswitch: .wsBody64. Size = 480.
2017-08-30T11:26:36.922+02:00| vmx| I125: Successfully loaded worldswitch fault handlers from .switchNMI. Size = 208.
2017-08-30T11:26:36.922+02:00| vmx| I125: vmm64-modules: [vmm.vmm64, mmu-nohv.vmm64, vprobe-none.vmm64, hv-none.vmm64, gphys-sw.vmm64, callstack-none.vmm64, vmce-none.vmm64, vvtd-none.vmm64, guestIntegrity-none.vmm64, buslogic-buslogic.vmm64, {SharedAreaReservations} .shared_per_vm_vmx:0x40, {SharedInterVcpuVmxSection}, {SharedInterVcpuSection}, , busLogicShared=0xfffffffffc0c6000, {UseUnwind}=0x0, hvLoadedAsAddr=0x0, useNPTAsAddr=0x0, numVCPUsAsAddr=0x4, busmemFrameSizeLog2AsAddr=0x4, busmemFrameSizeAsAddr=0x10, {rodataSize}=0x1b09c, {textAddr}=0xfffffffffc41c000, {textSize}=0x93473]
2017-08-30T11:26:36.922+02:00| vmx| I125: vmm64-vcpus: 4
2017-08-30T11:26:36.938+02:00| vmx| I125: KHZEstimate 3400000
2017-08-30T11:26:36.938+02:00| vmx| I125: MHZEstimate 3400
2017-08-30T11:26:36.938+02:00| vmx| I125: NumVCPUs 4
2017-08-30T11:26:36.938+02:00| vmx| I125: Guest OS (20488) not supported for replay debugging.
2017-08-30T11:26:36.938+02:00| vmx| I125: MonTimer: host does not have high resolution timers.
2017-08-30T11:26:36.938+02:00| vmx| I125: UUID: location-UUID is 56 4d 73 72 30 05 8a 20-0d ea 48 af 80 b6 87 e9
2017-08-30T11:26:36.938+02:00| vmx| I125: UUID: location-UUID is 56 4d 63 35 46 0d cd a6-08 ad 14 74 37 47 80 ab
2017-08-30T11:26:36.938+02:00| vmx| I125: AIOGNRC: numThreads=4 ide=1, scsi=0, passthru=1
2017-08-30T11:26:36.938+02:00| vmx| I125: WORKER: Creating new group with numThreads=4 (4)
2017-08-30T11:26:36.938+02:00| vmx| I125: WORKER: Creating new group with numThreads=1 (5)
2017-08-30T11:26:36.938+02:00| vmx| I125: MainMem: CPT Host WZ=0 PF=2000 D=0
2017-08-30T11:26:36.938+02:00| vmx| I125: MainMem: CPT PLS=1 PLR=1 BS=1 BlkP=32 Mult=4 W=50
2017-08-30T11:26:36.953+02:00| vmx| I125: Hostinfo_OpenProcessBits: OpenProcess access bits are 1000.
2017-08-30T11:26:36.953+02:00| vmx| I125: FILE: FileLockScanDirectory discarding M16434.lck from C:Users ipogDocumentsVirtual MachinesWindows XP Professional564d6335-460d-cda6-08ad-1474374780ab.vmem.lck': invalid executionID 5164-131484699338746354(vmware-vmx.exe).
2017-08-30T11:26:37.063+02:00| vmx| I125: MainMem: Opened paging file, 'C:Users ipogDocumentsVirtual MachinesWindows XP Professional564d6335-460d-cda6-08ad-1474374780ab.vmem'.
2017-08-30T11:26:37.063+02:00| vmx| I125: MStat: Creating Stat vm.uptime
2017-08-30T11:26:37.063+02:00| vmx| I125: MStat: Creating Stat vm.suspendTime
2017-08-30T11:26:37.063+02:00| vmx| I125: MStat: Creating Stat vm.powerOnTimeStamp
2017-08-30T11:26:37.063+02:00| vmx| I125: hread 11500 6160VMXAIOMGR: Using: simple=Generic unbuf=Compl
2017-08-30T11:26:37.063+02:00| aioCompletion| I125: VTHREAD start thread 10 "aioCompletion" host id 11500
2017-08-30T11:26:37.078+02:00| vmx| I125: WORKER: Creating new group with numThreads=1 (6)
2017-08-30T11:26:37.078+02:00| vmx| I125: WORKER: Creating new group with numThreads=16 (22)
2017-08-30T11:26:37.078+02:00| vmx| I125: MigrateResetStaleVMDBHostLog: Hostlog .Windows XP Professional-7eefab4f.hlog doesn't exist.
2017-08-30T11:26:37.078+02:00| vmx| I125: MigrateBusMemPrealloc: BusMem preallocation begins.
2017-08-30T11:26:37.078+02:00| vmx| I125: MigrateBusMemPrealloc: BusMem preallocation completes.
2017-08-30T11:26:37.078+02:00| vmx| I125: TimeTracker host to guest rate conversion 59314797440328 @ 3400000000Hz -> 0 @ 3400000000Hz
2017-08-30T11:26:37.078+02:00| vmx| I125: TimeTracker host to guest rate conversion ((x * 2147483648) >> 31) + -59314797440328
2017-08-30T11:26:37.078+02:00| vmx| I125: Disabling TSC scaling since host does not support it.
2017-08-30T11:26:37.078+02:00| vmx| I125: TSC offsetting enabled.
2017-08-30T11:26:37.078+02:00| vmx| I125: timeTracker.globalProgressMaxAllowanceMS: 2000
2017-08-30T11:26:37.078+02:00| vmx| I125: timeTracker.globalProgressToAllowanceNS: 1000
2017-08-30T11:26:37.078+02:00| vmx| A100: ConfigDB: Setting ide0:0.redo = ""
2017-08-30T11:26:37.078+02:00| vmx| I125: DISK: OPEN ide0:0 'C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk' persistent R[]
2017-08-30T11:26:37.094+02:00| vmx| I125: FILE: FileLockScanDirectory discarding M45553.lck from C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk.lck': invalid executionID 5164-131484699338746354(vmware-vmx.exe).
2017-08-30T11:26:37.094+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [0]: "Windows XP Professional-s001.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [1]: "Windows XP Professional-s002.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [2]: "Windows XP Professional-s003.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [3]: "Windows XP Professional-s004.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [4]: "Windows XP Professional-s005.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [5]: "Windows XP Professional-s006.vmdk" (0xa)
2017-08-30T11:26:37.110+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [6]: "Windows XP Professional-s007.vmdk" (0xa)
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [7]: "Windows XP Professional-s008.vmdk" (0xa)
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [8]: "Windows XP Professional-s009.vmdk" (0xa)
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [9]: "Windows XP Professional-s010.vmdk" (0xa)
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-DSCPTR: Opened [10]: "Windows XP Professional-s011.vmdk" (0xa)
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-LINK : Opened 'C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk' (0xa): twoGbMaxExtentSparse, 83886080 sectors / 40 GB.
2017-08-30T11:26:37.125+02:00| vmx| I125: DISKLIB-LIB : Opened "C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk" (flags 0xa, type twoGbMaxExtentSparse).
2017-08-30T11:26:37.125+02:00| vmx| I125: DiskGetGeometry: Reading of disk partition table
2017-08-30T11:26:37.125+02:00| vmx| I125: DISK: Disk 'C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk' has UUID '60 00 c2 97 38 29 05 70-57 96 8c 57 41 11 82 85'
2017-08-30T11:26:37.125+02:00| vmx| I125: DISK: OPEN 'C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk' Geo (83220/16/63) BIOS Geo (5221/255/63)
2017-08-30T11:26:37.141+02:00| vmx| I125: DISKUTILWIN32: DiskUtilW32IsATASSDDevice: Reported rotation rate = 1
2017-08-30T11:26:37.157+02:00| vmx| I125: DISKUTILWIN32: DiskUtilW32IsATASSDDevice: Reported rotation rate = 1
2017-08-30T11:26:37.172+02:00| vmx| I125: DISKUTILWIN32: DiskUtilW32IsATASSDDevice: Reported rotation rate = 1
2017-08-30T11:26:37.172+02:00| vmx| I125: DISK: DiskConfigureVirtualSSD: Disk 'ide0:0' identified as Virtual SSD device.
