<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Case M350 + Pentium G630 come HTPC]]></title><description><![CDATA[<p>Vi presento il mio nuovo HTPC.....</p>
<p>CASE: M350</p>
<p>PSU: Pico 120w + brick da 160</p>
<p>MB: Asrock H67 ITX</p>
<p>CPU: Pentium Sandy Bridge G630</p>
<p>DISSY: Dynatron Low Profile</p>
<p>RAM: 4Gb Kingston HyperX Blu Series ( però il banco è rosso bhooo )</p>
<p>HDD: 64Gb Crucial M4 + 1Tb Wd Scorpio BLue</p>
<p>Scheda Madre e case</p>
<p><a href="http://www.xtremeshack.com/scheda/159404_imag0156.jpg.html"><img src="http://www.xtremeshack.com/immagine/t159404_imag0156.jpg" alt="t159404_imag0156.jpg" /></a></p>
<p>Cpu dissy e ram montati</p>
<p><a href="http://www.xtremeshack.com/scheda/159405_imag0157.jpg.html"><img src="http://www.xtremeshack.com/immagine/t159405_imag0157.jpg" alt="t159405_imag0157.jpg" /></a></p>
<p>Spazio tra pico e Hard disk</p>
<p><a href="http://www.xtremeshack.com/scheda/159407_imag0159.jpg.html"><img src="http://www.xtremeshack.com/immagine/t159407_imag0159.jpg" alt="t159407_imag0159.jpg" /></a></p>
<p>SPazio dall'altro lato tra dissy e hard disk SSD ( non a caso ho posizionato il disco ssd sopra la cpu. Producendo meno calore di un disco meccanico l'ho ritenuto più adatto )</p>
<p><a href="http://www.xtremeshack.com/scheda/159395_imag0160.jpg.html"><img src="http://www.xtremeshack.com/immagine/t159395_imag0160.jpg" alt="t159395_imag0160.jpg" /></a></p>
<p>Foto dall'alto mentre installo windows setteven</p>
<p><a href="http://www.xtremeshack.com/scheda/159399_imag0164.jpg.html"><img src="http://www.xtremeshack.com/immagine/t159399_imag0164.jpg" alt="t159399_imag0164.jpg" /></a></p>
<p>Laterale durante l'installazione</p>
<p><a href="http://www.xtremeshack.com/scheda/159400_imag0165.jpg.html"><img src="http://www.xtremeshack.com/immagine/t159400_imag0165.jpg" alt="t159400_imag0165.jpg" /></a></p>
<p>Per chi non conoscesse il case ecco come sono posizionate le usb sotto il frontalino anteriore. Ho integrato il telecomando in questa maniera. Il telecomando + ricevitore USB è uno di quelli da 7 euro dalla baia. Ho smontato la scatolina intorno all'integrato del ricevitore IR e l'ho fissato al frontale del case nascondendolo dietro al frontalino. Essendo il frontalino bucato lascia passare il segnale tranquillamente</p>
<p><a href="http://www.xtremeshack.com/scheda/159398_imag0163.jpg.html"><img src="http://www.xtremeshack.com/immagine/t159398_imag0163.jpg" alt="t159398_imag0163.jpg" /></a></p>
<p>Dopo qualche giorno di test ho notato temperature un pò altine che portavano la ventola ad essere un pochino rumorosa. Ho smontato una ventolina da 40x40x10 da un vecchio box per hard disk. La ventola a 12V era anche fin troppo efficente ed anche rumorosa ho quindi ben pensato di farla andare a 7V.</p>
<p>Quindi ecco un piccolo magheggio con saldatore a stagno. Collegando la ventola in questo modo gira molto silenziosamente.</p>
<p><a href="http://www.xtremeshack.com/scheda/159402_imag0167.jpg.html"><img src="http://www.xtremeshack.com/immagine/t159402_imag0167.jpg" alt="t159402_imag0167.jpg" /></a></p>
<p>Ed ecco il posizionamento con biadesivo. Il flusso d'aria è in entrata che sembri far guadagnare gradi rispetto al contrario nei case piccoli.</p>
<p><a href="http://www.xtremeshack.com/scheda/159403_imag0168.jpg.html"><img src="http://www.xtremeshack.com/immagine/t159403_imag0168.jpg" alt="t159403_imag0168.jpg" /></a></p>
<p>Ed eccolo vicino al mio Zamzung da 40"</p>
<p><a href="http://www.xtremeshack.com/scheda/159401_imag0166.jpg.html"><img src="http://www.xtremeshack.com/immagine/t159401_imag0166.jpg" alt="t159401_imag0166.jpg" /></a></p>
<p>Conclusioni e consigli:</p>
<p>Il case in se stesso permette tranquillamente e comodamente di ospitare un disco ed una CPU discreta tipo un I3. Avendo posizionato il secondo disco ho ritenuto opportuno prendere una CPU più fresca. </p>
<p>Temperatura in IDLE intorno ai 40°-43° consumo 20W</p>
<p>Temperatura in riproduzione MKV 1080P da 15Gb 53° consumo 36W e carico CPU al 15%</p>
