Labview
 Share
Vi può interessare?
32 members have voted
  1. 1. Vi può interessare?
    • Si
    • No
    • Non lo so
Ho aggiunto questo in prima pagina:
|                 AMI Firmware Update Utility  v3.02.00                     |
|      Copyright (C)2012 American Megatrends Inc. All Rights Reserved.      |
| Usage: AFUDOS.EXE  [Option 1] [Option 2]...                |
|           or                                                              |
|        AFUDOS.EXE                    |
|           or                                                              |
|        AFUDOS.EXE                                                |
| Commands:        |
|         /O - Save current ROM image to file                               |
|         /U - Display ROM File's ROMID                                     |
|         /S - Refer to Options: /S                                         |
|         /D - Verification test of given ROM File without flashing BIOS.   |
|         /A - Refer to Options: /A                                         |
|       /OAD - Refer to Options: /OAD                                       |
| /CLNEVNLOG - Refer to Options: /CLNEVNLOG                                 |
| Options:        |
|         /Q - Silent execution                                             |
|         /X - Don't Check ROM ID                                           |
|       /CAF - Compare ROM file's data with Systems is different or         |
|              not, if not then cancel related update.                      |
|         /S - Display current system's ROMID                               |
|  /HOLEOUT: - Save specific ROM Hole according to RomHole GUID.            |
|              NewRomHole1.BIN /HOLEOUT:GUID                                |
|        /SP - Preserve Setup setting.                                      |
|         /R - Preserve ALL SMBIOS structure during programming             |
|        /Rn - Preserve SMBIOS type N during programming(n=0-255)           |
|         /B - Program Boot Block                                           |
|         /P - Program Main BIOS                                            |
|         /N - Program NVRAM                                                |
|         /K - Program all non-critical blocks.                             |
|        /Kn - Program n'th non-critical block(n=0-15).                     |
|     /HOLE: - Update specific ROM Hole according to RomHole GUID.          |
|              NewRomHole1.BIN /HOLE:GUID                                   |
|         /L - Program all ROM Holes.                                       |
|        /Ln - Program n'th ROM Hole only(n=0-15).                          |
|      /ECUF - Update EC BIOS when newer version is detected.               |
|         /E - Program Embedded Controller Block                            |
|        /ME - Program ME Entire Firmware Block.                            |
|      /MEUF - Program ME Ignition Firmware Block.                          |
|         /A - Oem Activation file                                          |
|       /OAD - Delete Oem Activation key                                    |
| /CLNEVNLOG - Clear Event Log.                                             |
|   /CAPSULE - Override Secure Flash policy to Capsule                      |
|  /RECOVERY - Override Secure Flash policy to Recovery                     |
|        /EC - Program Embedded Controller Block. (Flash Type)              |
|    /REBOOT - Reboot after programming.                                    |
|  /SHUTDOWN - Shutdown after programming.                                  |
http://www.ami.com/support/downloads/amiflash.zip
Altro non posso dare... :asd:
  • 1 month later...
Ciao a tutti,
è da un pò che vi leggo e alla fine mi sono iscritto.
Ho approfittato di un'occasione su ebay e comprato un programmatore willem pro 2, oggi è arrivato e sinceramente c'ho capito ben poco (non sono esperto nella programmazione di eeprom), tutti quei numeri, sigle mi hanno mandato in confusione. Io userei il programmatore soltanto per smanettarci un pò su e per lavoro, e avrò a che fare soltanto con eeprom plcc (quindi bios di sk madre). Non è che potreste darmi un aiuto su come usarla? Grazie mille
ciao passa come prima cosa a presentarti qui
Presentazione nuovi utenti
poi
cosa di preciso non capisci ? Il funzionamento del willem è molto easy ma "manuale". Devi scegliere il modello del bios e dopo settare i pin come mostrato nel programma sul pcb dello stesso.
Mi sono presentato, grazie per la segnalazione.
Per il discorso Willem lo sapevo già che è il programma a guidarti sulla disposizione dei pin, il problema è che tra i millemila menu non riesco a capire quale devo scegliere, e poi di slot plcc ce ne stanno 2, non saprei quale usare sinceramente...
 Share