2017-08-30T11:26:37.172+02:00| vmx| I125: DISK: Opening disks took 95 ms.
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Virtual Hub' backend
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Generic' backend
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Virtual HID' backend
2017-08-30T11:26:37.172+02:00| vmx| I125: hread 6924 6160VTHREAD start thread 11 "sensorThread" host id 6924
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Remote Device' backend
2017-08-30T11:26:37.172+02:00| vmx| I125: RemoteUSBVMX: Retrieved hostId [96 6b e4 4b ef 4b 2a b9-dd 49 88 d7 f6 e2 3a d9]
2017-08-30T11:26:37.172+02:00| vmx| I125: RemoteUSBVMX: Protocol version min:15 current:16
2017-08-30T11:26:37.172+02:00| vmx| I125: RemoteUSBVMX: no delay setting is TRUE.
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Virtual Mass Storage' backend
2017-08-30T11:26:37.172+02:00| vmx| I125: USB: Initializing 'Virtual CCID' backend
2017-08-30T11:26:37.188+02:00| vmx| I125: hread 9944 6160USB: Initializing 'Virtual Bluetooth' backend
2017-08-30T11:26:37.188+02:00| vmx| I125: USB: Initializing 'Virtual Audio' backend
2017-08-30T11:26:37.188+02:00| vmx| I125: USB: Initializing 'Virtual Video' backend
2017-08-30T11:26:37.188+02:00| usbCCIDEnumCards| I125: VTHREAD start thread 12 "usbCCIDEnumCards" host id 9944
2017-08-30T11:26:37.188+02:00| usbCCIDEnumCards| I125: USB-CCID: Card enum thread created.
2017-08-30T11:26:37.188+02:00| vmx| I125: USBGW: Skipping disk backing for file (C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmx).
2017-08-30T11:26:37.188+02:00| vmx| I125: USBGW: Skipping disk backing for file (C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmdk).
2017-08-30T11:26:37.203+02:00| vmx| I125: USBGW: Skipping disk backing for file (C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmsd).
2017-08-30T11:26:37.203+02:00| vmx| I125: USBGW: Skipping disk backing for file (C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.nvram).
2017-08-30T11:26:37.203+02:00| vmx| I125: MKS PowerOn
2017-08-30T11:26:37.203+02:00| vmx| I125: hread 6940 6160VTHREAD start thread 2 "mks" host id 6940
2017-08-30T11:26:37.203+02:00| mks| I125: MKS thread is alive
2017-08-30T11:26:37.203+02:00| mks| I125: SOUNDLIB: Creating the Wave sound backend.
2017-08-30T11:26:37.203+02:00| mks| I125: hread 11612 6160VTHREAD start thread 13 "mouse" host id 11612
2017-08-30T11:26:37.203+02:00| mks| I125: hread 13316 6160VTHREAD start thread 14 "kbh" host id 13316
2017-08-30T11:26:37.203+02:00| mks| I125: MKS Win32: Registering top level window (0x1a02d6) to receive session change notification.
2017-08-30T11:26:37.203+02:00| mks| I125: MKS-RenderMain: RenderMain: PowerOn allowed MKSBasicOps
2017-08-30T11:26:37.203+02:00| mks| I125: MKS-RenderMain: Starting MKSBasicOps
2017-08-30T11:26:37.203+02:00| mks| I125: KHBKL: Unable to parse keystring at: ''
2017-08-30T11:26:37.203+02:00| mks| I125: MKS-RemoteMgr: Set default display name: Windows XP Professional
2017-08-30T11:26:37.203+02:00| mks| I125: MKS-RemoteMgr: Loading VNC Configuration from VM config file
2017-08-30T11:26:37.203+02:00| mks| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:ProgramDataVMware): Unknown error 183 (0xb7) (183)
2017-08-30T11:26:37.203+02:00| vmx| I125: VLANCE: send cluster threshold is 80, size = 2 recalcInterval is 2 ticks
2017-08-30T11:26:37.203+02:00| vmx| I125: VMXNET: send cluster threshold is 80, size = 2 recalcInterval is 2 ticks, dontClusterSize is 128
2017-08-30T11:26:37.203+02:00| vmx| I125: Chipset version: 0x13
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge4.pciSlotNumber = "-1"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge5.pciSlotNumber = "-1"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge6.pciSlotNumber = "-1"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge7.pciSlotNumber = "-1"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge4.pciSlotNumber = "21"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge5.pciSlotNumber = "22"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge6.pciSlotNumber = "23"
2017-08-30T11:26:37.203+02:00| vmx| A100: ConfigDB: Setting pciBridge7.pciSlotNumber = "24"
2017-08-30T11:26:37.203+02:00| vmx| I125: FILE: FileDeletionRetry: Non-retriable error encountered (C:Users ipogDocumentsVirtual MachinesWindows XP ProfessionalWindows XP Professional.vmx~): Unknown error 2 (0x2) (2)
2017-08-30T11:26:37.219+02:00| vmx| I125: DISKUTIL: ide0:0 : capacity=83886080 logical sector size=512
2017-08-30T11:26:37.219+02:00| vmx| I125: SCSI DEVICE (ide0:0): Computed value of ide0:0.useBounceBuffers: default
2017-08-30T11:26:37.219+02:00| vmx| I125: DISKUTIL: ide0:0 : geometry=5221/255/63
2017-08-30T11:26:37.219+02:00| vmx| I125: SCSI DEVICE (ide1:0): Computed value of ide1:0.useBounceBuffers: default
2017-08-30T11:26:37.219+02:00| vmx| I125: DISKUTIL: ide1:0 : capacity=0 logical sector size=2048
2017-08-30T11:26:37.219+02:00| vmx| I125: DISKUTIL: ide1:0 : geometry=0/0/0
2017-08-30T11:26:37.219+02:00| vmx| I125: SCSI0: UNTAGGED commands will be converted to ORDER tags.
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA: Maximum display topology 3840x1920.
2017-08-30T11:26:37.219+02:00| vmx| I125: Ignoring svga.vramSize value in config file because svga.autoDetect is enabled.