<p>Nel case è stata una fortuna aver montato solamente un banco in modo da aver più spazio per i cavi del secondo hard disk. Confermo ancora una volta che il layout della asrock in questione fa schifo in quanto il connettore ATX di alimentazione dove si va a collegare il pico è proprio sul bordo della MB. Quindi nei case piccoli sarebbe opportuno prendere in considerazione che subito vicino alla scheda madre c'è il case e il suo coperchio con gli agganci.</p>
<p>Nella parte software ho scelto naturalmente XBMC. All'inizio tutto ok poi quando cominciai a scorrere velocemente tra le cartelle con animazioni a valanga andava il tutto in freeze. Dopo 1000 prove sono giunto a conclusione che finchè non lo richiede la CPU usa la propria potenza. Quando richiede l'aiuto di una GPU va a cercare di default quella nello slot PCIex che naturalmente non c'è e si freeza il tutto. Quindi è importantissimo ricordarsi di impostare da BIOS che la GPU primaria è quella Onbard. Altra incazzatura atomica con XBMC all'avvio. Mettendolo in esecuzione automatica mi appariva la barra di windows sopra il software. Dopo 10000 ricerche tra i forum basta inserire l'opzione " -d 5 " al collegamento di XBMC. Questo lo farà avviare 5 secondi dopo che la barra di windows si è sistemata. In pratica si caricava prima XBMC e poi la barra di win.  Troppo veloci stì PC !!</p>
<p>Ecco la mia esperienza completa con un HTPC.</p>
<p>Spero sia di aiuto a tutti gli altri appassionati dell'argomento.</p>
]]></description><link>https://www.xtremehardware.com/forum//topic/26853/case-m350-pentium-g630-come-htpc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 08 Apr 2026 02:38:31 GMT</lastBuildDate><atom:link href="https://www.xtremehardware.com/forum//topic/26853.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 May 2012 20:28:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Wed, 04 Jul 2012 12:38:38 GMT]]></title><description><![CDATA[<p>bhè i progetti spesso sono sulla stessa base quindi credo che non gli crei problemi <img src="/assets/uploads-legacy/emoticons/afro.gif.17de86fe34bff2b0b91da1f54c9b3376.gif" alt="O0" /></p>]]></description><link>https://www.xtremehardware.com/forum//post/397324</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397324</guid><dc:creator><![CDATA[tom1]]></dc:creator><pubDate>Wed, 04 Jul 2012 12:38:38 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Wed, 04 Jul 2012 12:33:18 GMT]]></title><description><![CDATA[<p>Diciamo che sono in fase esplorativa ancora, manca un pezzo importante da valutare che si chiama trinity...</p>
<p>Comunque aprirò un 3d tutto mio. Anzi chiedo scusa a Tulip se ho "dirottato" il suo.</p>
]]></description><link>https://www.xtremehardware.com/forum//post/397323</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397323</guid><dc:creator><![CDATA[azi_muth]]></dc:creator><pubDate>Wed, 04 Jul 2012 12:33:18 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Wed, 04 Jul 2012 06:37:08 GMT]]></title><description><![CDATA[<p>quindi sei in procinto di un nuovo progetto ?</p>]]></description><link>https://www.xtremehardware.com/forum//post/397322</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397322</guid><dc:creator><![CDATA[tom1]]></dc:creator><pubDate>Wed, 04 Jul 2012 06:37:08 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Wed, 04 Jul 2012 00:05:57 GMT]]></title><description><![CDATA[<p>Osservazioni giustissime:</p>
<p>La ram a bassa latenza è un vezzo e poi costa solo 6 euro in più della normale...non cambia molto le cose </p>
<p> I prezzi delle h67 /h77 itx ...li ricordo altini ma forse sono rimasto indietro. </p>
<p>Quei dischi SSD sata 3 li ho scelti solo perchè sembrano essere quelli più affidabili, se ci fossero dei sata 2 a 1/2 del prezzo forse sarebbero anche più ragionevoli, però mi pare che la tecnologia "al tempo" non fosse molto matura... e a dirti la verità anche adesso mi sembra semi sperimentale a sentire i casi di failure e dischi che tornano indietro. Tuttavia non credo che la differenza si senta su un'htpc in termini di fluidità e tempi di boot.</p>
]]></description><link>https://www.xtremehardware.com/forum//post/397321</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397321</guid><dc:creator><![CDATA[azi_muth]]></dc:creator><pubDate>Wed, 04 Jul 2012 00:05:57 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Tue, 03 Jul 2012 20:01:08 GMT]]></title><description><![CDATA[<blockquote>