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA-GFB: Initial gfbSize=4194304
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA: Number of displays 2
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA: Truncated maximum resolution to VRAM size: 4194304 bytes VRAM, 1176x885 Max Resolution
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA: FIFO capabilities 0x0000077f
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA: Device capabilities 0x0dff83e2
2017-08-30T11:26:37.219+02:00| vmx| I125: SVGA3dCaps: host, at power on: 3d disabled
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 0]: 0x00000000 (3D)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 1]: 0x00000000 (MAX_LIGHTS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 2]: 0x00000000 (MAX_TEXTURES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 3]: 0x00000000 (MAX_CLIP_PLANES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 4]: 0x00000000 (VERTEX_SHADER_VERSION)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 5]: 0x00000000 (VERTEX_SHADER)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 6]: 0x00000000 (FRAGMENT_SHADER_VERSION)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 7]: 0x00000000 (FRAGMENT_SHADER)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 8]: 0x00000000 (MAX_RENDER_TARGETS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 9]: 0x00000000 (S23E8_TEXTURES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 10]: 0x00000000 (S10E5_TEXTURES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 11]: 0x00000000 (MAX_FIXED_VERTEXBLEND)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 12]: 0x00000000 (D16_BUFFER_FORMAT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 13]: 0x00000000 (D24S8_BUFFER_FORMAT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 14]: 0x00000000 (D24X8_BUFFER_FORMAT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 15]: 0x00000000 (QUERY_TYPES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 16]: 0x00000000 (TEXTURE_GRADIENT_SAMPLING)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 17]: 0.000000 (MAX_POINT_SIZE)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 18]: 0x00000000 (MAX_SHADER_TEXTURES)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 19]: 0x00001000 (MAX_TEXTURE_WIDTH)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 20]: 0x00001000 (MAX_TEXTURE_HEIGHT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 21]: 0x00000000 (MAX_VOLUME_EXTENT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 22]: 0x00000000 (MAX_TEXTURE_REPEAT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 23]: 0x00000000 (MAX_TEXTURE_ASPECT_RATIO)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 24]: 0x00000000 (MAX_TEXTURE_ANISOTROPY)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 25]: 0x00000000 (MAX_PRIMITIVE_COUNT)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 26]: 0x00000000 (MAX_VERTEX_INDEX)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 27]: 0x00000000 (MAX_VERTEX_SHADER_INSTRUCTIONS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 28]: 0x00000000 (MAX_FRAGMENT_SHADER_INSTRUCTIONS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 29]: 0x00000000 (MAX_VERTEX_SHADER_TEMPS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 30]: 0x00000000 (MAX_FRAGMENT_SHADER_TEMPS)
2017-08-30T11:26:37.219+02:00| vmx| I125: cap[ 31]: 0x00000000 (TEXTURE_OPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 32]: 0x00000000 (SURFACEFMT_X8R8G8B8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 33]: 0x00000000 (SURFACEFMT_A8R8G8B8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 34]: 0x00000000 (SURFACEFMT_A2R10G10B10)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 35]: 0x00000000 (SURFACEFMT_X1R5G5B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 36]: 0x00000000 (SURFACEFMT_A1R5G5B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 37]: 0x00000000 (SURFACEFMT_A4R4G4B4)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 38]: 0x00000000 (SURFACEFMT_R5G6B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 39]: 0x00000000 (SURFACEFMT_LUMINANCE16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 40]: 0x00000000 (SURFACEFMT_LUMINANCE8_ALPHA8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 41]: 0x00000000 (SURFACEFMT_ALPHA8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 42]: 0x00000000 (SURFACEFMT_LUMINANCE8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 43]: 0x00000000 (SURFACEFMT_Z_D16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 44]: 0x00000000 (SURFACEFMT_Z_D24S8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 45]: 0x00000000 (SURFACEFMT_Z_D24X8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 46]: 0x00000000 (SURFACEFMT_DXT1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 47]: 0x00000000 (SURFACEFMT_DXT2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 48]: 0x00000000 (SURFACEFMT_DXT3)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 49]: 0x00000000 (SURFACEFMT_DXT4)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 50]: 0x00000000 (SURFACEFMT_DXT5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 51]: 0x00000000 (SURFACEFMT_BUMPX8L8V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 52]: 0x00000000 (SURFACEFMT_A2W10V10U10)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 53]: 0x00000000 (SURFACEFMT_BUMPU8V8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 54]: 0x00000000 (SURFACEFMT_Q8W8V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 55]: 0x00000000 (SURFACEFMT_CxV8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 56]: 0x00000000 (SURFACEFMT_R_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 57]: 0x00000000 (SURFACEFMT_R_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 58]: 0x00000000 (SURFACEFMT_RG_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 59]: 0x00000000 (SURFACEFMT_RG_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 60]: 0x00000000 (SURFACEFMT_ARGB_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 61]: 0x00000000 (SURFACEFMT_ARGB_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 62]: 0x00000000 (MISSING62)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 63]: 0x00000000 (MAX_VERTEX_SHADER_TEXTURES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 64]: 0x00000000 (MAX_SIMULTANEOUS_RENDER_TARGETS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 65]: 0x00000000 (SURFACEFMT_V16U16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 66]: 0x00000000 (SURFACEFMT_G16R16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 67]: 0x00000000 (SURFACEFMT_A16B16G16R16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 68]: 0x00000000 (SURFACEFMT_UYVY)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 69]: 0x00000000 (SURFACEFMT_YUY2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 70]: 0x00000000 (MULTISAMPLE_NONMASKABLESAMPLES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 71]: 0x00000000 (MULTISAMPLE_MASKABLESAMPLES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 72]: 0x00000000 (ALPHATOCOVERAGE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 73]: 0x00000000 (SUPERSAMPLE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 74]: 0x00000000 (AUTOGENMIPMAPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 75]: 0x00000000 (SURFACEFMT_NV12)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 76]: 0x00000000 (SURFACEFMT_AYUV)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 77]: 0x00000000 (MAX_CONTEXT_IDS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 78]: 0x00000000 (MAX_SURFACE_IDS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 79]: 0x00000000 (SURFACEFMT_Z_DF16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 80]: 0x00000000 (SURFACEFMT_Z_DF24)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 81]: 0x00000000 (SURFACEFMT_Z_D24S8_INT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 82]: 0x00000000 (SURFACEFMT_ATI1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 83]: 0x00000000 (SURFACEFMT_ATI2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 84]: 0x00000000 (DEAD1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 85]: 0x00000000 (VIDEO_DECODE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 86]: 0x00000000 (VIDEO_PROCESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 87]: 0x00000000 (LINE_AA)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 88]: 0x00000000 (LINE_STIPPLE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 89]: 0.000000 (MAX_LINE_WIDTH)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 90]: 0.000000 (MAX_AA_LINE_WIDTH)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 91]: 0x00000000 (SURFACEFMT_YV12)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 92]: 0x00000000 (LOGICOPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 93]: 0x00000001 (TS_COLOR_KEY)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 94]: 0x00000000 (DEAD2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 95]: 0x00000000 (DXCONTEXT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 96]: 0x00000000 (MAX_TEXTURE_ARRAY_SIZE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 97]: 0x00000000 (DX_MAX_VERTEXBUFFERS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 98]: 0x00000000 (DX_MAX_CONSTANT_BUFFERS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 99]: 0x00000000 (DX_PROVOKING_VERTEX)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[100]: 0x00000000 (DXFMT_X8R8G8B8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[101]: 0x00000000 (DXFMT_A8R8G8B8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[102]: 0x00000000 (DXFMT_R5G6B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[103]: 0x00000000 (DXFMT_X1R5G5B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[104]: 0x00000000 (DXFMT_A1R5G5B5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[105]: 0x00000000 (DXFMT_A4R4G4B4)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[106]: 0x00000000 (DXFMT_Z_D32)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[107]: 0x00000000 (DXFMT_Z_D16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[108]: 0x00000000 (DXFMT_Z_D24S8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[109]: 0x00000000 (DXFMT_Z_D15S1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[110]: 0x00000000 (DXFMT_LUMINANCE8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[111]: 0x00000000 (DXFMT_LUMINANCE4_ALPHA4)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[112]: 0x00000000 (DXFMT_LUMINANCE16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[113]: 0x00000000 (DXFMT_LUMINANCE8_ALPHA8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[114]: 0x00000000 (DXFMT_DXT1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[115]: 0x00000000 (DXFMT_DXT2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[116]: 0x00000000 (DXFMT_DXT3)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[117]: 0x00000000 (DXFMT_DXT4)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[118]: 0x00000000 (DXFMT_DXT5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[119]: 0x00000000 (DXFMT_BUMPU8V8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[120]: 0x00000000 (DXFMT_BUMPL6V5U5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[121]: 0x00000000 (DXFMT_BUMPX8L8V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[122]: 0x00000000 (DXFMT_FORMAT_DEAD1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[123]: 0x00000000 (DXFMT_ARGB_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[124]: 0x00000000 (DXFMT_ARGB_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[125]: 0x00000000 (DXFMT_A2R10G10B10)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[126]: 0x00000000 (DXFMT_V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[127]: 0x00000000 (DXFMT_Q8W8V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[128]: 0x00000000 (DXFMT_CxV8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[129]: 0x00000000 (DXFMT_X8L8V8U8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[130]: 0x00000000 (DXFMT_A2W10V10U10)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[131]: 0x00000000 (DXFMT_ALPHA8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[132]: 0x00000000 (DXFMT_R_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[133]: 0x00000000 (DXFMT_R_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[134]: 0x00000000 (DXFMT_RG_S10E5)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[135]: 0x00000000 (DXFMT_RG_S23E8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[136]: 0x00000000 (DXFMT_BUFFER)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[137]: 0x00000000 (DXFMT_Z_D24X8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[138]: 0x00000000 (DXFMT_V16U16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[139]: 0x00000000 (DXFMT_G16R16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[140]: 0x00000000 (DXFMT_A16B16G16R16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[141]: 0x00000000 (DXFMT_UYVY)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[142]: 0x00000000 (DXFMT_YUY2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[143]: 0x00000000 (DXFMT_NV12)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[144]: 0x00000000 (DXFMT_AYUV)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[145]: 0x00000000 (DXFMT_R32G32B32A32_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[146]: 0x00000000 (DXFMT_R32G32B32A32_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[147]: 0x00000000 (DXFMT_R32G32B32A32_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[148]: 0x00000000 (DXFMT_R32G32B32_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[149]: 0x00000000 (DXFMT_R32G32B32_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[150]: 0x00000000 (DXFMT_R32G32B32_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[151]: 0x00000000 (DXFMT_R32G32B32_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[152]: 0x00000000 (DXFMT_R16G16B16A16_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[153]: 0x00000000 (DXFMT_R16G16B16A16_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[154]: 0x00000000 (DXFMT_R16G16B16A16_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[155]: 0x00000000 (DXFMT_R16G16B16A16_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[156]: 0x00000000 (DXFMT_R32G32_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[157]: 0x00000000 (DXFMT_R32G32_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[158]: 0x00000000 (DXFMT_R32G32_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[159]: 0x00000000 (DXFMT_R32G8X24_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[160]: 0x00000000 (DXFMT_D32_FLOAT_S8X24_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[161]: 0x00000000 (DXFMT_R32_FLOAT_X8X24_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[162]: 0x00000000 (DXFMT_X32_TYPELESS_G8X24_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[163]: 0x00000000 (DXFMT_R10G10B10A2_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[164]: 0x00000000 (DXFMT_R10G10B10A2_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[165]: 0x00000000 (DXFMT_R11G11B10_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[166]: 0x00000000 (DXFMT_R8G8B8A8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[167]: 0x00000000 (DXFMT_R8G8B8A8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[168]: 0x00000000 (DXFMT_R8G8B8A8_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[169]: 0x00000000 (DXFMT_R8G8B8A8_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[170]: 0x00000000 (DXFMT_R8G8B8A8_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[171]: 0x00000000 (DXFMT_R16G16_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[172]: 0x00000000 (DXFMT_R16G16_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[173]: 0x00000000 (DXFMT_R16G16_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[174]: 0x00000000 (DXFMT_R32_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[175]: 0x00000000 (DXFMT_D32_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[176]: 0x00000000 (DXFMT_R32_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[177]: 0x00000000 (DXFMT_R32_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[178]: 0x00000000 (DXFMT_R24G8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[179]: 0x00000000 (DXFMT_D24_UNORM_S8_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[180]: 0x00000000 (DXFMT_R24_UNORM_X8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[181]: 0x00000000 (DXFMT_X24_TYPELESS_G8_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[182]: 0x00000000 (DXFMT_R8G8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[183]: 0x00000000 (DXFMT_R8G8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[184]: 0x00000000 (DXFMT_R8G8_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[185]: 0x00000000 (DXFMT_R8G8_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[186]: 0x00000000 (DXFMT_R16_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[187]: 0x00000000 (DXFMT_R16_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[188]: 0x00000000 (DXFMT_R16_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[189]: 0x00000000 (DXFMT_R16_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[190]: 0x00000000 (DXFMT_R16_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[191]: 0x00000000 (DXFMT_R8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[192]: 0x00000000 (DXFMT_R8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[193]: 0x00000000 (DXFMT_R8_UINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[194]: 0x00000000 (DXFMT_R8_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[195]: 0x00000000 (DXFMT_R8_SINT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[196]: 0x00000000 (DXFMT_P8)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[197]: 0x00000000 (DXFMT_R9G9B9E5_SHAREDEXP)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[198]: 0x00000000 (DXFMT_R8G8_B8G8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[199]: 0x00000000 (DXFMT_G8R8_G8B8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[200]: 0x00000000 (DXFMT_BC1_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[201]: 0x00000000 (DXFMT_BC1_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[202]: 0x00000000 (DXFMT_BC2_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[203]: 0x00000000 (DXFMT_BC2_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[204]: 0x00000000 (DXFMT_BC3_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[205]: 0x00000000 (DXFMT_BC3_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[206]: 0x00000000 (DXFMT_BC4_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[207]: 0x00000000 (DXFMT_ATI1)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[208]: 0x00000000 (DXFMT_BC4_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[209]: 0x00000000 (DXFMT_BC5_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[210]: 0x00000000 (DXFMT_ATI2)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[211]: 0x00000000 (DXFMT_BC5_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[212]: 0x00000000 (DXFMT_R10G10B10_XR_BIAS_A2_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[213]: 0x00000000 (DXFMT_B8G8R8A8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[214]: 0x00000000 (DXFMT_B8G8R8A8_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[215]: 0x00000000 (DXFMT_B8G8R8X8_TYPELESS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[216]: 0x00000000 (DXFMT_B8G8R8X8_UNORM_SRGB)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[217]: 0x00000000 (DXFMT_Z_DF16)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[218]: 0x00000000 (DXFMT_Z_DF24)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[219]: 0x00000000 (DXFMT_Z_D24S8_INT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[220]: 0x00000000 (DXFMT_YV12)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[221]: 0x00000000 (DXFMT_R32G32B32A32_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[222]: 0x00000000 (DXFMT_R16G16B16A16_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[223]: 0x00000000 (DXFMT_R16G16B16A16_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[224]: 0x00000000 (DXFMT_R32G32_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[225]: 0x00000000 (DXFMT_R10G10B10A2_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[226]: 0x00000000 (DXFMT_R8G8B8A8_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[227]: 0x00000000 (DXFMT_R16G16_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[228]: 0x00000000 (DXFMT_R16G16_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[229]: 0x00000000 (DXFMT_R16G16_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[230]: 0x00000000 (DXFMT_R32_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[231]: 0x00000000 (DXFMT_R8G8_SNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[232]: 0x00000000 (DXFMT_R16_FLOAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[233]: 0x00000000 (DXFMT_D16_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[234]: 0x00000000 (DXFMT_A8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[235]: 0x00000000 (DXFMT_BC1_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[236]: 0x00000000 (DXFMT_BC2_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[237]: 0x00000000 (DXFMT_BC3_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[238]: 0x00000000 (DXFMT_B5G6R5_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[239]: 0x00000000 (DXFMT_B5G5R5A1_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[240]: 0x00000000 (DXFMT_B8G8R8A8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[241]: 0x00000000 (DXFMT_B8G8R8X8_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[242]: 0x00000000 (DXFMT_BC4_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[243]: 0x00000000 (DXFMT_BC5_UNORM)
2017-08-30T11:26:37.235+02:00| vmx| I125: SVGA3dCaps: guest, compatibility level: No-Clamping
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 0]: 0x00000000 (3D)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 1]: 0x00000000 (MAX_LIGHTS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 2]: 0x00000000 (MAX_TEXTURES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 3]: 0x00000000 (MAX_CLIP_PLANES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 4]: 0x00000000 (VERTEX_SHADER_VERSION)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 5]: 0x00000000 (VERTEX_SHADER)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 6]: 0x00000000 (FRAGMENT_SHADER_VERSION)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 7]: 0x00000000 (FRAGMENT_SHADER)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 8]: 0x00000000 (MAX_RENDER_TARGETS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 9]: 0x00000000 (S23E8_TEXTURES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 10]: 0x00000000 (S10E5_TEXTURES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 11]: 0x00000000 (MAX_FIXED_VERTEXBLEND)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 12]: 0x00000000 (D16_BUFFER_FORMAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 13]: 0x00000000 (D24S8_BUFFER_FORMAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 14]: 0x00000000 (D24X8_BUFFER_FORMAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 15]: 0x00000000 (QUERY_TYPES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 16]: 0x00000000 (TEXTURE_GRADIENT_SAMPLING)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 17]: 0.000000 (MAX_POINT_SIZE)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 18]: 0x00000000 (MAX_SHADER_TEXTURES)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 19]: 0x00001000 (MAX_TEXTURE_WIDTH)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 20]: 0x00001000 (MAX_TEXTURE_HEIGHT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 21]: 0x00000000 (MAX_VOLUME_EXTENT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 22]: 0x00000000 (MAX_TEXTURE_REPEAT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 23]: 0x00000000 (MAX_TEXTURE_ASPECT_RATIO)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 24]: 0x00000000 (MAX_TEXTURE_ANISOTROPY)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 25]: 0x00000000 (MAX_PRIMITIVE_COUNT)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 26]: 0x00000000 (MAX_VERTEX_INDEX)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 27]: 0x00000000 (MAX_VERTEX_SHADER_INSTRUCTIONS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 28]: 0x00000000 (MAX_FRAGMENT_SHADER_INSTRUCTIONS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 29]: 0x00000000 (MAX_VERTEX_SHADER_TEMPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 30]: 0x00000000 (MAX_FRAGMENT_SHADER_TEMPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 31]: 0x00000000 (TEXTURE_OPS)