<p><strong>azi_muth ha scritto:</strong></p>
<div>Facendo rapido conto ed economizzando sul case ed alimentazione avevo tirato fuori questa lista
<p>EK00006971      Case Mini LC-Power LC-1320mi MiniITX Nero con alimentatore esterno LC75ITX 75W     € 44,30     € 44,30      0,00%              </p>
<p>EK00015474      .RAM DDR3 G.Skill Ripjaws-X F3-10666CL7D-4GBXH 1333MHz 4GB (2x2GB) CL7-7-7-21 1.5v     € 28,00     € 28,00      0,00%              </p>
<p>EK00019879      Scheda Madre Asrock H61M-ITX Socket 1155 Intel H61 DDR3 SATA2 USB3 HDMI Mini-ITX     € 61,20     € 61,20      0,00%              </p>
<p>EK00018360      SSD Crucial RealSSD M4 64GB 2.5" Lettura 415MB/s Scrittura 95MB/s Sata3 CT064M4SSD2     € 67,30     € 67,30      0,00%              </p>
<p>EK00018413       CPU Intel Pentium Dual-Core G620 2.60GHz Socket 1155 65W Sandy Bridge  con GPU Boxed BX80623G620     € 50,40     € 50,40      0,00% </p>
<p>251,20 €</p>
<p>In realtà si può limare un po' sulle memorie che sono a bassa latenza (fisse audiofile) e anche l'SSD forse si riesce trovare a meno...Samsung 830 da 64gb era in offerta a 50 euro...</p>
<p>Manca il bluray slim... hai qualche suggerimento?</p>
<p>Frena frena......</p>
<p>Hai preso la scheda madre con chipset H61 !! La differenza tra H61 e H67 sono le 2 porte SATA3 per i dischi. E' inutile prendere un Crucial o Samsung che sia ed attaccarlo ad una porta SATA2. La differenza con un hard disk meccanico si vede lo stesso ma non è sfruttato al max. Tanto vale prendere una ram stile Kingston value Ram e con quello che risparmi ti prendi un H67. Tanto per un HTPC la ram conta proprio ZERO o poco più !! O altrimenti ti prendi H61 e rinunci al SSD</p>
]]></description><link>https://www.xtremehardware.com/forum//post/397320</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397320</guid><dc:creator><![CDATA[TulipanZ]]></dc:creator><pubDate>Tue, 03 Jul 2012 20:01:08 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Tue, 03 Jul 2012 15:03:55 GMT]]></title><description><![CDATA[<p>non male la configurazione</p>]]></description><link>https://www.xtremehardware.com/forum//post/397319</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397319</guid><dc:creator><![CDATA[tom1]]></dc:creator><pubDate>Tue, 03 Jul 2012 15:03:55 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Tue, 03 Jul 2012 13:54:57 GMT]]></title><description><![CDATA[<p>Facendo rapido conto ed economizzando sul case ed alimentazione avevo tirato fuori questa lista</p>
<p>251,20 €</p>
]]></description><link>https://www.xtremehardware.com/forum//post/397318</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397318</guid><dc:creator><![CDATA[azi_muth]]></dc:creator><pubDate>Tue, 03 Jul 2012 13:54:57 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Tue, 03 Jul 2012 13:21:06 GMT]]></title><description><![CDATA[<blockquote>
<div>Meno male! Da quello che leggo in giro sembrava ci fossi solo io a ritenere che gli intel siano utilizzabili anche senza integrata a scopo htpc! Io ho usato un g620 per breve periodo poi visto che avevo un vecchio x2 4850e fermo ho deciso di adibire il pentium ad altro scopo più prosaico... però "tragedie" particolari non le avevo notate...anzi visto che i trinity nuovi sono ancora lontani...mi hai fatto venire voglia di fare nuovamente lo swap...stavolta in salsa miniitx <img src="/assets/uploads-legacy/emoticons/afro.gif.17de86fe34bff2b0b91da1f54c9b3376.gif" alt="O0" />
<p>Alla fine quando l'ho assemblato ad aprile ho speso circa 400 euro. Ma ho preso tutto nuovo e con hard disk SSD. Solo quello sono quasi 80 euri ed anche il dissipatore dedicato per farci stare 2 dischi sono altre 25 euro. Volendo se smonti un disco da un portatile limi qualcosa anche lì. Diciamo che con quei prezzi al mercato d'oggi ci prendi un netbook con un " fantastico " Atom !!!</p>
]]></description><link>https://www.xtremehardware.com/forum//post/397317</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397317</guid><dc:creator><![CDATA[TulipanZ]]></dc:creator><pubDate>Tue, 03 Jul 2012 13:21:06 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Tue, 03 Jul 2012 12:04:58 GMT]]></title><description><![CDATA[<blockquote>
<p><strong>TulipanZ ha scritto:</strong></p>
<div>Ciao ci si vede anche di qua !!!