2017-08-30T11:26:37.235+02:00| vmx| I125: cap[ 93]: 0x00000000 (TS_COLOR_KEY)
2017-08-30T11:26:37.235+02:00| vmx| I125: hread 17448 6160USB: Initializing 'UHCI' host controller
2017-08-30T11:26:37.235+02:00| svga| I125: VTHREAD start thread 1 "svga" host id 17448
2017-08-30T11:26:37.235+02:00| vmx| A100: ConfigDB: Setting usb:0.present = "TRUE"
2017-08-30T11:26:37.235+02:00| vmx| A100: ConfigDB: Setting usb:0.deviceType = "hid"
2017-08-30T11:26:37.235+02:00| vmx| A100: ConfigDB: Setting usb:0.port = "0"
2017-08-30T11:26:37.235+02:00| vmx| A100: ConfigDB: Setting usb:0.parent = "-1"
2017-08-30T11:26:37.250+02:00| vmx| A100: ConfigDB: Setting usb:1.speed = "2"
2017-08-30T11:26:37.250+02:00| vmx| I125: Ethernet0 MAC Address: 00:0c:29:47:80:ab
2017-08-30T11:26:37.250+02:00| vmx| I125: USB: Initializing 'EHCI' host controller
2017-08-30T11:26:37.250+02:00| vmx| A100: ConfigDB: Setting vmci0.id = "2044499865"
2017-08-30T11:26:37.250+02:00| vmx| I125: WORKER: Creating new group with numThreads=1 (23)
2017-08-30T11:26:37.250+02:00| vmx| I125: DISKUTIL: ide0:0 : max toolsVersion = 10252, type = 1
2017-08-30T11:26:37.250+02:00| vmx| I125: TOOLS setting legacy tools version to '10252' type 1, manifest status is 9
2017-08-30T11:26:37.250+02:00| vmx| I125: TOOLS INSTALL initializing state to IDLE on power on.
2017-08-30T11:26:37.250+02:00| Worker#0| I125: ToolsISO: open of C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig failed: Could not find the file
2017-08-30T11:26:37.250+02:00| Worker#0| I125: ToolsISO: Unable to read signature file 'C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig', ignoring.
2017-08-30T11:26:37.266+02:00| Worker#0| I125: ToolsISO: Selected Tools ISO 'winPreVista.iso' for 'winxppro' guest.
2017-08-30T11:26:37.266+02:00| Worker#0| I125: GetHostManifests: Extracting the manifest file.
2017-08-30T11:26:37.266+02:00| vmx| I125: FeatureCompat: No VM masks.
2017-08-30T11:26:37.266+02:00| vmx| I125: MonPmc: ctrBase 0xc0010004 selBase 0xc0010000/1 PGC 0/0 SMM 0 drain 0 AMD 1
2017-08-30T11:26:37.266+02:00| vmx| I125+ MonPmc: gen counters num: 0 width 48 write width 48
2017-08-30T11:26:37.266+02:00| vmx| I125+ MonPmc: fix counters num: 0 width 0
2017-08-30T11:26:37.266+02:00| vmx| I125+ MonPmc: unavailable counters: 0
2017-08-30T11:26:37.266+02:00| Worker#0| I125: GetHostManifests: Done extracting the manifest file.
2017-08-30T11:26:37.266+02:00| Worker#0| I125: ToolsVersionGetStatusWorkerThread: Tools status 3 derived from environment
2017-08-30T11:26:37.266+02:00| vmx| I125: guestCpuFeatures = 0x307f
2017-08-30T11:26:37.266+02:00| vmx| A100: ConfigDB: Setting monitor.phys_bits_used = "42"
2017-08-30T11:26:37.266+02:00| vmx| I125: Full guest CPUID with differences from hostCPUID highlighted.
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest vendor: AuthenticAMD
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest family: 0x17 model: 0x1 stepping: 0x1
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest codename: Unknown
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest name: AMD Ryzen 7 1700X Eight-Core Processor
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID level eaxIn, ecxIn: eax ebx ecx edx
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000000, 0: 0x0000000d 0x68747541 0x444d4163 0x69746e65
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000001, 0: 0x00800f11 0x00020800 0xf6f83203 0x178bfbff
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 00000001, 0: 0x00800f11 0x00100800 0x7ed8320b 0x178bfbff
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000002, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000003, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 1: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 2: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 5: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000004, 6: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000006, 0: 0x00000004 0x00000000 0x00000001 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000007, 0: 0x00000000 0x001c01a9 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 00000007, 0: 0x00000000 0x209c01a9 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000a, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000b, 0: 0x00000000 0x00000001 0x00000100 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 0000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000b, 1: 0x00000001 0x00000002 0x00000201 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 0: 0x00000007 0x00000340 0x00000340 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1: 0x00000001 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 0000000d, 1: 0x0000000f 0x00000340 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2: 0x00000100 0x00000240 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 5: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 6: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 7: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 8: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 9: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 10: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 11: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 12: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 13: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 14: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 15: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 16: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 17: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 18: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 19: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 20: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 21: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 22: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 23: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 24: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 25: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 26: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 27: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 28: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 29: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 30: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 31: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 32: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 33: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 34: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 35: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 36: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 37: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 38: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 39: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3a: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3b: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3c: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3d: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3e: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3f: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 0000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000010, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000011, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 00000012, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000000, 0: 0x40000010 0x61774d56 0x4d566572 0x65726177
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000001, 0: 0x31237648 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000002, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000003, 0: 0x00000262 0x00000000 0x00000000 0x00000508
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000004, 0: 0x00000020 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000005, 0: 0xffffffff 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000006, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000007, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000a, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 4000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 40000010, 0: 0x0033e140 0x000101d0 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000000, 0: 0x8000001f 0x68747541 0x444d4163 0x69746e65
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000001, 0: 0x00800f11 0x20000000 0x000003fb 0x2fd3fbff
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 80000001, 0: 0x00800f11 0x20000000 0x35c233ff 0x2fd3fbff
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000002, 0: 0x20444d41 0x657a7952 0x2037206e 0x30303731
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000003, 0: 0x69452058 0x2d746867 0x65726f43 0x6f725020
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000004, 0: 0x73736563 0x2020726f 0x20202020 0x00202020
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000005, 0: 0xff40ff40 0xff40ff40 0x20080140 0x40040140
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000006, 0: 0x26006400 0x66006400 0x02006140 0x00808140
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000007, 0: 0x00000000 0x00000000 0x00000000 0x00000100
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 80000007, 0: 0x00000000 0x0000001b 0x00000000 0x00006599
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000008, 0: 0x0000302a 0x00000007 0x00001001 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID *host level 80000008, 0: 0x00003030 0x00000007 0x0000400f 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000010, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000011, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000012, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000013, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000014, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000015, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000016, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000017, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000018, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 80000019, 0: 0xf040f040 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001a, 0: 0x00000003 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001b, 0: 0x000003ff 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 0: 0x00004121 0x01c0003f 0x0000003f 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 1: 0x00004122 0x00c0003f 0x000000ff 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 2: 0x00004143 0x01c0003f 0x000003ff 0x00000002
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 3: 0x0001c163 0x03c0003f 0x00001fff 0x00000001
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001e, 0: 0x00000000 0x00000100 0x00000000 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: guest vs. host CPUID guest level 8000001f, 0: 0x00000007 0x0000016f 0x0000000f 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: CPUID control desired.