<p>All'inizio xbmc mi freezava il pc ma solo avviandolo. Ho risolto selezionando da bios la scheda grafica integrata invece della pciex (a cui non era collegato niente) Risolto questo nessun problema. Vedo filmati MKV 1080p da 15gb tranquillamente con CPU al 15%</p>
<p>Meno male! Da quello che leggo in giro sembrava ci fossi solo io a ritenere che gli intel siano utilizzabili anche senza integrata a scopo htpc! Io ho usato un g620 per breve periodo poi visto che avevo un vecchio x2 4850e fermo ho deciso di adibire il pentium ad altro scopo più prosaico... però "tragedie" particolari non le avevo notate...anzi visto che i trinity nuovi sono ancora lontani...mi hai fatto venire voglia di fare nuovamente lo swap...stavolta in salsa miniitx <img src="/assets/uploads-legacy/emoticons/afro.gif.17de86fe34bff2b0b91da1f54c9b3376.gif" alt="O0" /></p>
]]></description><link>https://www.xtremehardware.com/forum//post/397316</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397316</guid><dc:creator><![CDATA[azi_muth]]></dc:creator><pubDate>Tue, 03 Jul 2012 12:04:58 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Sun, 24 Jun 2012 12:22:33 GMT]]></title><description><![CDATA[<p>Ah ok difatti freezava tutto !!!</p>]]></description><link>https://www.xtremehardware.com/forum//post/397315</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397315</guid><dc:creator><![CDATA[TulipanZ]]></dc:creator><pubDate>Sun, 24 Jun 2012 12:22:33 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Sun, 24 Jun 2012 12:07:43 GMT]]></title><description><![CDATA[<p>no dicevo che con la grafica integrata era difficile che non riproduceva e manteneva xmbc</p>]]></description><link>https://www.xtremehardware.com/forum//post/397314</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397314</guid><dc:creator><![CDATA[tom1]]></dc:creator><pubDate>Sun, 24 Jun 2012 12:07:43 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Sun, 24 Jun 2012 12:00:06 GMT]]></title><description><![CDATA[<p>Che intendi. Tom non ho capito.   :sly:</p>]]></description><link>https://www.xtremehardware.com/forum//post/397313</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397313</guid><dc:creator><![CDATA[TulipanZ]]></dc:creator><pubDate>Sun, 24 Jun 2012 12:00:06 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Sun, 24 Jun 2012 11:36:01 GMT]]></title><description><![CDATA[<p>come minimo doveva girare tutto a palla</p>]]></description><link>https://www.xtremehardware.com/forum//post/397312</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397312</guid><dc:creator><![CDATA[tom1]]></dc:creator><pubDate>Sun, 24 Jun 2012 11:36:01 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Sat, 23 Jun 2012 20:00:32 GMT]]></title><description><![CDATA[<blockquote>
<div>Con quale software utilizzi questa configurazione? Xmbc aveva qualche problemino con dxva e le intel (infatti andava disabilitata)<p>Riesci a vedere filmati hd in maniera fluida?</p>
<p>Ciao ci si vede anche di qua !!!</p>
]]></description><link>https://www.xtremehardware.com/forum//post/397311</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397311</guid><dc:creator><![CDATA[TulipanZ]]></dc:creator><pubDate>Sat, 23 Jun 2012 20:00:32 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Sat, 23 Jun 2012 18:50:54 GMT]]></title><description><![CDATA[<p>ciao passa a presentarti qui </p>
<p><a href="http://www.xtremehardware.com/forum/f46/">Presentazione nuovi utenti</a></p>
<p>poi </p>
<p>con quella configurazione senza problemi fa tutto da xmbc</p>
]]></description><link>https://www.xtremehardware.com/forum//post/397310</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397310</guid><dc:creator><![CDATA[tom1]]></dc:creator><pubDate>Sat, 23 Jun 2012 18:50:54 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Sat, 23 Jun 2012 18:05:20 GMT]]></title><description><![CDATA[<p>Con quale software utilizzi questa configurazione? Xmbc aveva qualche problemino con dxva e le intel (infatti andava disabilitata)</p>