2017-08-30T11:26:37.266+02:00| vmx| I125: Minimum ucode level: 0x00000000
2017-08-30T11:26:37.266+02:00| vmx| I125: VPMC: events will use hybrid freeze.
2017-08-30T11:26:37.266+02:00| vmx| I125: VPMC: gen counters: num 0 mask 0xffffffffffff
2017-08-30T11:26:37.266+02:00| vmx| I125: VPMC: hardware counters: 0
2017-08-30T11:26:37.266+02:00| vmx| I125: SVGA-GFB: Allocated gfbSize=4194304
2017-08-30T11:26:37.266+02:00| vmx| A100: ConfigDB: Setting vmotion.checkpointFBSize = "4194304"
2017-08-30T11:26:37.266+02:00| vmx| A100: ConfigDB: Setting vmotion.checkpointSVGAPrimarySize = "33554432"
2017-08-30T11:26:37.266+02:00| vmx| I125: SVGA-PCI: BAR gfbSize=134217728, fifoSize=8388608
2017-08-30T11:26:37.266+02:00| vmx| I125: SVGA: SVGA_REG_MEMORY_SIZE=4194304
2017-08-30T11:26:37.266+02:00| vmx| I125: SVGA: SVGA_REG_VRAM_SIZE=4194304
2017-08-30T11:26:37.266+02:00| vmx| I125: BusMemSampleSetUpStats: touched: initPct 75 pages 384000 : dirtied: initPct 75 pages 384000
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: caller 0 numvm 1 locked pages: num 1915 max 7264772
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: locked Page Limit: host 8078673 config 7325696 dynam 7272964
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: minmempct 50 timestamp 21281
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: VM 0 min 285926 max 541926 shares 512000 paged 221498 nonpaged 3697 anonymous 26229 locked 1915 touchedPct 75 dirtiedPct 75 timestamp 21281 vmResponsive is 1
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: locked 1915 target 541926 balloon 0 0 0 swapped 0 0 allocd 0 512 state 0 100
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: states: 0 1 : 1 0 : 2 0 : 3 0
2017-08-30T11:26:37.266+02:00| vmx| I125: MemSched: Balloon enabled 1 guestType 0 maxSize 0
2017-08-30T11:26:37.282+02:00| vmx| I125: FeatureCompat: Capabilities:
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.FFXSR = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.RDRAND = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.PDPE1GB = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.XSAVE = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.LM = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.MWAIT = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.RDSEED = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.MOVBE = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.EXTAPICSPC = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.MMXEXT = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.CR8AVAIL = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.AMD = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.ABM = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.XCR0_MASTER_YMM_H = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.FMA = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.AVX2 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.XSAVEOPT = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SSE4A = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SSSE3 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SSE3 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.NX = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SSE41 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.BMI2 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.AES = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.PCLMULQDQ = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.3DNPREFETCH = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.POPCNT = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.AVX = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.F16C = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.FSGSBASE = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.RDTSCP = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.LAHF64 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.MISALIGNED_SSE = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.CMPXCHG16B = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SMEP = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.ADX = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SSE42 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.BMI1 = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.SMAP = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: Capability Found: cpuid.XCR0_MASTER_SSE = 0x1
2017-08-30T11:26:37.282+02:00| vmx| I125: FeatureCompat: Requirements:
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SSE3 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.PCLMULQDQ - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SSSE3 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.FMA - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.CMPXCHG16B - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SSE41 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SSE42 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.MOVBE - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.POPCNT - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.AES - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.XSAVE - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.AVX - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.F16C - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.RDRAND - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.FSGSBASE - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.BMI1 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.AVX2 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SMEP - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.BMI2 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.RDSEED - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.ADX - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SMAP - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.XCR0_MASTER_SSE - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.XCR0_MASTER_YMM_H - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.XSAVEOPT - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.LAHF64 - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.EXTAPICSPC - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.CR8AVAIL - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.ABM - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.SSE4A - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.MISALIGNED_SSE - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.3DNPREFETCH - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.NX - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.MMXEXT - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.FFXSR - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.PDPE1GB - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.RDTSCP - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.LM - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: VM Features Required: cpuid.AMD - Bool:Min:1
2017-08-30T11:26:37.282+02:00| vmx| I125: TOOLS received request in VMX to set option 'enableDnD' -> '1'
2017-08-30T11:26:37.282+02:00| vmx| I125+ OvhdMem: Static (Power On) Overheads
2017-08-30T11:26:37.282+02:00| vmx| I125: reserved | used
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem excluded cur max avg | cur max avg
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MainMem : 512000 512000 - | - - -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxText : 6912 6912 - | - - -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxTextLibs : 15360 15360 - | - - -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Total excluded : 534272 534272 - | - - -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Actual maximum : 534272 | -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem paged cur max avg | cur max avg
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_KSTATS_vmm : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_STATS_vmm : 8 8 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_KSTATS_device : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_STATS_device : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_KSTATS_migrate : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_IOFilters : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_DiskLibMemUsed : 3075 3075 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaSurfaceData : 5 5 - | 1 1 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaRestoreBufferArray : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaSDirtyCache : 48 48 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaShaderTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaShaderText : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaContextCache : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaMobCache : 248 248 - | 24 24 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXRTViewTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXDSViewTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXSRViewTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXBlendStateTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXElementLayoutTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXDepthStencilTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXRasterizerStateTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXSamplerTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXContextTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXShaderTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXStreamOutTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SvgaDXQueryTable : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxAllocTrack : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxCallStackProf : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxGlobals : 10240 10240 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxGlobalsLibs : 3584 3584 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxHeap : 8704 8704 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxHeapFreeList : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMks : 33 33 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMks3d : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksGLRenderer : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksGLTransient : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksLLVM : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksScreenTemp : 69634 69634 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksVnc : 37712 37712 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksScreen : 65537 65537 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxMksSVGAVO : 4096 4096 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxPhysMemRingBuf : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxPhysMemErrPages : 10 10 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxFTCptOutputBuf : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxSLEntryBuf : 128 128 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxThreadMks : 512 512 - | 512 512 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxThreadVmx : 512 512 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxThreadsVcpu : 1024 1024 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxThreadsWorker : 15872 15872 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VmxThreadSvga : 512 512 - | 512 512 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Total paged : 221498 221498 - | 1049 1049 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Actual maximum : 221498 | 1049
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem nonpaged cur max avg | cur max avg
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SharedArea : 89 89 - | 66 66 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_BusMemTraceBitmap : 18 18 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PFrame : 1147 1328 - | 1147 1147 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VProbe : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VIDE_KSEG : 16 16 - | 16 16 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VGA : 64 64 - | 64 64 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_BalloonMPN : 1 1 - | 1 1 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_P2MUpdateBuffer : 3 3 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_ServicesMPN : 2 2 - | 2 2 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_LocalApic : 4 4 - | 4 4 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_BusError : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VBIOS : 8 8 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VnicGuest : 16 16 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VnicMmap : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_TestDev : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_LSIBIOS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_LSIRings : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PCIPBIOS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PVSCSIBIOS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PVSCSIKickReg : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SAS1068BIOS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SBIOS : 16 16 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_AHCIBIOS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_FlashRam : 128 128 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SMM : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SVGAFB : 1024 1024 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_SVGAMEM : 64 512 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_HDAudioReg : 3 3 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_EHCIRegister : 1 1 - | 1 1 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_XhciRegister : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PhysMemDebug : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_HyperV : 2 2 - | 1 1 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_ExtCfg : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_HV : 13 13 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_HVIOBitmap : 3 3 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_HVMSRBitmap : 2 2 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VHVGuestMSRBitmap : 2 2 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_vhvCachedVMCS : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_vhvNestedAPIC : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PCIP : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_VMsafe : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonBootstrap : 5 5 - | 5 5 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonWired : 196 196 - | 196 196 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonLow : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonWiredNuma : 116 116 - | 116 116 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonNuma : 418 418 - | 296 296 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_MonOther : 136 136 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_PAEShadow : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_FTCpt : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdUser_NVDIMM : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Total nonpaged : 3516 4145 - | 1915 1915 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Actual maximum : 4145 | 1915
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem anonymous cur max avg | cur max avg
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Alloc : 316 316 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMemFrame : 2280 2471 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMemFramePGAR : 6 6 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMemTracePGAR : 2 2 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMem2MRegionPGAR : 9 9 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMemZapListMPN : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_MMU : 3100 3100 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Backmap : 8 8 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_ScratchAS : 648 648 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_MonTLB : 24 24 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_DT : 72 72 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_TCCoherency : 84 84 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_TC : 18436 18436 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_ChainInfo : 324 324 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Island : 8 8 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusMemScratchAS : 8 8 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_PlatformScratchAS : 5 5 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_HVNuma : 12 12 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_HV : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VHV : 12 12 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VNPTShadow : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VNPTShadowCache : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VNPTBackmap : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_SVMIDT : 4 4 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_CallStackProfAnon : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Numa : 42 42 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_NumaTextRodata : 222 222 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_NumaDataBss : 196 196 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_NumaLargeData : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_WiredNuma : 116 116 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_GPhysTraced : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_GPhysHWMMU : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_GPhysNoTrace : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BTScratchPage : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_PhysMemGart : 88 88 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_PhysMemErr : 9 9 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_TraceALot : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VIDE : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VMXNETWake : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_BusLogic : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Ahci : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_PVSCSIShadowRing : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_LSIRings : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_FTCptScratchAS : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_Hba : 0 0 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem OvhdMon_VProbe : 1 1 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Total anonymous : 26038 26229 - | 0 0 -
2017-08-30T11:26:37.282+02:00| vmx| I125: OvhdMem Actual maximum : 26229 | 0
2017-08-30T11:26:37.282+02:00| vmx| I125: VMMEM: Precise Reservation: 980MB (MainMem=2000MB)
2017-08-30T11:26:37.282+02:00| vmx| I125: Vix: [13112 mainDispatch.c:1073]: VMAutomation_PowerOn. Powering on.
2017-08-30T11:26:37.282+02:00| vmx| I125: VMX_PowerOn: ModuleTable_PowerOn = 1
2017-08-30T11:26:37.282+02:00| vmx| A100: ConfigDB: Setting cleanShutdown = "FALSE"
2017-08-30T11:26:37.282+02:00| vmx| A100: ConfigDB: Setting softPowerOff = "FALSE"
2017-08-30T11:26:37.282+02:00| vmx| I125: hread 17780 6160VTHREAD start thread 4 "vcpu-0" host id 17780
2017-08-30T11:26:37.282+02:00| vmx| I125: ToolsISO: open of C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig failed: Could not find the file
2017-08-30T11:26:37.282+02:00| vmx| I125: ToolsISO: Unable to read signature file 'C:Program Files (x86)VMwareVMware Workstationisoimages_manifest.txt.sig', ignoring.
2017-08-30T11:26:37.282+02:00| vmx| I125: ToolsISO: Selected Tools ISO 'winPreVista.iso' for 'winxppro' guest.
2017-08-30T11:26:37.282+02:00| vmx| I125: VMXVmdb_SetToolsVersionStatus: status value set to 'ok', 'current', install possible
2017-08-30T11:26:37.282+02:00| vcpu-0| I125: MonTimer APIC:0/0 vec: 0
2017-08-30T11:26:37.282+02:00| vcpu-0| I125: APIC: version = 0x10, max LVT = 5, LDR = 0x1000000, DFR = 0xfffffff
2017-08-30T11:26:37.282+02:00| vcpu-0| W115: MONITOR PANIC: vcpu-0:VERIFY vmcore/vmm/main/cpuid.c:386 bugNr=1036521
2017-08-30T11:26:37.282+02:00| vcpu-0| I125: Core dump with build build-5813279
2017-08-30T11:26:37.282+02:00| vcpu-0| W115: Writing monitor corefile "C:Users ipogDocumentsVirtual MachinesWindows XP Professionalvmmcores.gz"
2017-08-30T11:26:37.297+02:00| vcpu-0| W115: Dumping core for vcpu-0
2017-08-30T11:26:37.297+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:37.297+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddf05) Unknown error 998 (0x3e6)
2017-08-30T11:26:37.922+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:37.922+02:00| vcpu-0| W115: Dumping core for vcpu-1
2017-08-30T11:26:37.922+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:37.922+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddeff) Unknown error 998 (0x3e6)
2017-08-30T11:26:38.547+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:38.547+02:00| vcpu-0| W115: Dumping core for vcpu-2
2017-08-30T11:26:38.547+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:38.547+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddefe) Unknown error 998 (0x3e6)
2017-08-30T11:26:39.172+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:39.172+02:00| vcpu-0| W115: Dumping core for vcpu-3
2017-08-30T11:26:39.172+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:39.172+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddefa) Unknown error 998 (0x3e6)
2017-08-30T11:26:39.782+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:39.829+02:00| vcpu-0| I125: CoreDump_CoreDump: faking exception to get context
2017-08-30T11:26:39.829+02:00| vcpu-0| I125: CoreDump: Minidump file C:Users ipogDocumentsVirtual MachinesWindows XP Professionalvmware-vmx.dmp exists. Rotating ...
2017-08-30T11:26:39.844+02:00| vcpu-0| W115: CoreDump: Writing minidump to C:Users ipogDocumentsVirtual MachinesWindows XP Professionalvmware-vmx.dmp
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ff63f2a0000 size 0x0x01691000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x01415431 timestamp 0x59488eee
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:Program Files (x86)VMwareVMware Workstationx64vmware-vmx.exe
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 12.5.7.20721
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05fe0000 size 0x0x001db000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x001dd2f4 timestamp 0xa329d3a8
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 tdll.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.447
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb058e0000 size 0x0x000ae000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000ba9b8 timestamp 0xf5fa43df
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32kernel32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.296
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02e30000 size 0x0x00249000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00251760 timestamp 0x005405b5
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32KERNELBASE.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.502
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaeb880000 size 0x0x000a7000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000aedf6 timestamp 0x593677bf
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:Program FilesBitdefenderBitdefender Securityatcuf262824383465032704atcuf64.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 1.9.84.0
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05e30000 size 0x0x0014a000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0014c0a9 timestamp 0xd66f509b
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32user32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.0
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb034b0000 size 0x0x0001e000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002c288 timestamp 0xd9592a17
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32win32u.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05be0000 size 0x0x00027000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002d6de timestamp 0xefcc154c
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32gdi32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03320000 size 0x0x00188000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0018c93a timestamp 0x2e4a909f
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32gdi32full.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.413
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb031d0000 size 0x0x0009a000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0009c31a timestamp 0xd867caf3
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32msvcp_win.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb030d0000 size 0x0x000f6000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000f8df9 timestamp 0x5ba8b66e
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32ucrtbase.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb056e0000 size 0x0x00145000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0014bf01 timestamp 0xcf17fc6c
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32ole32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb036f0000 size 0x0x002f9000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0030878d timestamp 0x91412db8
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32combase.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03540000 size 0x0x00125000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x001251d1 timestamp 0xcf94c546
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 pcrt4.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb034d0000 size 0x0x0006a000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0006e6ae timestamp 0x3bbaa205
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32cryptPrimitives.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03d50000 size 0x0x00059000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00062381 timestamp 0xb4c11302
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32sechost.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05830000 size 0x0x000a1000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000a0077 timestamp 0x8e7c3351
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32advapi32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03c80000 size 0x0x0009d000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000a08ad timestamp 0x3280d1b7
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32msvcrt.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 7.0.15063.0
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb041f0000 size 0x0x01437000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0146b7f9 timestamp 0x944613c6
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32shell32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03080000 size 0x0x00049000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00049455 timestamp 0xbb524065
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32cfgmgr32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05c70000 size 0x0x000aa000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000ab70b timestamp 0xb7eb0e3a
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32SHCore.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02500000 size 0x0x006f3000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00700b1f timestamp 0xded631f2
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32windows.storage.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb039f0000 size 0x0x00051000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00050ac9 timestamp 0x166c812d
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32shlwapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb024e0000 size 0x0x00011000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0001ca85 timestamp 0xed031ad5
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32kernel.appcore.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02490000 size 0x0x0004c000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00059a98 timestamp 0xbc0704c4
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32powrprof.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02470000 size 0x0x00015000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00020f06 timestamp 0xc8e1d59a
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32profapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03db0000 size 0x0x0043b000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0044ef93 timestamp 0x5b73cf27
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32setupapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03670000 size 0x0x0006c000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0006aeaf timestamp 0x60cde072
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32ws2_32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03bc0000 size 0x0x000c0000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000bea89 timestamp 0xc76efb2b
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32oleaut32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.332
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02c00000 size 0x0x001c9000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x001c8cbd timestamp 0x27f585b8
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32crypt32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02450000 size 0x0x00011000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00011ae2 timestamp 0xc8896f56
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32msasn1.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x58d80000 size 0x0x000a3000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0009febb timestamp 0x57fb7ca9
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsWinSxSamd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9279_none_08e667efa83ba076msvcr90.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 9.0.30729.9279
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb00830000 size 0x0x00023000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002d19d timestamp 0x24ec155f
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32winmm.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffae8720000 size 0x0x0008c000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000911bd timestamp 0x05871a39
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32dsound.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf1ad0000 size 0x0x0003f000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0003c6de timestamp 0x94f161b1