]]></description><link>https://www.xtremehardware.com/forum//post/397309</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397309</guid><dc:creator><![CDATA[azi_muth]]></dc:creator><pubDate>Sat, 23 Jun 2012 18:05:20 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Wed, 06 Jun 2012 11:59:20 GMT]]></title><description><![CDATA[<blockquote>
<p><strong>One1ros ha scritto:</strong></p>
<div>Hai ottimizzato lo spazio alla perfezione. <img src="/assets/uploads-legacy/emoticons/afro.gif.17de86fe34bff2b0b91da1f54c9b3376.gif" alt="O0" /><p>Interessante questo XMBC, non lo conoscevo! :n2mu:</p>
<p>sei il solito <img src="/assets/uploads-legacy/emoticons/asd.gif.50bd87e1bd2fb722ff72ad77f76e268c.gif" alt=":asd:" /></p>
]]></description><link>https://www.xtremehardware.com/forum//post/397308</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397308</guid><dc:creator><![CDATA[tom1]]></dc:creator><pubDate>Wed, 06 Jun 2012 11:59:20 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Wed, 06 Jun 2012 11:52:16 GMT]]></title><description><![CDATA[<p>Hai ottimizzato lo spazio alla perfezione. <img src="/assets/uploads-legacy/emoticons/afro.gif.17de86fe34bff2b0b91da1f54c9b3376.gif" alt="O0" /></p>
]]></description><link>https://www.xtremehardware.com/forum//post/397307</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397307</guid><dc:creator><![CDATA[One1ros]]></dc:creator><pubDate>Wed, 06 Jun 2012 11:52:16 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Thu, 31 May 2012 18:12:03 GMT]]></title><description><![CDATA[<p>ora sotto con qualche test <img src="/assets/uploads-legacy/emoticons/afro.gif.17de86fe34bff2b0b91da1f54c9b3376.gif" alt="O0" /></p>]]></description><link>https://www.xtremehardware.com/forum//post/397306</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397306</guid><dc:creator><![CDATA[tom1]]></dc:creator><pubDate>Thu, 31 May 2012 18:12:03 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Thu, 31 May 2012 11:58:29 GMT]]></title><description><![CDATA[<p>Grazie Grazie mi fate arrossire.......</p>]]></description><link>https://www.xtremehardware.com/forum//post/397305</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397305</guid><dc:creator><![CDATA[TulipanZ]]></dc:creator><pubDate>Thu, 31 May 2012 11:58:29 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Thu, 31 May 2012 06:28:50 GMT]]></title><description><![CDATA[<p>spettacolo davvero , complimenti per l'integrazione.</p>]]></description><link>https://www.xtremehardware.com/forum//post/397304</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397304</guid><dc:creator><![CDATA[tom1]]></dc:creator><pubDate>Thu, 31 May 2012 06:28:50 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Wed, 30 May 2012 21:05:10 GMT]]></title><description><![CDATA[<p>ragazzi 2hd su un M350.......<img src="/assets/uploads-legacy/emoticons/icon_pray.gif.2f3ae52d46a32736fd890e2ce0aba6cd.gif" alt=":ave:" /></p>
<p>come 4 gorilla su una panda....</p>
]]></description><link>https://www.xtremehardware.com/forum//post/397303</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397303</guid><dc:creator><![CDATA[davidecesare]]></dc:creator><pubDate>Wed, 30 May 2012 21:05:10 GMT</pubDate></item><item><title><![CDATA[Reply to Case M350 + Pentium G630 come HTPC on Wed, 30 May 2012 20:28:48 GMT]]></title><description><![CDATA[<p>Vi presento il mio nuovo HTPC.....</p>
<p>CASE: M350</p>
]]></description><link>https://www.xtremehardware.com/forum//post/397302</link><guid isPermaLink="true">https://www.xtremehardware.com/forum//post/397302</guid><dc:creator><![CDATA[TulipanZ]]></dc:creator><pubDate>Wed, 30 May 2012 20:28:48 GMT</pubDate></item></channel></rss>