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32WinSCard.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffafb080000 size 0x0x000d7000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000da987 timestamp 0x5a70786d
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32winhttp.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaff000000 size 0x0x00013000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00015c52 timestamp 0xf583d34a
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wtsapi32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb00540000 size 0x0x0002b000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00028fa7 timestamp 0x318335b4
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32WINMMBASE.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb00f90000 size 0x0x00028000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00025d32 timestamp 0xcc2b2861
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32devobj.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03d20000 size 0x0x0002d000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002bd92 timestamp 0xdd2e6bc9
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32imm32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb00c50000 size 0x0x00095000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0009238a timestamp 0x32d33af4
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32uxtheme.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x58570000 size 0x0x00244000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0023f163 timestamp 0x5897f482
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:Program Files (x86)VMwareVMware Workstationx64libeay32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 1.0.2.11
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf6fa0000 size 0x0x0005d000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0005a7fd timestamp 0x5897f48e
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:Program Files (x86)VMwareVMware Workstationx64ssleay32.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01f00000 size 0x0x00017000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000218b4 timestamp 0x867e8ea6
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32cryptsp.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01920000 size 0x0x00034000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000367ed timestamp 0x87674e0e
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 saenh.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02320000 size 0x0x00025000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002692f timestamp 0x17fe17fb
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32crypt.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01f20000 size 0x0x0000b000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000111cd timestamp 0xde95b0dc
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32CRYPTBASE.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02350000 size 0x0x00030000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0003283d timestamp 0x4ed5f018
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32sspicli.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01750000 size 0x0x00031000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00031add timestamp 0x1c48ce6a
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 tmarta.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01d00000 size 0x0x0005c000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0005d450 timestamp 0x279c60ce
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32mswsock.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01ae0000 size 0x0x000a4000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000af167 timestamp 0x4b63fa85
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32dnsapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb056d0000 size 0x0x00008000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00014149 timestamp 0x5e3fea14
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 si.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01aa0000 size 0x0x00037000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0003f628 timestamp 0x445de47c
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32IPHLPAPI.DLL
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf7f40000 size 0x0x0000a000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0000e2a1 timestamp 0x1faec3a4
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32 asadhlp.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb05630000 size 0x0x0009e000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000a5c1e timestamp 0x08d5a6ff
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32clbcatq.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 2001.12.10941.16384
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf7f30000 size 0x0x00010000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00014224 timestamp 0xa8949859
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wbemwbemprox.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf1f20000 size 0x0x00082000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0007febd timestamp 0x3a8a6fab
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wbemcomn.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaef9a0000 size 0x0x00014000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000163eb timestamp 0x0f06ed62
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wbemwbemsvc.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaeff80000 size 0x0x000f0000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000f2f5c timestamp 0xe706edd1
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wbemfastprox.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb059b0000 size 0x0x00008000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000052db timestamp 0x26b463dc
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32psapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf0190000 size 0x0x001a9000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00194edc timestamp 0xed6376f8
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32dbghelp.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.250
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb03a50000 size 0x0x00166000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00168f90 timestamp 0x6e750bce
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32msctf.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb01ea0000 size 0x0x00055000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00056e14 timestamp 0x6c7fa901
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32winsta.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaf6480000 size 0x0x00069000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000735b6 timestamp 0x1e7a418a
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32SensorsApi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: file version 10.0.15063.483
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaff580000 size 0x0x0000f000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0000e8c7 timestamp 0xab999dd1
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32SensorsUtilsV2.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffafc540000 size 0x0x0001d000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x00024861 timestamp 0x04fac2f0
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32SensorsNativeApi.V2.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaff0b0000 size 0x0x00196000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0019b38a timestamp 0x74650d36
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32propsys.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb02dd0000 size 0x0x00056000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0005cba7 timestamp 0xbffdf466
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32wintrust.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffb00800000 size 0x0x0002a000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x0002f77a timestamp 0xdd3bab06
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32dwmapi.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: including module base 0x0x7ffaefa40000 size 0x0x00029000
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: checksum 0x000259c5 timestamp 0xb0cf3869
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: image file C:WindowsSystem32dbgcore.dll
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 13112
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 13712
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 6060
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 14296
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 10248
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 15444
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 11500
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 6924
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 9388
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 9944
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 6940
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 11612
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 13316
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 17448
2017-08-30T11:26:40.016+02:00| vcpu-0| I125: CoreDump: Including thread 17780
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: Msg_Post: Error
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: [msg.log.error.unrecoverable] VMware Workstation unrecoverable error: (vcpu-0)
2017-08-30T11:26:40.063+02:00| vcpu-0| I125+ vcpu-0:VERIFY vmcore/vmm/main/cpuid.c:386 bugNr=1036521
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: [msg.panic.haveLog] A log file is available in "C:Users ipogDocumentsVirtual MachinesWindows XP Professionalvmware.log".
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: [msg.panic.requestSupport.withoutLog] You can request support.
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: [msg.panic.requestSupport.vmSupport.windowsOrLinux]
2017-08-30T11:26:40.063+02:00| vcpu-0| I125+ To collect data to submit to VMware support, choose "Collect Support Data" from the Help menu.
2017-08-30T11:26:40.063+02:00| vcpu-0| I125+ You can also run the "vm-support" script in the Workstation folder directly.
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: [msg.panic.response] We will respond on the basis of your support entitlement.
2017-08-30T11:26:40.063+02:00| vcpu-0| I125: ----------------------------------------
2017-08-30T11:26:47.718+02:00| vcpu-0| W115: Writing monitor corefile "C:Users ipogDocumentsVirtual MachinesWindows XP Professionalvmmcores.gz"
2017-08-30T11:26:47.734+02:00| vcpu-0| W115: Dumping core for vcpu-0
2017-08-30T11:26:47.734+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:47.734+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddf05) Unknown error 998 (0x3e6)
2017-08-30T11:26:48.359+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:48.359+02:00| vcpu-0| W115: Dumping core for vcpu-1
2017-08-30T11:26:48.359+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:48.359+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddeff) Unknown error 998 (0x3e6)
2017-08-30T11:26:48.984+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:48.984+02:00| vcpu-0| W115: Dumping core for vcpu-2
2017-08-30T11:26:48.984+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:48.984+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddefe) Unknown error 998 (0x3e6)
2017-08-30T11:26:49.625+02:00| vcpu-0| I125: End monitor coredump
2017-08-30T11:26:49.625+02:00| vcpu-0| W115: Dumping core for vcpu-3
2017-08-30T11:26:49.625+02:00| vcpu-0| I125: Beginning monitor coredump
2017-08-30T11:26:49.625+02:00| vcpu-0| I125: CoreDump error: Read, page 0x9 (0xddefa) Unknown error 998 (0x3e6)
2017-08-30T11:26:50.250+02:00| vcpu-0| I125: End monitor coredump
